gilsaluki Posted April 22, 2018 Share Posted April 22, 2018 Question: Can a power supply from the SX212 power the 1030 modem safely? I don't have a PS for the 1030. Sources say the 1030 had its own unique 9VAC/600mA PS. The SX212 is rated at 9VAC/500mA, also can be used with the 2600. The plug is the same. Will I do harm to the 1030 using the SX's PS? Also is there any Dial-up BBSs left to call? Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted April 22, 2018 Share Posted April 22, 2018 Question: Can a power supply from the SX212 power the 1030 modem safely? I don't have a PS for the 1030. Sources say the 1030 had its own unique 9VAC/600mA PS. The SX212 is rated at 9VAC/500mA, also can be used with the 2600. The plug is the same. Will I do harm to the 1030 using the SX's PS? Don't use a 9VAC PS with a 2600. The VCS needs 9VDC. Don't know about the modems but before you try make sure both are AC (or both are DC). Quote Link to comment Share on other sites More sharing options...
Brentarian Posted April 22, 2018 Share Posted April 22, 2018 I'm pretty sure the SX-212 is 9VDC, and is the same as the XEP-80 and 2600 adaptors. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted April 22, 2018 Share Posted April 22, 2018 From the F.A.Q: 9 V DC 500 mA (4.5 W) Atari#CO16353/CA014034/CO10472/CX261 XEP80,SX212,2600 (center positive) 9 V AC 5.4 VA (600 mA) Atari#CO62195/CO17539 1030 So, no, definitely not interchangeable 1 Quote Link to comment Share on other sites More sharing options...
gilsaluki Posted April 22, 2018 Author Share Posted April 22, 2018 Thanks for the info. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted April 22, 2018 Share Posted April 22, 2018 (edited) To make the story complete, in this 9 VDC case: 500 mA = 4.5 W = 4.5 VA 600 mA = 5.4 W = 5.4 VA This is the max. a PS can deliver, so, using a 600 mA PS with a 500 mA device is o.k. The remaining 100 mA is just not used. With a 500 mA PS and a 600 mA device you're 100 mA short. This just works in most cases but isn't recommended for extended use because a PS is a pretty stupid thing and tries to deliver the extra 100 mA anyways with the result that it's getting hotter and the risk it'll just break. Edited April 22, 2018 by Fox-1 / mnx 1 Quote Link to comment Share on other sites More sharing options...
gilsaluki Posted April 23, 2018 Author Share Posted April 23, 2018 Thanks. I have 1030 with no PS. I also cannot find any dial up BBSs, so I guess the point is mute. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted April 23, 2018 Share Posted April 23, 2018 moot Quote Link to comment Share on other sites More sharing options...
gilsaluki Posted April 24, 2018 Author Share Posted April 24, 2018 moot, yeah...that word. Quote Link to comment Share on other sites More sharing options...
