SNUG SGCPU Compatible Keyboard
19 replies to this topic
#1 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Sat Apr 28, 2018 2:58 PM
Any SNUG users out there that can tell me what a compatible keyboard will be for this unit.
I have a old XT/AT (switchable) but it does not seem to work on the SGCPU, all the LEDS just flash every few seconds.
#2 mizapf ONLINE
mizapf
  • 3,671 posts
Posted Sat Apr 28, 2018 3:37 PM
The manual (https://www.s-n-u-g....pu/sgcpu_en.pdf) says that you need a MF2 keyboard (11-bit AT code).
#3 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Sat Apr 28, 2018 3:46 PM
I have a HI-TEK AT/XT keyboard model # RT-101.
Not sure if it's a MF2 keyboard.  I would think so if it can be switched between XT and AT.  But not sure.,
#4 FDOS OFFLINE
FDOS
    Moonsweeper
  • 287 posts
Posted Sat Apr 28, 2018 5:02 PM
I have a Key Tronic that has two mode switches.  Auto = off off , PC AT = on on , PC XT = on off
It is in the PC AT mode, and I've only used it for my SNUG TI system, as I have two XT keyboards that came with my two Geneves, and switching modes on the Key Tronic is not easy as a small "snap in" door has to be removed , and the switch itself is a very small 8 switch mechanism that is difficult to operate.  I do believe that it would also work on the Geneves, if necessary.  Not something one would want to do if they were all connected via a KVM (if such a device exists for an AT/XT keyboard).
#5 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Sat Apr 28, 2018 6:00 PM
Happen to have your model # handy?
#6 Ksarul OFFLINE
Ksarul
  • 5,319 posts
Posted Sat Apr 28, 2018 6:01 PM
Note that there is one other possible "gotcha" with the SNUG keyboards. If the original owner wished, Michael would set the keyboard coding for a standard German AT keyboard. If yours does apparently strange things with some keys but works with all others, that may be the source of your problem.
#7 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Tue May 22, 2018 8:06 AM
is this similar or the one you use?
HERE
#8 FDOS OFFLINE
FDOS
    Moonsweeper
  • 287 posts
Posted Wed May 23, 2018 10:36 AM
HERE
Yes, I believe it is it.  I can't quite read the label on the bottom to be absolutely sure.  I just noticed that mine was manufactured in Ireland, not the USA, so probably not identical.  Another difference is the FCC ID: mined is CIG 5E7 E03418 VS CIG 8AV E03417
Edited by FDOS, Wed May 23, 2018 10:47 AM.
#9 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Thu Jun 7, 2018 9:37 PM
i'm having issues finding a compatible keyboard.  I have purchased a couple on ebay and although they work great in XT mode on the Geneve, they are a no go on the SNUG system in AT mode.  Not sure why, i thought all AT keyboards were standard MF2 compatible.
Will a PS/2 keyboard work as I have read those are considered AT keyboards.  Maybe inline with a PS2 to AT adapter?
If anyone has one they are willing to sell me that will work with the SNUG system let me know or point me to one that will work.
Thanks,
Edited by Shift838, Thu Jun 7, 2018 9:41 PM.
#10 acadiel ONLINE
acadiel
  • 1,514 posts
  • www.hexbus.com
Posted Fri Jun 8, 2018 6:23 AM
Thanks,
I actually got a black Compaq PS2 keyboard with an AT keyboard adapter and it worked fine.
Sent from my moto g(6) using Tapatalk
#11 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Fri Jun 8, 2018 4:23 PM
nice.  Can you shoot me the model # and what AT keyboard adapter you are using?
#12 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Fri Jun 8, 2018 9:39 PM
Keyboard like this maybe:  HERE
PS/2 to AT : HERE
#13 acadiel ONLINE
acadiel
  • 1,514 posts
  • www.hexbus.com
Posted Fri Jun 8, 2018 9:43 PM
PS/2 to AT : HERE
Yep, found one like mine on eBay:  https://www.ebay.com...9QAAOSwJjZa80e8
The PS/2 to AT adapter is a regular standard item.
The keyboards come up new on eBay a lot for $5-$10.
#14 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Sat Jun 9, 2018 1:06 PM
thanks.  I purchased one with an PS/2 to AT adapter.  hopefully  it will work, then I can get past Tony's boot menu!
#15 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Sat Jun 9, 2018 9:54 PM
And you are using this on a SNUG SGCPU right?
#16 acadiel ONLINE
acadiel
  • 1,514 posts
  • www.hexbus.com
Posted Sun Jun 10, 2018 6:39 AM
Yes. I have a full SNUG system.
#17 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Tue Jun 12, 2018 5:14 PM
Winner Winner  Chicken Dinner!
Got the keyboard in you recommended ant it works great!
#18 acadiel ONLINE
acadiel
  • 1,514 posts
  • www.hexbus.com
Posted Tue Jun 12, 2018 6:35 PM
Awesome!!! :)
#19 Schmitzi OFFLINE
Schmitzi
  • 4,537 posts
  • ToXiC
Posted Tue Jun 19, 2018 3:08 PM
I am looking for  a HSGPL card. Last thing I miss :sad:
#20 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Tue Jun 19, 2018 4:39 PM
I was lucky and got one with my system.
