520ST bombs with AERCO easieST RAM upgrade
4 replies to this topic
#1 Sugarland OFFLINE
Sugarland
    Chopper Commander
  • 231 posts
Posted Fri Apr 6, 2018 5:12 PM
Hi!
I recently got a 520ST machine that may work for a few minutes when cold then throws bombs across the screen after a few minutes of being on. It has a v.2 AERCO easieST RAM upgrade. I removed the RAM upgrade and when I power it on, I now only get a black screen. I reinstall the RAM upgrade the system does give a video signal again with 3 bombs. Would someone please help me diagnose it?
More about the computer.. It has a version C motherboard with what looks like some modding or factory installed wires/jumpers/etc to the right in the photos attached.
#2 Sugarland OFFLINE
Sugarland
    Chopper Commander
  • 231 posts
Posted Fri Apr 6, 2018 5:22 PM
Also I reseated all of the socketed chips except glue. No change.
#3 Zogging Hell OFFLINE
Zogging Hell
    Moonsweeper
  • 435 posts
Posted Sat Apr 7, 2018 5:28 AM
Is it a 1mb or 512k upgrade. I notice there are empty memory chip sockets - so presumably 512k upgrade? If it is 1mb though the reason nothing works without it in could be that the internal memory has been disabled (something you would have to do with 1mb to stop the machine having 1.5mb which the ST doesn't support). Check for some snipped components near the motherboard memory. My other thought if that is not the case, is that the mounting over the MMU is to blame. I would check connections there (not pressed in correctly when you reseated it, or the socket pins aren't making good connection. I can't see how that adaptor fits over the mmu, Is it socketed and press in (i.e. pins on the adaptor push into the socket) or press on (i.e. that socket fits over a surface mounted MMU) or is it soldered on?  Finally it could be the ram has gone bad, either on the upgrade board or on the motherboard, as it seems socketed on the upgrade you could try replacing that..
#4 Sugarland OFFLINE
Sugarland
    Chopper Commander
  • 231 posts
Posted Sun Apr 8, 2018 6:40 PM
Thank you for your response!!
The RAM upgrade has pins on it that push into the MMU socket. It's not soldered. In an attempt to restore the machine to stock, I used a PLCC extractor I removed the MMU from the RAM upgrade and put it back into the motherboard socket. Same with the shifter chip - I removed the upgrade from that socket and put the shifter back in place. This is what gives me a black screen when powering on the machine. With the RAM upgrade installed I usually get bombs across the screen but sometimes the machine will work for several minutes before bombing.
I don't see any snips near the RAM on the top side of the motherboard. I will check again. I was told the machine has 2.5MB of ram.  Attached is a photo of one of the ram chips on the expansion board.  Searching for TC511000P does bring up this page which says it is 1mb. Since there are 18 chips on the board that seems to be 2MB on the expansion.
Also below is a photo of the first RAM chip on the motherboard which has a piggyback socket installed. Is that factory installed?  Looking at this photo of a rev D board it doesn't have a socket like that.
#5 Zogging Hell OFFLINE
Zogging Hell
    Moonsweeper
  • 435 posts
Posted Mon Apr 9, 2018 3:48 AM
Hhhm, if it is failing after warming up that could be a number of things. How is the power supply for this, has it been recapped? If it is the original external power supply it could be getting a bit long in the tooth now, those caps will be on their last legs probably. They could be failing which could perhaps cause your problems with the bombs.
The memory upgrade pushes into the socket between the MMU and the socket then? This might have caused the pins in the socket to fail to make proper connection when you have plopped the MMU back in. You could try gently trying to bend the pins in the socket out a bit. You did definitely put all the chips and connectors back the right way when you reinstalled didn't you? I can only assume that something has gone amiss when you reinstalled, I'd check the fitting of the MMU bit first as it can be difficult to line it up when you can't see it very well.
2.5mb makes sense, so presumably the spare slots could take you up to 4mb if you disable the onboard memory.
It's not entirely unusual for STs to have some in factory alterations, which may have been simply to make the ST work, although that socket is a bit unusual and probably not done at that stage. Soldering the socket on top would have caused a lot of heat to be transferred to the memory chip underneath potentially, which could cause it to fail over time. I can't see what purpose it could actually have really in its current state, unless the original owner was going to try to do a piggy back memory upgrade, gave up after soldering the first socket and brought that memory upgrade instead. If that chip has failed you could try and disable the onboard memory (this would reduce you to 2mb), or replacing that chip if your soldering is good. Again that could be the source of your crashes.
