160 Pixel Display
40 Characters
10 replies to this topic
#1 Omegamatrix OFFLINE
Omegamatrix
  • 6,218 posts
Posted Sun Apr 29, 2018 9:40 PM
Here is a 160 pixel demo. I confess it does use flicker (a lot!).
I always avoided using lots of flicker, but when I tried it out my LED TV it was surprisingly readible, which is why I'm posting it. In the demo are two rows of text. The bottom row in particular looked okay in my modern TV in its progressive mode.
Here it is. If you are using Stella better ALT-P in Windows to enable phosphor effects. I would be interested in how it looks on real TV's and what sort of TV you have (CRT, Plasma, LED, etc...)
Attached File  160_Pixel_20180429.zip   8.64KB   93 downloads
#2 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,811 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Mon Apr 30, 2018 6:33 AM
Crazy flicker with Stella (ALT-P) and LCD HDTV.
#3 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,549 posts
  • Medieval Mayhem
Posted Mon Apr 30, 2018 8:24 AM
That's painful.
To me on a 1084S, the flicker's better on the top row but the bottom row is easier to read.
You're currently using 4 frames to draw everything, so each set of 8 pixels is drawn on 1 frame out of 4 for 15Hz flicker.
Consider using 6 frames to draw everything where the positions overlap 1/3rd the time.  That would draw each set of 8 pixels on 2 frames out of 6 for 20Hz flicker.
#4 Mr SQL OFFLINE
Mr SQL
  • 2,050 posts
Posted Tue May 1, 2018 1:37 AM
Some modern TV's merge two frames and would render this at 30 HZ.
I tried it on a vintage Television where it flickers tremendously a 15 HZ, but I also find 30 HZ flicker difficult
to look at for reading static text like the Harmony menu.
I find with animation sometimes 30 HZ is clearer for text, the color is an important factor too.
Try using the BW switch to change the animated full screen text display in WARPDRIVE from 30 HZ to 60 HZ and see what you think, it might not change the display on your modern TV but it will on a classic CRT:
Attached File  WARP_DRIVE_PRGE.BIN   8.25KB   59 downloads
#5 ZackAttack OFFLINE
ZackAttack
    Dragonstomper
  • 760 posts
Posted Tue May 1, 2018 9:13 AM
If you take that to the extreme 34.4fps should be possible. That might actually be tolerable.
; Produces a repeating pattern where 31 of 54 pixels can be set (31*60/54)=34.4fps
;[--po0--][--gr1--][--po1--][--gr0--][--gr1--][--gr0--][--po0--][--gr1--][--po1--][--gr0--][--gr1--][--gr0--]
;         ________        00000000 111111100000000 11111111     ________        00000000 111111100000000 11111111
sta RESP0
sta GRP1
sta RESP1
sta GRP0
sta GRP1
sta GRP0
#6 Omegamatrix OFFLINE
Omegamatrix
  • 6,218 posts
Posted Fri May 4, 2018 9:56 PM
I got back to this today, and made a new kernel that flickers at 20Hz, but didn't do any overlap. I haven't been able to test it on real hardware yet.
Attached File  160_Pixel_20180504.zip   4.05KB   70 downloads
There are three rows, and the bottom row should be the clearest. Each row can display all 160 pixels over a few frames (4 for the top two rows, and 3 for the bottom row).
#7 Mr SQL OFFLINE
Mr SQL
  • 2,050 posts
Posted Sat May 5, 2018 1:08 PM
The 20HZ kernel is much better on the bottom line but the 15 HZ kernels on the two lines above make it seem to flicker more than it does.
I think a 96 pixel 30 HZ kernel would be easier to look at, particularly if you do it in blue.
To get more text per line with less pixels you could try a smaller font, this 4x4 is surprisingly clear:
#8 Sheddy OFFLINE
Sheddy
    Dragonstomper
  • 768 posts
Posted Sun May 6, 2018 4:27 AM
Not surprising as it's not all 4x4!
Sure something passable can be done for M, N, V, Q, Y, W, Z. The others work well.
#9 iesposta OFFLINE
iesposta
  • 3,876 posts
  • Retro-gaming w/my VCS
Posted Mon May 14, 2018 11:47 PM
I like the 2x3 at the bottom.
This shows lots, even italic.
#10 iesposta OFFLINE
iesposta
  • 3,876 posts
Posted Tue May 15, 2018 1:47 AM
How is more text per line possible with a 4x4 font when the demo is using a 3x5 font?
#11 Mr SQL OFFLINE
Mr SQL
  • 2,050 posts
Posted Tue May 15, 2018 3:18 AM
I didn't realize it was 3x5.  I took a look at the 36 character demo and there's a pixel between each character, can that be 144 pixels (72 pixels per frame)?
