AVGCart
529 replies to this topic
#476 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Wed Apr 10, 2019 4:28 PM
Here are two music tracks from the Tempest 2000 soundtrack CD. Now you can listen to them on an A8 with PDM player by FJC and UNO / SIDE / AVG cart...
Attached File  Tempest 2k1 pcm4+4 mono 44270Hz ide pal.zip   7.93MB   26 downloads
Attached File  Tempest 2k1 pcm4+4 stereo 22135Hz ide pal.zip   8.24MB   25 downloads
Attached File  Tempest 2k2 pcm4+4 mono 44270Hz ide pal.zip   9.17MB   26 downloads
Attached File  Tempest 2k2 pcm4+4 stereo 22135Hz ide pal.zip   9.8MB   22 downloads
Edited by CharlieChaplin, Wed Apr 10, 2019 4:29 PM.
#477 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Thu Apr 11, 2019 5:40 PM
Here is "Third Side Of Numen" music track, original length 11 minutes 28 seconds. A video of it can be found e.g. here:  https: // www. youtube.com/watch?v=WQGs23r4ADY
(remove three spaces). Use the PDM player by FJC and  your UNO / SIDE / AVG cart... and remember, I am hard-hearing, so if any of my PDM files sound strange, you know why.
Besides, I do own several thousand original songs (on several hundred original / commercial audio CD's) and have already converted 500 rock + pop songs into the PDM format (all mono + stereo). But I do not want to upload any of them here. Otherwise the record companies may sue Albert and me...
Attached File  Numen (3rd Side) pcm4+4 mono 44270Hz ide pal.zip   23.56MB   27 downloads
Attached File  Numen (3rd Side) pcm4+4 stereo 22135Hz ide pal.zip   25.03MB   25 downloads
Edited by CharlieChaplin, Thu Apr 11, 2019 5:42 PM.
#478 dimfil OFFLINE
dimfil
    Star Raider
  • 61 posts
Posted Fri Apr 12, 2019 8:14 AM
attachicon.gifNumen (3rd Side) pcm4+4 mono 44270Hz ide pal.zip
attachicon.gifNumen (3rd Side) pcm4+4 stereo 22135Hz ide pal.zip
Any link for the pdm player? I found only an "alpha" version, I don't know where to find the latest...
#479 flashjazzcat OFFLINE
flashjazzcat
  • 14,605 posts
Posted Fri Apr 12, 2019 8:24 AM
Then you already found the latest. :)
#480 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Fri Apr 12, 2019 2:29 PM
Here is the SIDE XEX loader for AVG + UNO carts. and the (alpha) PDM-player for AVG + UNO + SIDE. To playback PDM soundfiles (mono only atm), load the SIDE XEX loader first, then load the PDM player, then load the PDM soundfile...
Attached File  pdm.xex   13.01KB   34 downloads
Attached File  SIDEloader_and SDX_v2.zip   226.83KB   33 downloads
#481 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Sat Apr 13, 2019 3:19 AM
Some Atarians from Poland did covers/interpretations of 8Bit sounds with an E-Guitar and/or synthesizers. While some are very recognizable (e.g. Warhawk), others sound quite different and only give you a hint by their filename. So here they are as PDM files...
Attached File  Draconus_by_Franklyn pcm4+4 mono 44270Hz ide pal.zip   8.43MB   22 downloads
Attached File  Keystone_Kapers_by Vangis pcm4+4 mono 44270Hz ide pal.zip   3.17MB   21 downloads
Attached File  Ninja_Commando_by Franklyn pcm4+4 mono 44270Hz ide pal.zip   8.34MB   13 downloads
Attached File  Warhawk_by_Caruso pcm4+4 mono 44270Hz ide pal.zip   9.17MB   22 downloads
Attached File  Zybex_by_Franklyn_8Bit pcm4+4 mono 44270Hz ide pal.zip   18.32MB   19 downloads
#482 luckybuck OFFLINE
luckybuck
  • 1,062 posts
Posted Wed Apr 17, 2019 3:44 PM
What is the max. GB an SD card does have, when using with AVGCART? 32?
#483 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Wed Apr 17, 2019 3:58 PM
Afaik, AVG supports FAT-16 and FAT-32, SD and SD-HC. Think, SD-XC begins with 64GB, so the largest SD card which AVG can use should be 32GB...?!?
My Sandisk Ultra 32GB SD-card works fine with the AVG cartridge... but in a few years we will need devices and firmware that also support SD-XC...
Regarding cluster size, my 16GB and 32GB Sandisk SD cards were originally formatted with 8k clusters, but that limited the playback of PDM files to a maximum of approx. 24MB; downloaded the Sandisk SD-card formatter V4.x (older version for Win XP, there is V5.x for newer Windows versions) and re-formatted them with 32k clusters (there was no option in SD card formatter for cluster size, I simply chose format and when it was done, it displayed the SD card size and the cluster size). After re-formatting I could easily playback PDM files with a length of 30MB and more...
Edited by CharlieChaplin, Wed Apr 17, 2019 4:15 PM.
#484 luckybuck OFFLINE
luckybuck
  • 1,062 posts
Posted Wed Apr 17, 2019 4:58 PM
Thank you very much CharlieChaplin, the SanDisk Ultra 32 GB SD-Card is exactly what I have in mind. :-)))
#485 tmp OFFLINE
tmp
    Chopper Commander
  • 116 posts
Posted Tue May 7, 2019 8:44 AM
I'm wondering, did anyone order those parts for unbricker (esp8266 + cable) and is able to build one? I have an update here that managed to brick one (remote) cart and I need to find out whether it was just a bad luck/british weather that caused it or there's some bigger issue somewhere.
#486 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,707 posts
Posted Tue May 7, 2019 8:50 AM
Our weather is bad but not that bad :)
Yep, twas my cart...I personally just think it was bad luck but tmp has been great...Really nice bloke...Like all our devs and vendors (that I've used), always there to help....Never used FJC but the reports are glowing (didn't want to leave out one of our most known modders / coders / fixers).
Same for all our EU folks..
#487 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,707 posts
Posted Tue May 7, 2019 10:49 AM
A nice by product of this issue is that I had already ordered the parts for the debricker device, but because tmp has kindly posted me one to save a LONG wait it means I'll build a debricker when my parts come, flash it up and it will be available if anyone else had an issue like mine, it could be sort of passed around / pay it on if people want to.
Hopefully no one will need it but it will be there just in case..
#488 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,950 posts
Posted Tue May 7, 2019 12:19 PM
The debricker works a treat, it even rescued a stubborn cart that I have as it refused to get along at all, almost gave up. Gave it repeated tries and then I was able to flash the firmware. Then we flashed it again just to make sure. It was indeed working again.
Edited by _The Doctor__, Tue May 7, 2019 12:19 PM.
#489 lemiel OFFLINE
lemiel
    Moonsweeper
  • 280 posts
Posted Tue May 7, 2019 2:17 PM
I have esp and cable bought especially for AVG cart but didn't use it yet...
#490 tmp OFFLINE
tmp
    Chopper Commander
  • 116 posts
Posted Sun May 12, 2019 3:00 PM
firmware 0015 has some basic joystick support, link is in the first post
#491 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,707 posts
Posted Mon May 13, 2019 10:32 AM
Works great...And a public thank you for your time and excellent help..My cart is good as new....And of course thank you for adding the requested joystick stuff..
#492 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Mon May 13, 2019 12:04 PM
Now, if every A8 hardware could be updated so easily...
- download the firmware update and copy it onto your (AVG) SD-card
- insert SD-card into AVG-cart, then insert AVG-cart into A8
- power on Atari and simply press Shift-Control-U and wait.
Done!
No need to buy a USB-Blaster and most of all, no need to download some sh.... gigabytes of Quartus xyz Software. Listening to some music now...   with my HiFi system (CDA) or the AVG cart (PDM)... :)
Edited by CharlieChaplin, Mon May 13, 2019 12:34 PM.
#493 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,707 posts
Posted Mon May 13, 2019 12:14 PM
Yup, nothing but praise for the cart and the author..
#494 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Mon May 13, 2019 12:55 PM
Hmmm,
in the zip-archive of the update there is a file, named "AVFPlay" (no extender)...?!? What's its purpose ? Threw it into the main/root directory of the SD-card, but it does not show up on the menu, so no clue what's it for. (Simply thrown into the archive, so that CC asks about it?)
Also, after I did the firmware update, AVG menu works with joystick, SIDE XEX-Loader (CAR from december 2018, not updated in the first post?) seems not to work with joystick, whereas PDM-Player (PDM.XEX) works with joystick...?!?
Edited by CharlieChaplin, Mon May 13, 2019 12:59 PM.
#495 eizner23 OFFLINE
eizner23
    Space Invader
  • 11 posts
Posted Mon May 13, 2019 1:04 PM
Is AVGCart still available?
#496 flashjazzcat OFFLINE
flashjazzcat
  • 14,605 posts
Posted Mon May 13, 2019 1:10 PM
The SIDE cartridge's NVRAM is not emulated by the AVG cartridge, so the SIDE loader always presents default settings (since it attempts to read the configuration from the non-existent DS1305 RTC chip, and since the checksum is wrong 100 per cent of the time, it finds the configuration to be invalid and uses the defaults). The PDM player does not save any configuration data at all, meanwhile, and happens to default to 'joystick enabled'.
Have you tried manually enabling the joystick in the SIDE loader? There's no reason why that would not work. If the default setting for the joystick needs to be 'Port 1' instead of 'Disabled', I will consider it.
EDIT: Looks like I already considered it, since the default in the unreleased update is 'Port 1'. ;)
Edited by flashjazzcat, Mon May 13, 2019 1:27 PM.
#497 NuY OFFLINE
NuY
    Chopper Commander
  • 226 posts
Posted Mon May 13, 2019 1:29 PM
I'm down for buying one too if they're still available :)
#498 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Mon May 13, 2019 1:41 PM
No, I did not try it, since the settings of SIDE XEX-loader are not saved/loaded anyways (due to the missing DS1305 RTC chip). But it would be cool if the status of the "unreleased update" would change into a "released update" and then become available for AVG also...  ;-)
Edited by CharlieChaplin, Mon May 13, 2019 1:47 PM.
#499 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Mon May 13, 2019 1:43 PM
Simply write a pm to the author (tmp)... he can tell you more...
#500 flashjazzcat OFFLINE
flashjazzcat
  • 14,605 posts
Posted Mon May 13, 2019 1:57 PM
Despite the fact that settings are not saved, enabling the joystick on a per-session basis will at least allow it to be used for the time being.
Yes: that would be very cool. Unfortunately (or perhaps fortunately), I spent three heavy hours last night frantically fixing a bug in the loader which was usefully uncovered by user skr (to whom thanks are due). I think that when three days have passed without additional features being added (like the support for two additional 'broken' ATR types added the other day) or new bugs being found, then it will be safe to release the update. :D
