USB to TI99/4A Keyboard converter by F.G. Kaal
USB-Keyboard Converter Adapter TI-99
14 replies to this topic
#1 Schmitzi OFFLINE
Schmitzi
  • 4,538 posts
  • ToXiC
Posted Tue May 1, 2018 10:17 AM
Fred has something new :lust:
http://www.ti99-geek...a.html#kbti994a
(Main page: http://www.ti99-geek.nl )
#2 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,042 posts
Posted Tue May 1, 2018 10:34 AM
JediMatt42 did a USB keyboard project a couple of years ago.  If I had not already had the wired PS/2 project designed by Tursi installed, I would have gone with Matt's.  I'm happy though, it works great and matches the console.
#3 FDOS OFFLINE
FDOS
    Moonsweeper
  • 288 posts
Posted Tue May 1, 2018 12:27 PM
It looks like a worth while project for someone with a steady hand to take on, as it has Basic mode.  Which means my TI Basic Plus project would not require Microkey or TI Keys. I'm currently using two TI Consoles with Jedimatt42's TI USB device and Microkey (commercial) while I work on TI Keys as replacement.
#4 Schmitzi OFFLINE
Schmitzi
  • 4,538 posts
  • ToXiC
Posted Wed May 9, 2018 2:52 PM
Version 2.0 available.
#5 iKarith OFFLINE
iKarith
    Moonsweeper
  • 351 posts
Posted Thu May 17, 2018 7:11 AM
Thing is, depending on your keyboard model, the TI keyboard may suck in terms of keys it has and doesn't have, but that HP keyboard sucks and is a mushy, gummy mess of a keyboard.  Of course I still like my Alps salmon switch boards the best, but  they don't make them anymore.  :(
#6 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,042 posts
Posted Thu May 17, 2018 7:27 AM
Eh, I get by with my HP PS/2 keyboard and have no problems with it.  The beauty of Matt's USB keyboard adapter is that there is nearly no limit to the number of currently available keyboards.  You could go with a cheap wired keyboard all the way up to an super expensive wireless model with mechanical switches, the choice is yours.
#7 iKarith OFFLINE
iKarith
    Moonsweeper
  • 351 posts
Posted Thu May 17, 2018 10:26 AM
Including the USB version of what you have…
https://www.ebay.com...16/123096086156
#8 FDOS OFFLINE
FDOS
    Moonsweeper
  • 288 posts
Posted Thu May 17, 2018 11:50 AM
Until someone good at new hardware construction ability builds and tests Fred Kaal's new USB keyboard adapter, we just won't know which might be most preferred.  Maybe the one that adds USB/Serial mouse interface first.  We've had several functional serial mouse interface and software for the TI and a buss mouse for the Geneve.  The SNUG TI-99/P has a serial mouse interface also, so a USB/Serial mouse would be very welcome.
#9 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,042 posts
Posted Thu May 17, 2018 1:00 PM
Matt's USB keyboard already exists, as does the mouse driver for the TIPI, which works with TI-Artist, but I understand they are still tweaking the sensitivity levels. At any rate two contemporary devices exist.
#10 Ksarul OFFLINE
Ksarul
  • 5,328 posts
Posted Sun May 20, 2018 9:13 AM
Additional compatible objects are always good, as that allows someone to build the device they are most comfortable with. The real issue comes on the interfacing side: if they all connect transparently to the console and use compatible software hooks for the components that programs can use, then all options are good choices and it boils down to personal preference. That is a really good place to be. . .
#11 jedimatt42 OFFLINE
jedimatt42
  • 2,030 posts
Posted Sun May 20, 2018 9:24 PM
Most people could go make an informed decision by reading. Both USB keyboard adapters have details about features and assembly on their respective websites.
Mice have very little to do with keyboard adapters in the TI space, so I wouldn't ever expect a single device to handle both.
-M@
#12 FDOS OFFLINE
FDOS
    Moonsweeper
  • 288 posts
Posted Mon May 21, 2018 11:38 AM
-M@
However, both of my USB equipped TI-99/4A consoles are connected via USB wireless keyboard/mouse KVM, so it would be nice in my case.  How many others might also think so?
#13 iKarith OFFLINE
iKarith
    Moonsweeper
  • 351 posts
Posted Tue May 22, 2018 12:35 PM
It might be possible to connect a Teensy to TiPi and let you use your KVM that way.  That's a little fiddly for a couple of different reasons though.  For one, you want to be able to use a keyboard on the Pi to control the Pi now and then for debugging and other things.  For another, this would add a lot of cable mess.  The other thing is you'd need to connect TiPi to the AVR sitting inside your console.  This starts to get irritating if you ever want to move the thing.  But it should be doable.
Unless there is a reason Matt can think of why it wouldn't work?  I still don't have a TiPi.  :(  I do now have a 32k! I couldn't get both, and I think Matt's still soldering the next batch of TiPis anyway.
#14 FDOS OFFLINE
FDOS
    Moonsweeper
  • 288 posts
Posted Wed May 23, 2018 10:57 AM
My fingers are very hardware limited, so I won't be using this approach.
#15 iKarith OFFLINE
iKarith
    Moonsweeper
  • 351 posts
Posted Wed May 23, 2018 11:14 PM
That's okay, my wallet is very cash-limited, so I'll be using the built-in keyboard and no TIPI for awhile.
Also tagged with one or more of these keywords: USB-Keyboard, Converter, Adapter, TI-99
