How do you implement X07 (Atariage) Bankswitching?
No replies to this topic
#1 CDS Games OFFLINE
CDS Games
    Moonsweeper
  • 382 posts
Posted Thu Apr 12, 2018 5:08 AM
I'm trying to implement X07 bankswitching. I've consulted the guide (see below), and it's still not clear to me which address I should be calling. I've also stepped through an X07 ROM and seen that the different banks are called with LDA $1FEx. But then when I add that to my 64k ROM I get nothing.
Can someone give me the quick scoop on how to set it up and what values to use?
Thanks!
X07 (Atariage)
Apparently, this was only used on one cart: Stella's Stocking.
Similar to EF, there are 16 4K banks, for a total of up to 64K of ROM.
The addresses to select banks is below the ROM area, however.
The following TWO masks are used:
A13            A0
0 1xxx nnnn 1101
This means the address 80B selects bank 0, 81B selects bank 1, etc.
In addition to this, there is another way:
A13            A0
0 0xxx 0nxx xxxx
This is somewhat special purpose: Accessing here does nothing, unless one of the last two banks are selected (banks 14 or 15). In that case, the new bank is:
111n i.e. accessing 0000 will select bank 14 (Eh, 1110b) while accessing 0040 will select bank 15 (Fh, 1111b). This allows for bankswitching by accessing TIA registers at 00-3F or 40-7F without incurring any overhead.
