XEGS ROM Geometry
XEGS OS ROM EPROM
18 replies to this topic
#1 flashjazzcat ONLINE
flashjazzcat
  • 14,325 posts
Posted Thu Apr 5, 2018 8:26 AM
I've just fixed an XEGS with a bad ROM and MMU, and have got it going temporarily by flashing four copies of the XEGS OS to a 27C128. Naturally it boots straight to the Self-Test, since there's no BASIC or Missile Command. I can't seem to find out what the ROM layout is supposed to be, however, on a 32K chip (i.e., is it BASIC, Missile Command, OS ROM, or OS ROM, Missile Command, BASIC?). Needless to say I've also been unable to locate a complete 32K dump of the XEGS ROM, otherwise I wouldn't be asking how to manually assemble one. :)
#2 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
  • What is your Alternate Reality?
Posted Thu Apr 5, 2018 8:37 AM
Funny.  I was in the exact same position, years ago, and couldn't find anything either.  That XEGS still has only an XE os without basic and m/c.
#3 Nezgar ONLINE
Nezgar
  • 1,573 posts
Posted Thu Apr 5, 2018 9:00 AM
I found this 2016 post by Rybags that contains an untested 32KB XEGS ROM dump, and followup enlightening (as usual) posts by phaeron :)
http://atariage.com/...-rom/?p=3639787
The order of components can probably be easily determined by inspecting the dump.
Edited by Nezgar, Thu Apr 5, 2018 9:04 AM.
#4 Rybags ONLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Thu Apr 5, 2018 9:02 AM
It should be OS ROM, Missile Command then Basic.
OS ROM being 4K that would appear at $C000 then the 2K of Self-Test, then the 2K FPP.
Then the 2K character set and 8K high part of OS ROM.
This is from an image called xegs_alt that I've got configured in Altirra which it recognises as XEGS firmware.
Easy eyecatcher signs of what part of the Rom you're looking at:
The low part of the OS Rom should have a bunch of zero bytes just before offset C00 as well as the 8 zero bytes @ C00 for start of the second character set.
Similarly the high part of the OS Rom will have 9 zeros then several hex 18, 00, 18, 00 (space then ! character)
The Missile Command game is actually only 6K, so there will be 2K worth of leading zeros.
Game and Basic ROM should have the normal bunch of vectors and flags at offset 1FFA in their parts of the image.
#5 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 756 posts
Posted Thu Apr 5, 2018 9:04 AM
That´s quite easy - but the organisation is strange.
ROM offsets:
$0000-$1FFF - 8 KB Missile Command
$2000-$3FFF - 8 KB BASIC
$4000-$7FFF - 16 KB Operating System
The MMU is a little bit different from the XL one, it uses the PB6 bit for selecting Missile Command / BASIC and managed the addressline A13 for a working O.S. access.
I´ve made an standard XL MMU for usage of standard 16 KB O.S. (so no problems with memory expansions using PB6). Here´s the code:
CHIP   MMU_XEGS   GAL16V8   COMPLEX_MODE
A11  A12  A13  A14     A15  MAP  RD4  RD5  REN  GND
REF  S5   PB6  ROMSEL  OS   CI   IO   BE   S4   VCC
/S4  = /A13 & /A14 & A15 & RD4 & REF;
/S5  =  A13 & /A14 & A15 & RD5 & REF;
/IO  = /A11 & A12 & /A13 & A14 & A15 & REF;
/OS  =  A13 &  A14 &  A15 &  REN &  REF                       /* $E000-$FFFF */
     + /A12 & /A13 &  A14 &  A15 &  REN & REF                 /* $C000-$CFFF */
     +  A11 &  A12 & /A13 &  A14 &  A15 & REN & REF           /* $D800-$DFFF */
     +  A13 & /A14 &  A15 & /RD5 &  /BE & REF                 /* Atari-Basic */
     + /A11 &  A12 & /A13 &  A14 & /A15 & /MAP & REN & REF;   /* Selbsttest */
/CI  = /A13 & /A14 &  A15 & RD4 & REF
     +  A13 & /A14 &  A15 & RD5 & REF
     + /A11 &  A12 & /A13 & A14 & A15 & REF
     + /OS
     + /REF;
ROMSEL = A13 &  A14 & A15
       + A13 & /A14 & A15 & /BE;
BR Jurgen
#6 Rybags ONLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Thu Apr 5, 2018 9:05 AM
OK, well that's a bit weird.
The ROM I posted in that thread Nezgar just pointed to has MC, Basic then the OS.
"Logically" you'd probably do it that way but given the MMU is producing the select signals for the 2 msbs to the ROM it sort of doesn't matter - in theory they could have ordered it any way they wanted.
#7 flashjazzcat ONLINE
flashjazzcat
  • 14,325 posts
Posted Thu Apr 5, 2018 9:10 AM
Thanks all. I'd noticed the MMU's RS (ROM select) pin on the schematic, connected to A13, but couldn't figure out the organisation on the chip. Nice thing about putting this on an EPROM is that the customer can have Altirra BASIC and a different game if they want. :)
@Jurgen: thanks for the MMU GAL code as well. Most useful, and I almost had to resort to a GAL in order to repair this machine.
#8 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
Posted Thu Apr 5, 2018 12:35 PM
For what it's worth: the info I have about the XEGS ROM I have (same CRC32 as the one mentioned above)
ATA_XEGS.ROM = ATARI XEGS O.S.
 8K : Missile Command
 8K : BASIC Rev.C
16K : ATARI OS. Rev.4
Match: XEGS.ROM (Freddy Offenga)
CRC32: D50260D1
#9 flashjazzcat ONLINE
flashjazzcat
  • 14,325 posts
Posted Thu Apr 5, 2018 1:05 PM
Unfortunately this XEGS was sent direct from Hell, since it worked (with an EPROM OS), was elaborately modded with a DIN-5 monitor jack and Y/C video, booted to show a beautiful display, and promptly died. It's booted about twice out of 100 tries since, while I scour the board for shorts and breakages. :(
#10 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
Posted Thu Apr 5, 2018 1:42 PM
My N.O.S. XEGS came with a faulty O.S. out of it's factory sealed box.  After putting in an EPROM, with 4 times Rev4 O.S. in it just to get it running, it turned out to be a very flaky bitch.  It probably has some more hidden "features" I don't know about.
Have another one from the same batch but don't know how this one behaves as I never unpacked it.
Judging outside views from a third one, this one probably works o.k, or at least did for a period of time. Never opened it up, or even connected the thing to see if still works.
#11 flashjazzcat ONLINE
flashjazzcat
  • 14,325 posts
Posted Thu Apr 5, 2018 1:48 PM
A friend of mine got an XEGS for Christmas in 1987 or so and after his mother returned two or three of the things which arrived DOA from the catalogue company, his dad took him to Curry's and bought him a 65XE.
Just took ANTIC off this one and put a socket under it since it seemed to be the last VLSI which would stop the system dead in its tracks, but it didn't help.
#12 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
Posted Thu Apr 5, 2018 3:04 PM
Sounds like those 2 (3) are from the same batch.  My first two were both from the left-over stock from Atari Benelux.
If you succeed to repair it, don't hesitate to write it down  (so I can repair mine when I'm at it :-) )
#13 flashjazzcat ONLINE
flashjazzcat
  • 14,325 posts
Posted Thu Apr 5, 2018 4:03 PM
I noticed some odd behaviour (brief flickers of life) when flexing the board, but could not reproduce this later on. So something's cracked somewhere. Not fun. :)
#14 1050 OFFLINE
1050
  • 1,065 posts
Posted Thu Apr 5, 2018 8:18 PM
Not sure it will help at all but I've found that
OS eprom speed need to be 200ns and above or they get
flaky enough to behave as if they aren't even there.
Sort of like yours? Had several OS projects fail
and then discovered this anomaly with no issues
since. No explanation for it of course.
#15 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 756 posts
Posted Fri Apr 6, 2018 1:56 AM
I´ve also had some XEGS with issues like that. The half of issues I can fix with changing the DRAMsm the other with OS-ROM and MMU. it´s strange... I never must change DRAMs (as long the right power supply was used  :-D ) at the Atari 130 XE mainboards using 2 (800XE) or 4 (130XE) DRAM 41464 models, but the XEGS - with same DRAM type - has a lot defects.
Also the OS-ROM was faulty some times, in the most cases the MMU (PAL16L8) was defect - typically on or more of the outputs can´t sink, they remain at high level forever.
My personal thoughts are, that the XEGS - the last production line - was populated with all the sediments Atari found in their production warehouses :-o
#16 flashjazzcat ONLINE
flashjazzcat
  • 14,325 posts
Posted Fri Apr 6, 2018 3:31 AM
Sort of like yours?
I've lacked faith in these EPROMs since the get go, after my TL866 failed to write a TMS 27PC512 which would have been a perfect fit. I then resorted to windowed EPROMs. I may simply pull the OS ROM of another XEGS board here to definitively rule out the ROM as a source of issues. Thanks for the tip!
At first I was convinced the thing had taken a hit from a Commodore PSU, and therefore aimed for RAM and MMU first. It's only later I noticed corrosion at the front edge of the board (looks like all the console keys are kaput), and evidence of someone working on the board beforehand (although the poor soldering appears confined to innocuous areas around the joystick ports).
I agree. It's a shame, since the component count is comparatively low and there is a lot of copper on the board, but it appears what's soldered to it is basically junk.
#17 Marius OFFLINE
Marius
  • 4,800 posts
Posted Fri Apr 6, 2018 5:50 AM
I have always been a fan of the xegs. I have quite some of these friendly looking cases with their colourful buttons and external keyboard. The ones I have also have a very good and crisp default video output.
I hated the power switch and the lack of pbi though. The space inside for upgraded is nice.
I haven't had a single bad experience with my xegs's although that does not mean a lot. I haven't experienced a lot of trouble at all with a8. MY worst Atari was a PAL 800xl with 256kb upgraded using a handful of TTL-IC's and a lot of wires. In combination with a black box this machine was meant to crash and be unstable. Except for this, lots of success stories here... even with the xegs.
Edited by ProWizard, Fri Apr 6, 2018 5:51 AM.
#18 flashjazzcat ONLINE
flashjazzcat
  • 14,325 posts
Posted Fri Apr 6, 2018 6:53 AM
We've both been quite lucky, then, since I have two working XEGS machines here too. One even survived a 128K upgrade. As I say: I have no particular complaints about the XEGS motherboards, since they have high thermal mass and don't seem to part with traces easily. But the ICs and fittings appear to have varied in quality from one batch to the next.
In any case: I swapped the OS ROM from my own machine. No difference. Even if I were able to fix this machine, it's no longer a cost-effective proposition.
#19 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
Posted Fri Apr 6, 2018 10:47 AM
An Atari 8-bit machine and cost-effective in the very same sentence?
Also tagged with one or more of these keywords: XEGS, OS ROM, EPROM
