Nebulus/Tower Toppler game
50 replies to this topic
#26 artrag ONLINE
artrag
  • 1,184 posts
Posted Thu May 3, 2018 12:27 AM
It looks awesome already! Probably the 3d effect could even improve by adding a color gradient using reds or blues in oder to make the front face of the tower brighter than the lateral faces
#27 Vorticon OFFLINE
Vorticon
  • 3,495 posts
Posted Thu May 3, 2018 6:29 AM
This version has a background.
I actually got nauseous watching the animation! Did anybody else experience that? I think it has to do with the background being completely tiled instead of just having a few scrolling elements.
#28 mizapf OFFLINE
mizapf
  • 3,470 posts
Posted Thu May 3, 2018 7:28 AM
Kinetosis...
Interestingly, VR headsets now use a kind of tunnel vision when you sweep around ("comfort mode"); the peripheral areas are just gray. Otherwise, your vision system has nothing to cling to, and you start swaying and start feeling dizzy. (I've got a HTC Vive.)
#29 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Sat May 12, 2018 12:54 PM
I haven't done a lot of work on this, but I did add some doors/openings. I also changed the graphics to look more like bricks.
So far it's very simple: a door is added by choosing the right row from a map like this, and copying it to the VDP:
Attached File  temp.png   2.08KB   4 downloads
There is another map for odd rows, and another map for rows without doors. With this technique each row can have only one door.
Pre-defining maps with more than one door would take up too much memory, so additional doors will have to be added on the fly together with platforms, etc. So instead of copying directly to the VDP I have to copy the row to a buffer first where additional objects are added. That's the next step.
#30 artrag ONLINE
artrag
  • 1,184 posts
Posted Sun May 13, 2018 12:40 PM
There has to be a way to store single tiles or transitions between tiles according to the angle of the rotation
It would allow full flexibility in building the map
#31 artrag ONLINE
artrag
  • 1,184 posts
Posted Mon May 14, 2018 12:23 AM
I see about 60 angles in your plot that make the right edge of a door visible from the leftmost to the rightmost side of the tower.
The same holds for its middle black tiles and the left edge. A door slice is 4 tiles.
The door could be coded by a matrix 4x60.
Each row is a tile, each column an angle.
Edited by artrag, Mon May 14, 2018 1:03 AM.
#32 artrag ONLINE
artrag
  • 1,184 posts
Posted Wed May 16, 2018 2:14 PM
I would reduce the height of the blue tiles in background in order to keep the rectangular proportions of the tiles used in the foreground tower
#33 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Thu May 17, 2018 11:22 AM
I'm very, very slowly working towards a version were the doors and platforms are drawn on the tower instead of being predefined.
#34 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Mon May 21, 2018 2:36 AM
Attached File  screenshot.png   4.68KB   2 downloads
This version has platforms, and both platforms and door are drawn programmatically, i.e. without relying on a pre-calculated data. The speed is OK for this demo, but if all platforms were the same width it would be possible to pre-calculate how a platform looks at all angles, which would result in much faster drawing. The 3D look of a platform when it rotates around the edge of the tower could also be improved with this approach.
Edited by Asmusr, Mon May 21, 2018 2:38 AM.
#35 LASooner OFFLINE
LASooner
    Moonsweeper
  • 340 posts
Posted Mon May 21, 2018 11:20 PM
Are you going to create a 3d effect on the edges of the doorways?
#36 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 431 posts
Posted Tue May 22, 2018 5:03 AM
Once again, I think that we will have a great game!
  • RXB likes this
#37 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Tue May 22, 2018 9:07 AM
That's actually a pretty good idea.  :)
#38 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Tue May 22, 2018 9:09 AM
Well, it's not a game yet and I don't know if it ever will.
#39 arcadeshopper OFFLINE
arcadeshopper
  • 4,054 posts
Posted Tue May 22, 2018 10:13 AM
So i ran this on real hw, with a finalgrom99
It runs fine but after a bit it gives a loud beeeeeeeee
https://photos.app.g...P6rn8tykDrMeXy1
Greg
#40 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Tue May 22, 2018 11:41 AM
Greg
Possibly a buffer overrun into the >8400 area.
#41 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Tue May 22, 2018 11:53 AM
Just a thought here.  Is it possible to define a door as a sprite, and you just redefine the sprite for the 3-D effect as you near the edge?
The sprite tracks with the movement/rotation?
Just a thought.
#42 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Tue May 22, 2018 1:33 PM
Just a thought.
The idea is to save the sprites for the player, monsters, and moving platforms.
#43 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Tue May 22, 2018 1:36 PM
The doors could have a simple 3D effect like this:
Attached File  doors.png   770bytes   7 downloads
#44 OX. OFFLINE
OX.
    Dragonstomper
  • 514 posts
Posted Fri Jun 15, 2018 5:21 PM
That simple effect works very good
#45 Asmusr ONLINE
Asmusr
  • 2,996 posts
Posted Fri Jun 15, 2018 11:46 PM
The latest version shows the effect in action.
I'm no longer working on this, but I will probably return to it later.
#46 OX. OFFLINE
OX.
    Dragonstomper
  • 514 posts
Posted Sat Jun 16, 2018 10:43 AM
Shame, I'd love to see it completed.
#47 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 431 posts
Posted Mon Oct 8, 2018 1:33 PM
I'm so sad! This demo is a pure jewel. I would have been so happy to see  a game using this code.
With it, you could make a different game than Nebulus/Tower Toppler. For example, an infinite tower where the player has to go as higher he can to reach something or someone, avoiding obstacles or nasty beasts. I would love to see a sort of Donkey-Kong alike game where steel beams are replaced with this tower.
#48 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Chopper Commander
  • 241 posts
Posted Mon Oct 8, 2018 2:36 PM
Y
Edited by HOME AUTOMATION, Mon Oct 8, 2018 2:36 PM.
#49 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Chopper Commander
  • 241 posts
Posted Mon Oct 8, 2018 2:42 PM
WoW! It,'s CRAZY CLIMBER...
atari2600
#50 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 431 posts
Posted Tue Oct 9, 2018 5:05 AM
I hope not.
What I propose is different than the Crazy Climber game is. Furthermore, and to be frank, I find the Crazy Climber Arcade graphics very confused, near awful.
