A Newbies Journey with the TIPI
145 replies to this topic
#51 ndp630 OFFLINE
ndp630
    Star Raider
  • 50 posts
Posted Tue Apr 17, 2018 7:14 PM
You read my mind. I was about ask if there was a FG99 version. Thank you!
Oh BTW - If you want documentaion for 4A/DOS...   ;-)
Be sure to put CHARA1 on DSK1.
#52 jedimatt42 OFFLINE
jedimatt42
  • 1,818 posts
Posted Tue Apr 17, 2018 8:04 PM
That's pretty cool Omega! I came to 4A/DOS only after having a PC with directories.. So 4A/DOS just never made sense to me on a flat floppy system like the old TIFDC.
-M@
#53 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Sat Apr 21, 2018 7:42 PM
Okay, when I have a few minutes 'here and there' I like to mess around...
In the new documentation for the TIPICFG program, Matt has a link under "URI3="
I figured, might at well try it as my "URI1"
Can't do a directory using DM2K though.. it was worth a shot... just for the heck if it.
4A DOS gives you a little bit more, but nothing usable.
#54 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Sun Apr 22, 2018 3:14 PM
Hey guys, here's a little hack I came up with for you guys wanting to load the 9640 Menu System on your TIPI's using the FinalGROM99.
1) Create a directory on your RPi's SD card for TIPI called "BOOT"
     Put all the files in the BOOT folder there.
2) Now put the files in the FG99 ROOT folder in the ROOT directory of your FG99
3) Go to TI BASIC, CALL TIPI and then set your DSK3 as BOOT
Now whenever you load up your FG99, you have a selection to instantly load up the 9640 Menu System.
#55 jedimatt42 OFFLINE
jedimatt42
  • 1,818 posts
Posted Sun Apr 22, 2018 6:50 PM
The goal and purpose of the URI1-3 things is so that programmers who want to fetch data off a long link, can set a large redundant part of the link into the URI mapping, and then fetch subsequent data or program files from it.
There is no support for parsing apache style directory listings from a web server.
Glad to see you playing at the edges though! icon_smile.gif Good stuff.
I imagine programs to set URI shortcuts, not just manual user usage. So after running some online adventure game, URI3 might have been remapped on you.
It also serves as an integration compatibility bit... as many programs on the 4A pretend we don't have a case-sensative filesystem and force UPPERCASE only path entry. The web is highly case-sensative for the 'path' part of a URL. So all that can be mapped into URI1, and then you can get a legacy program to open the file with URI1.DATA or whatever...
-M@
#56 ndp630 OFFLINE
ndp630
    Star Raider
  • 50 posts
Posted Tue Apr 24, 2018 12:18 PM
I've not had time to play with TiPi yet, but is 9640 menu for F18A consoles only (80 column)?
#57 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Tue Apr 24, 2018 1:25 PM
Yes, the 9640 Menu System is only 80 column... BUT there is a great program called BOOT that works very much like it for users still using the original 9918 VDP.
Note: Unless you have a 'Real Time Clock' in your P-Box. you'll not see the clock display, but other than that, this is what it looks like.
#58 ndp630 OFFLINE
ndp630
    Star Raider
  • 50 posts
Posted Tue Apr 24, 2018 2:08 PM
OK. Cool.... I remember your post about BOOT in another thread I think. I hope to get some free time this evening to try it out. Thanks!
Edit: The post I misremembered was for 9640 Menu system. I'm looking for BOOT now.
Edited by ndp630, Tue Apr 24, 2018 3:08 PM.
#59 arcadeshopper OFFLINE
arcadeshopper
  • 3,851 posts
Posted Tue Apr 24, 2018 3:36 PM
using boot to make things easier, auto loads in xb and then i get a menu that will load both xb programs and ea5 images
#60 ndp630 OFFLINE
ndp630
    Star Raider
  • 50 posts
Posted Tue Apr 24, 2018 3:40 PM
I found BOOT in an old thread. I can't get through the login on wht to get it.
#61 arcadeshopper OFFLINE
arcadeshopper
  • 3,851 posts
Posted Tue Apr 24, 2018 3:44 PM
Use http or anonymous with no pwd
Sent from my LG-H872 using Tapatalk
#62 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Tue Apr 24, 2018 8:39 PM
In a CHATTI conversation with jonecool tonight, The topic of having a list of games or other programs on the TIPI server would be great.  That way people without FG99's could easily load and run most of their favorites in a snap, just like CHATTI, TELNET, CHESS, AMBULANCE, etc.
#63 ndp630 OFFLINE
ndp630
    Star Raider
  • 50 posts
Posted Wed Apr 25, 2018 10:32 AM
I haven't gotten to sit down at the TI yet, but I see 2 files listed at BOOT and BOOU in the zip. Should there be a loader for XB too?
#64 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Wed Apr 25, 2018 10:52 AM
Just use the XB loader included in the ZIP file in << THIS MESSAGE >>  It should work fine.
#65 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Sun Apr 29, 2018 4:04 PM
The old X10 Home Automation stuff is rather out-of-date, and now days almost everything is WiFi.
I'm thinking TIPI is WiFi via the RPI and using the TI as the control interface...
... It even has the time and date that could be used for on/off times...
... pondering potential uses and justifications ...
#66 ElectricLab OFFLINE
ElectricLab
    Chopper Commander
  • 245 posts
Posted Sun Apr 29, 2018 5:20 PM
Since my home-grown HA system is drivable via http, Ive been wanting to create a simple control program. I can control the whole house from BASIC by just making http requests, so a user-friendly program will be easy. Ill probably give it a go after I get Chess done.
Edited by ElectricLab, Sun Apr 29, 2018 5:24 PM.
#67 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Mon Apr 30, 2018 11:46 AM
4A/DOS -- Essentially a TIPI/RPi Operating System
For those who have not tried it with their TIPI's yet...  I HIGHLY RECOMMEND IT!
A) Download the ZIP
B) Extract CHARA1 and put it on your DSK1.
C) If you also use an F18A, extract AUTO-BAT and also install it on your DSK1.
On your FinalGROM put the 4ados.BIN file in the ROOT directory.  If using a FlashROM 99, just put it in with everything else.
If more than a couple of people are interested in a video, let me know and I'll try to make one, otherwise this will be it.
The attachment contains the documentaion and cover, the .BIN image for the FR99 or FG99, the CHARA1 character set and a batch file tailored for TIPI and F18A users.
#68 ndp630 OFFLINE
ndp630
    Star Raider
  • 50 posts
Posted Mon Apr 30, 2018 7:33 PM
I’d appreciate a video.
A) Download the ZIP
#69 Shift838 OFFLINE
Shift838
  • 2,436 posts
  • SHIFT838
Posted Thu May 3, 2018 4:07 PM
4A dos works great on the TIPI..
#70 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Thu May 3, 2018 10:24 PM
I have build 18 up and running with my I2C!  All thank's to Shift838 and his new disk image!  Thanks again Chris!
msg-35324-0-95974100-1525407609_thumb.pn
#71 jedimatt42 OFFLINE
jedimatt42
  • 1,818 posts
Posted Thu May 3, 2018 10:35 PM
-- unnecessary expression of frustration on my part. --
-M@
Edited by jedimatt42, Thu May 3, 2018 11:10 PM.
#72 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Fri May 11, 2018 8:41 AM
Now that I've "settled in" with the TIPI, I've noticed my computing habits are changing.  Before TIPI, I would not turn on my TI every day, but now since it's always "ready to go", I started switching it on first thing in the morning (while the PC was booting) and checked the BBS, Chatti messages and even the chess game in progress.  Now I find myself not even bothering with the PC, I go straight for the TI!
It makes me wonder how long it will be before I can start logging into AtariAge with my TI!  I know it's possible, with the TIPI.  Maybe it'll be like using the cellphone method but sans the graphics?  I get the feeling that some day in the future I'll FINALLY be able to do all things TI related with my TI.
#73 Casey OFFLINE
Casey
    Moonsweeper
  • 307 posts
Posted Fri May 11, 2018 10:58 AM
I’m looking forward to receiving a TIPI shortly, but I would think now, with this device, it should be possible to make a Twitter client that runs on the TI. It probably can’t do anything with the graphics people post, but it should be able to easily consume the text and manage the Twitter feed. That’s a project I’d like to see if I can take a swing at, at least.
#74 ElectricLab OFFLINE
ElectricLab
    Chopper Commander
  • 245 posts
Posted Fri May 11, 2018 12:53 PM
Im looking forward to receiving a TIPI shortly, but I would think now, with this device, it should be possible to make a Twitter client that runs on the TI. It probably cant do anything with the graphics people post, but it should be able to easily consume the text and manage the Twitter feed. Thats a project Id like to see if I can take a swing at, at least.
Yes you most certainly could! I developed CHATTI and would be happy to share what Ive done. A twitter client would be a bit different but some concepts would be similar :)
#75 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,030 posts
Posted Thu May 17, 2018 4:22 PM
While playing around with BA-WRITER on TIPI today, I found that you can "PRINT" to a file, for instance if do a PF and then give it a device name of TIPI.WRITER.TEST you can then download the file to your PC using the HTML utility on your browser.  You can then open it with Notepad, although the formatting may be a little 'funky'.  The same should work even with BASIC programs.  Give it a shot.
