Not connecting to BBS's today?
16 replies to this topic
#1 V-Cool OFFLINE
V-Cool
    Star Raider
  • 54 posts
Posted Mon Apr 16, 2018 2:25 PM
Hey all, I got up and running for the first time on a BBS the other day and was trying to get back on today and can't seem to connect.  Since I only made it the one time I assume there must be a setting incorrect or a user error.
I'm using a Wimodem232, PR connection and Bobterm.
I have it set on full duplex, atascii and 9600 baud(I also tried connecting at 300 just to see).
I'm going a manual dial and typing in "8bitguild.no-ip.org:130" and have tried several others with no luck.  It shows dialing for a long time and then says no answer.  The others all said aborted after trying a while. The modem is powered up and I ran the ATI test when I went into terminal mode and everything looks ok.
Is there something obvious I am missing?
#2 Nezgar OFFLINE
Nezgar
  • 1,690 posts
Posted Mon Apr 16, 2018 2:31 PM
I don't have this device but just looked at the manual... a thought: Are you preceding the host name with ATDT? ie in ASCII translation mode:
ATDT 8bitguild.no-ip.org:130{RETURN}
If you are using ATASCII translation mode when entering this, you'll have to press Control-M instead of pressing Return.
Edited by Nezgar, Mon Apr 16, 2018 2:32 PM.
#3 Nezgar OFFLINE
Nezgar
  • 1,690 posts
Posted Mon Apr 16, 2018 2:38 PM
Just tested myself, and there is no answer on that address/port right now, so maybe you're doing it right but the BBS is just down at the moment...
#4 V-Cool OFFLINE
V-Cool
    Star Raider
  • 54 posts
Posted Mon Apr 16, 2018 2:53 PM
thanks for your help.  I tried adding the ATDT to the beginning with no improvement.
#5 Nezgar OFFLINE
Nezgar
  • 1,690 posts
Posted Mon Apr 16, 2018 3:18 PM
Can you try a different BBS until 8-bit guild is back online?
#6 V-Cool OFFLINE
V-Cool
    Star Raider
  • 54 posts
Posted Mon Apr 16, 2018 8:11 PM
I tried a few
#7 a8isa1 OFFLINE
a8isa1
  • 1,560 posts
Posted Tue Apr 17, 2018 12:38 PM
Are you sure you are connected to your router?
I don't have a wimodem232 and I don't know what firmware it runs but my ESP8266 doo-dads are running [edit] Strikelink and Zimodem firmware.  With either firmware (and other JSalin firmware derivatives I assume) the ATI command will tell you if you are connected to your router.
[P.S.]
I don't get any response from 8bitguild.no-ip.org:130
Edited by a8isa1, Tue Apr 17, 2018 12:42 PM.
#8 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 652 posts
Posted Tue Apr 17, 2018 1:11 PM
Today I am not able to get any response from 8-bit Guild, YYZ, and ST Guild I cannot even resolve the address. Also MCRORIES Bates Motel seems down, but this one seems up and down regularly, not sure whats up there.
James
#9 V-Cool OFFLINE
V-Cool
    Star Raider
  • 54 posts
Posted Wed Apr 18, 2018 7:52 PM
[P.S.]
Yes, the ATI command let me know I was connected.
#10 V-Cool OFFLINE
V-Cool
    Star Raider
  • 54 posts
James
Maybe several were down all at once coincidentally.
#11 Nezgar OFFLINE
Nezgar
  • 1,690 posts
Posted Thu Apr 19, 2018 1:27 PM
What do lantronix devices or altirra emulated bbs's do in the case of someone already on the BBS? Thinking it might be possible they just don't respond if 'busy'
#12 Kyle22 OFFLINE
Kyle22
  • 3,899 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Thu Apr 19, 2018 3:04 PM
Have you tried mine?
#13 V-Cool OFFLINE
V-Cool
    Star Raider
  • 54 posts
Posted Thu Apr 19, 2018 4:22 PM
No sir but I will.  Thanks!
#14 Tillek OFFLINE
Tillek
    Dragonstomper
  • 728 posts
Posted Thu Apr 19, 2018 5:06 PM
They just refuse the connection.  (I've been trying to find a way around that for my BBS, but no real time to explore it so far).
#15 Tillek OFFLINE
Tillek
    Dragonstomper
  • 728 posts
Posted Thu Apr 19, 2018 5:08 PM
YYZ and 8Bit Guild are run by the same guy, so something like an internet burp will likely take both down.
ST Guild just needed a reboot I think.  I was able to get on that last night after he reset it.
#16 V-Cool OFFLINE
V-Cool
    Star Raider
  • 54 posts
Posted Fri Apr 20, 2018 7:51 PM
Hey Kyle, just tried and it aborted.  I'm sure I'm doing something wrong.  I go into manual dial and in the case of your site typed, "ATDT telnet://23.25.83.98"  It tries dialing and after a bit, it aborts
#17 Kyle22 OFFLINE
Kyle22
  • 3,899 posts
Posted Sat Apr 21, 2018 8:51 AM
The telnet:// part is to make it a link so it's clickable for some operating systems. Try ATDT 23.25.83.98 and press Return a few times when it connects.
It is on the default telnet port 23. You may need to specify the port depending on your device.
