AVGCart
452 replies to this topic
#76 Philsan ONLINE
Philsan
  • 3,763 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Wed May 16, 2018 1:56 PM
Attached File  Space Harrier.zip   386.43KB   59 downloads
Thank you!
#77 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Wed May 16, 2018 2:52 PM
i have three versions of space harrier (atarimax 1MB)
Space Harrier (2011-07-05)(Hutt, Chris)(GB)[!].car
Space Harrier (2011-07-05)(Hutt, Chris)(GB)[f for older cartridges Tucker, Steve 2011-07-23][!].car
Space Harrier (2011-08-30)(Hutt, Chris)(GB)[!][optimized].car
first one doesn't work with avgcart, the rest does
i'll put in my todo to check what's different, could be related to the change i did in 0005
- fixed type 42 (Atarimax 1 MB Flash cartridge) (bank is also switched on reads, seems to help with certain carts)
all three versions here - http://avgcart.tmp.s...ace_harrier.rar
Edited by tmp, Wed May 16, 2018 2:53 PM.
#78 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Wed May 16, 2018 6:25 PM
ok, the issue seems to be that the atarimax 1MB should have last bank selected initially which wasn't mentioned in cart.txt i was using as reference
should be fixed in the next firmware update, all three files work now
#79 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Thu May 17, 2018 4:55 AM
So CAR compatibility is now perfect (or near perfect).
Regarding XEX, the best source of files to test is here: http://www.mushca.co...index.php?idx=A
Click Download all.
Homesoft XEX versions are very "clean".
#80 tomsmart1 OFFLINE
tomsmart1
    Space Invader
  • 11 posts
Posted Thu May 17, 2018 9:10 AM
I am interest in 1x AVGCart
Regards,
Thomas
#81 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Thu May 17, 2018 2:51 PM
I am testing homebrew XEX (and some ATR) 64KB games.
8 out of 45 not working so far. If you want I can send you files, now or when I finish this part of testing.
#82 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Thu May 17, 2018 3:03 PM
i expect .atr support to be not really great due to the method used and i don't think there's much that can be done about it
there still might be issues with xex loader so i'm interested in non-working files so i can try to improve that
btw, please try Bomb Jack (320kB) for me, i'm interested whether it loads for you or dies while loading
thanks
#83 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Thu May 17, 2018 3:15 PM
thanks
Crashes after title screen.
#84 IndusGT OFFLINE
IndusGT
    Moonsweeper
  • 396 posts
Posted Thu May 17, 2018 3:20 PM
I'm interested in 2 cards maybe 3 if price is the same. When is next batch coming out?
#85 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Thu May 17, 2018 3:22 PM
great. apparently i'm the only who can't get it to crash
sigh
#86 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Thu May 17, 2018 3:23 PM
I installed an external memory expansion (as written my 800XL with U1MB has problems with AVG Cart) and I just found many >64KB XEXs have problems: Amaroute 128, Bosconian 128, Crownland.
#87 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Thu May 17, 2018 3:28 PM
i don't know, i'm out of pcbs currently, i've ordered some more and meanwhile i'm waiting for more feedback
therefore i'm currently not doing any lists or promising anything to anyone
#88 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Thu May 17, 2018 3:39 PM
so was this 800xl with u1mb? (they work for me on 800xe, i'm trying to find the pattern)
#89 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Fri May 18, 2018 1:12 PM
Considered compatibility issues with my Atari 800XL with U1MB, I am now doing tests with a 130XE.
All CAR games works.
All 128KB homebrew games XEX work.
Now testing XEX 64KB homebrews.
After having tested letters A-C, only these games don't work:
Animal Party
Blah blah
#90 flashjazzcat OFFLINE
flashjazzcat
  • 14,168 posts
Posted Fri May 18, 2018 1:20 PM
If it helps, these latest two in the above ZIP plus the two you sent me last night Phil, work with U1MB when launched from the UNO cart here. So if it's an U1MB problem, it's unique to whatever firmware you have on your board.
#91 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Fri May 18, 2018 1:30 PM
Those games work with my U1MB + Side2 or SIO devices.
They don't work with my U1MB + AVG Cart.
#92 flashjazzcat OFFLINE
flashjazzcat
  • 14,168 posts
Posted Fri May 18, 2018 1:33 PM
OK: I didn't know if the cause of the trouble was uncertain or not. ;)
#93 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Fri May 18, 2018 1:44 PM
last night i found out that the issues with large xex files on xl(?) are most likely caused by timing issues that are somehow amplified when extended memory is in use (as i'm learning, atari timings are basically a suggestion, not really a spec so there's a wide variance mostly due to how crappy sally version one has (if i got that right))
my primary testing machine (800xe) is probably not really suitable as a reference and by trying to fix some visual glitches on it, i most likely made things worse on other machines
i have a firmware version that should help on machines that had issues, i'm just waiting for a feedback that it doesn't break anything too horribly
(if you're brave enough, i can give it to you to test it)
#94 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Fri May 18, 2018 1:53 PM
Homebrew games 64KB XEX letters D-G not working:
Dratewka the Shoemaker
Fairy Castle
Gangsters it's an ATR
The Great Escape
#95 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Fri May 18, 2018 2:06 PM
Blah Blah, Fairy Castle and Great Escape crash for me in altirra so i either have some altirra config problem or there is some issue with them
EDIT: ok, they're not, my bad
Edited by tmp, Fri May 18, 2018 2:12 PM.
#96 flashjazzcat OFFLINE
flashjazzcat
  • 14,168 posts
Posted Fri May 18, 2018 2:11 PM
I think you have a config problem. I just tested everything in Phil's latest archive in Altirra using the SIDE loader and they all work.
#97 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Fri May 18, 2018 2:17 PM
one day Altirra's "Break at EXE Run address" option that somehow reenables (or i keep forgetting i do that myself) will stop fooling me, i promise ;-)
Edited by tmp, Fri May 18, 2018 2:17 PM.
#98 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Fri May 18, 2018 2:22 PM
Homebrew games 64KB XEX letters H-L not working (110 games tested so far):
Heli in the caves
L.E.M.
#99 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Fri May 18, 2018 2:45 PM
Homebrew games 64KB XEX letters M-O not working:
Mazezam
Mental Age
Mini-Slots
Ms. Bulimia
#100 Philsan ONLINE
Philsan
  • 3,763 posts
Posted Fri May 18, 2018 3:13 PM
Homebrew games 64KB XEX letters P-Z not working:
Reaxion
Same Game
Simon!
Sumator
Superfly XL
In few cases menu alphabetic order is not correct (I have 230 games in one folder)
International characters are not allowed (not a big issue)
  • tmp likes this
