WOW! Look what I found in a junk 800 - 3Bit Full-View 80 and ?
KLund1
Got a crappy 800 for parts. I opened it up and looks what I found!! Almost gold!
80 card, 16K mod, and an Intac 32K card!!
The 3Bit cables need a bit of cleaning, but overall it looks like it is good condition.
But the ram card has me stumped!! The wire out the top goes to a toggle switch on top of the case. This looks like a pro job mod.
The label reads Copyright 1983, S.C.S.D. Inc
On the back of this card there is a hand written white sticker that reads: Jump Back Board for Intec 32k Mod (use 2nd slot). It is the same hand as the copywrite.
Then there was the order of how the cards were installed. Back to front:
3Bit
16Ram
32K ram
empty (no 10k Rom card!!!)
I have not powered the machine up. It is in not that good of condition. Smells like smoke, and the speaker is rattling around inside.
Any thoughts about the ram card mod, and why no OS card?
  • Like 8
My guess would be that somebody needed the ROM card
so they took it.
Layout you report is NOT right by the Bit 3 diagram.
I'm thinking the directions on the 'jump back board'
are too open to improper interpretations?
S.C.S.D. appears to have owned CSS at one time.
Probably before Bob Puff took over CSS at least that
is what I can gather from an ad for the "Pill" in
a Compute magazine that google hit on. page 60
http://nleaudio.com/css/
Oh look an ad for a new 1050 - only $349!
16K board for the low, low price of $89...
http://www.commodore.ca/gallery/magazines/compute/Compute-043-04.pdf
Back in those days I couldn't even afford a baloney
sandwich for lunch let alone an issue of Compute.
Would be nice to know the numbers off those ram chips
on the 16K S.C.S.D. board, can't read from the picture.
Have my suspicions that the 16K board might be axlon
type ramdisk and the switch on those typically turned
the extended memory off. Never understood really why,
unless they just did that because they could.
You should maybe buy a lottery ticket?
I thought I was lucky when I found a Happy in a
$25 goodwill 1050.
Thanks, couldn't see the far right one at all due to
sticker on it. So normal size ram chip means it's not
an axlon but we have 3 bits used and it's on a Bit 3
machine - hmmm.
S.C.S.D. has perhaps figured out how to turn Bit 3 on
or off with the switch? But only with this 16K ram
board with it's epoxy protection. Just guessing of
course. A good deal before my time too, a lot of
older stuff has left no paper trail on the interwebs.
Here are the front and back of the switched 16K card.
Looks like the switch turns on/off the ram. Possibly used for a hidden ramdisk? Turn on/off extra video ram? Hide the ram from the rest of the system for some reason. Or maybe a way to switch from 40 column ram memory display to 80 column Ram?
Hello KLund1
Could it be a switch to switch in the 4 kB RAM the 800 is missing? Turning it from a 48kB computer into a 52kB computer? IIRC CSS did something similar for "The Impossible" upgrade. Since CSS was related to SCSD...
Sincerely
Mathy
Edited by Mathy
There is only 16K here so no ramdisk is possible, this
was the line of my first inquiry. I was shot down,
did you not see the blood?
Only other suggestion I've got is that S.C.S.D somehow
figured how to package a 40 column machine along with
the 80 column machine by turning off the Bit 3 device
or at the very least misdirecting it back into a 40
column display. If Bit 3 needed extra memory, wouldn't
they have included it on their very expensive board
already instead of rely on someone else to hack their
work?
I see a cut off red wire coming out of the grey epoxy
module that CSS made famous as un-hackable stuff in
there. I see jumpers on the back that often are used
to address strange and new locations probably unique
to Bit 3 alone. Two the 16K ram chips have been covered
up by convenient spillage of more grey epoxy. I suspect
those two to be possibly 64K chips working only for
those two bits that Bit 3 needs at some special address
unique to Bit 3 only.
I would worry about 5% about the red wire cut off and
defeating the use of the board. You still have a Bit 3
and it would work with a standard 16K board anyway. Cut
wire could easily be version 2 of the device modded
this way because of extra talent installed on the back
side as to another jumper added there doing the work
of the red wire now cut off. They made these 100 at a
time, it's likely they sold off early versions where the
red wire was routed to the back side and then they
found it was better to just cut it off and obfuscate
the system entirely by use of new addressing jumper.
In other words I'm thinking it would work as soon as
you put the 16K board into the third slot which is
NOT where you found it.
They already had 'The Pill' in cartridge form to do
the read only ram aspect of faked cart code, they
would not then sell this version doing the same thing.
In my opinion it just toggles the display between 40
and 80 columns. Something that Bit 3 should have done
in the first place but just didn't get around to it?
