SRL by 8 vs SWPB timing
6 replies to this topic
#1 FarmerPotato OFFLINE
FarmerPotato
    Moonsweeper
  • 313 posts
Posted Thu May 3, 2018 11:02 AM
I have been finding this in ISR code and I am wondering how wasteful it is in cycles? Would someone who knows TMS9900 timing care to analyze it?
All registers are in external RAM (full wait state penalties).
movb  *r8,r8
srl   r8,8
Proposed Optimization:
clr r11
movb *r8,r11
swpb r11
The programmer has RUN OUT of temp registers and is overusing R8, but I see R11 is free.
Thanks in advance!
#2 mizapf ONLINE
mizapf
  • 3,564 posts
Posted Thu May 3, 2018 11:37 AM
On the 9900, SWPB uses 10 clock cycles plus memory cycles, while Shifts use 12+2c cycles with c=shift count, plus memory cycles.
Interestingly, on the 9995, the SWPB uses 13 cycles, while the Shifts use 5+c cycles.
#3 Lee Stewart OFFLINE
Lee Stewart
  • 3,947 posts
Posted Thu May 3, 2018 12:28 PM
Perhaps:
CLR  R11
MOVB *R8,@1(R11)
[Edit: As pointed out later by mizapf and FarmerPotato, the above will not work.  Rather, the address of the current workspace would need to be copied to another register—say, R13—and the offset of the LSB of R11 added:
STWP R13
CLR  R11
MOVB *R8,@23(R13)
Thanks, guys.]   :)
...lee
#4 mizapf ONLINE
mizapf
  • 3,564 posts
Posted Thu May 3, 2018 12:43 PM
Perhaps:
CLR  R11
MOVB *R8,@1(R11)
...lee
That would mean to copy the byte at the address pointed to by R8 to address >0001. Maybe you had a STWP in mind?
#5 Asmusr ONLINE
Asmusr
  • 3,093 posts
Posted Thu May 3, 2018 12:48 PM
With r8 = >a000 and workspace in >8300:
movb *r8,r8                 (26)
srl  r8,8                   (32)
                            (58)
clr  r11                    (14)
movb *r8,r11                (26)
swpb r11                    (14)
                            (54)
clr  r11                    (14)
movb *r8,@>8317             (38)
                            (52)
#6 FarmerPotato OFFLINE
FarmerPotato
    Moonsweeper
  • 313 posts
Posted Thu May 3, 2018 1:08 PM
I can work with that.. There is already a STWP which I can keep around in R13.
STWP R13   this is already paid for
CLR   R11
MOVB *R8,23(R13)    to low byte of R11
Based on Rasmus' cycle counts, this is at best slightly faster.  (Note: registers are in external ram >D844)
I see this code 2 times, so I consider
AI R13,23   point to R11 lsb
Then each time
MOVB *R8,*R13
I can take care that the high byte of R11 will stay 0.
#7 Lee Stewart OFFLINE
Lee Stewart
  • 3,947 posts
Posted Thu May 3, 2018 3:49 PM
That one trips me up a lot.  Obviously, the register in () would need to contain the address of R11—doh!  :dunce:  And—of course, STWP would get the address of R0.  Thanks, mizapf.
...lee
