Adventure Cartridge and GPL
Adventure GPL F18A
64 replies to this topic
#26 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,161 posts
  • Technology Samurai
Posted Tue May 8, 2018 6:58 PM
How much larger could you load?  I thought the size of a program file you can load is limited by the DSR as it will only load into VDP RAM.  Am I mistaken?
#27 Torrax OFFLINE
Torrax
    Chopper Commander
  • 127 posts
Posted Tue May 8, 2018 8:03 PM
Now that's the style of disassembly output I am more used to!  Do you recall if the source will re-assemble into the cartridge or what programs I would use to attempt it?  If so, I might take my comments and 'merge' them into your files.
Go ahead and use them.  It looks like I used TI99/Sim DUMPGROM for the disassembly and was editing it for Theirry's GPL Assembler.
Here's all my GPL related files.  Two of the included cart images in the Dev zip are usefull for the ADV Editor program.
#28 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Tue May 8, 2018 10:31 PM
The next few weeks may not allow me much if any hobby time.  So here's the current version for those interested in trying it out.
1. The game file title text (not the title screen) is scrolled one extra line, resulting in some missing text on row 22/23.  This is a temporary side effect of the 80 column scroll routine.
2. The save/load options do NOT work properly. I have not had a chance to fix the last few memory locations, in part because I need to address number 3...
3. The largest games, i..e, IRONHEART, are just a few bytes to large for this 80 column version.  This will be fixed if and when I can implement the CALL FILES(1) code.
Anyway, the cart image works with Classic99.  If someone else can convert for use with real hardware, feel free to do so. With luck the the video register settings are right for the F18A and v9938.
Edited by InsaneMultitasker, Tue May 8, 2018 10:31 PM.
#29 Asmusr ONLINE
Asmusr
  • 3,144 posts
Posted Wed May 9, 2018 10:38 AM
I can't get it to work in js99er. It seems to be missing a real cartridge header?
Edit: If you have an E/A#5 file I can convert it to cart in a sec.
Edited by Asmusr, Wed May 9, 2018 10:42 AM.
#30 mizapf OFFLINE
mizapf
  • 3,666 posts
Posted Wed May 9, 2018 11:04 AM
I built a RPK from it, but I found a problem with the screen output. This is running on the emulated TI with EVPC card (9938).
#31 Torrax OFFLINE
Torrax
    Chopper Commander
  • 127 posts
Posted Wed May 9, 2018 1:56 PM
Which GPL assembler did you settle on?
#32 Asmusr ONLINE
Asmusr
  • 3,144 posts
Posted Wed May 9, 2018 2:21 PM
Aah, it's a GROM cart with an E/A#5 header.
#33 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Wed May 9, 2018 2:28 PM
What is the best way to fix that?  I am not sure how the original bin was created, I just used what I could find.
Hmm.  Probably a bit or two set wrong in VR0/1.  Can you check the value in the debugger?  I'll put this on my list.
#34 mizapf OFFLINE
mizapf
  • 3,666 posts
Posted Wed May 9, 2018 3:08 PM
Could that be a wrong VRAM type setting? Not only is the text doubled, but the cursor is blinking at those two locations and adding keystrokes.
#35 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Wed May 9, 2018 5:10 PM
Ah.  Here are the video register settings copied from Classic99's debugger.  The Adventure cartridge is only changing VR0,1, 7.  Seems the TI powerup incorrectly sets some high order bits in the VRs?  I'll need to add a routine to set all registers to a compatible state, and probably should clear VR8-15 to be safe.
VDP0  04      mode
VDP1  F0      mode
VDP2  F0      screen image
VDP3  0E       color-don't care
VDP4  F9       patterns
VDP5  86      sprite-don't care
VDP6  F8      sprite-don't care
VDP7  13     color
#36 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Wed May 9, 2018 5:34 PM
I did all my work with Winhex (sector/byte editor) directly within the cartridge image.  I haven't had a time to look into what you posted, or choose an assembler.  I want to do that when my next free time opportunity arises...
#37 mizapf OFFLINE
mizapf
  • 3,666 posts
Posted Wed May 9, 2018 6:21 PM
...and probably should clear VR8-15 to be safe.
Ehm, no, I would not bet on that. VR8 has the VRAM setting, for instance. I can look up some safe values. Keep in mind that the Text2 mode need not respect any compatibility constraints.
#38 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Wed May 9, 2018 8:08 PM
Good point.  Now that you mention this, I recall a conversation between me and Gazoo regarding a few of these registers. For many of the TI-only (9918 typically) style programs he (and I) often reset the VRs to disable blinking and other sporadic problems when used with the V9938/9958 systems.  I think I first noticed trouble in the GPL program, where I added a few register changes to stop naughty programs from creating random sprites and blinking.  And it may have been an improper VR8 bit that "broke" vdp banking via R14 in programs like Funnelweb.
I will refresh my memory by looking at the V9938 manual and if you have a few safe values, by all means please share. :)
Edited by InsaneMultitasker, Wed May 9, 2018 8:11 PM.
#39 Lee Stewart OFFLINE
Lee Stewart
  • 3,990 posts
Posted Wed May 9, 2018 8:55 PM
Tim, I believe you were the source (via TurboForth) for the values I use in fbForth 2.0 for the VDP registers in Text80 mode:
VR00: >04
VR01: >F0
VR02: >03
VR03: >E8
VR04: >01
VR05: >06
VR06: >01
VR07: >4F
VR08: >88
VR09: >00
VR10: >00
VR11: >00
VR12: >4F
VR13: >10
VR14: >00
...lee
#40 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Wed May 9, 2018 9:33 PM
VR00: >04
VR01: >F0
VR02: >03
VR03: >E8
VR04: >01
VR05: >06
VR06: >01
VR07: >4F
VR08: >88
VR09: >00
VR10: >00
VR11: >00
VR12: >4F
VR13: >10
VR14: >00
...lee
I compared your post with my updates to the GPL interpreter (for the Geneve) and it sets VR8 just as you show above. The color registers are set to disable blinking regardless of the fore/background color, and all the high address bit Vregisters are cleared.  Didn't we have a thread once upon a time where it was recommended to first set V8-V14 then VR0-7, to minimize F18A compatibility issues?  Little fuzzy on this stuff right now.
Oh, you and Michael may have helped track down a related TIMXT problem that Atrax reported. :)
#41 Lee Stewart OFFLINE
Lee Stewart
  • 3,990 posts
Posted Thu May 10, 2018 3:09 AM
Post #403 (and several following) of F18A programming, info, and resources discusses a lot of this.
...lee
#42 mizapf OFFLINE
mizapf
  • 3,666 posts
Posted Thu May 10, 2018 4:58 AM
This is what is written by your Adventure cartridge to the video registers:
* Console startup with EVPC
[:ioport:peb:slot2:evpc:vdp] Write 20 to R#1
[:ioport:peb:slot2:evpc:vdp] Write 70 to R#2
[:ioport:peb:slot2:evpc:vdp] Write 0e to R#3
[:ioport:peb:slot2:evpc:vdp] Write 39 to R#4
[:ioport:peb:slot2:evpc:vdp] Write 86 to R#5
[:ioport:peb:slot2:evpc:vdp] Write 38 to R#6
[:ioport:peb:slot2:evpc:vdp] Write f7 to R#7
[:ioport:peb:slot2:evpc:vdp] Write 00 to R#1
[:ioport:peb:slot2:evpc:vdp] Write 02 to R#14
[:ioport:peb:slot2:evpc:vdp] Write 00 to R#2
[:ioport:peb:slot2:evpc:vdp] Write 01 to R#4
[:ioport:peb:slot2:evpc:vdp] Write 06 to R#5
[:ioport:peb:slot2:evpc:vdp] Write 00 to R#6
[:ioport:peb:slot2:evpc:vdp] Write 08 to R#8
[:ioport:peb:slot2:evpc:vdp] Write 02 to R#9
[:ioport:peb:slot2:evpc:vdp] Write f7 to R#12
[:ioport:peb:slot2:evpc:vdp] Write 00 to R#14
[:ioport:peb:slot2:evpc:vdp] Write 00 to R#9
[:ioport:peb:slot2:evpc:vdp] Write 60 to R#1
* After selecting 2 FOR ADVENTURE 80
[:ioport:peb:slot2:evpc:vdp] Write 70 to R#1
[:ioport:peb:slot2:evpc:vdp] Write 4b to R#7
* After pressing a key, before showing "Where is the data base:"
[:ioport:peb:slot2:evpc:vdp] Write 13 to R#7
* After entering the file name:
* After loading, before showing "Want to restore ..."
[:ioport:peb:slot2:evpc:vdp] Write 04 to R#0
#43 mizapf OFFLINE
mizapf
  • 3,666 posts
Posted Thu May 10, 2018 5:18 AM
The screen contents mirror exactly at >0400.
Here is what MDOS writes when booting has completed:
[:vdp] Write 88 to R#8
[:vdp] Write 20 to R#1
[:vdp] Write 00 to R#0
[:vdp] Write 04 to R#0
[:vdp] Write 30 to R#1
[:vdp] Write 03 to R#2
[:vdp] Write 2f to R#3
[:vdp] Write 02 to R#4
[:vdp] Write 00 to R#14
[:vdp] Write 70 to R#1
[:vdp] Write f4 to R#7
#44 mizapf OFFLINE
mizapf
  • 3,666 posts
Posted Thu May 10, 2018 5:34 AM
VR2 must be set to 03. The rightmost two bits determine the length of the name table as (((m_cont_reg[2] & 3) << 10) | 0x3ff).
#45 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Sun May 20, 2018 12:57 PM
I added GPL code to set VR02 to >03.   One thing I have not considered is the F18A 80 column mode as that might require being cautious with the register order.  I forget whether or not the F18a must be unlocked to enable 80 column mode; if not, then VR8-15 order becomes more important.
I am about out of 'hack' space within this particular GROM cartridge. I probably need to add a second GROM to the cartridge if I have any hope of finishing the changes. My attempts to set CALL FILES(1) via GPL have so far failed. I'll have to play around with this another day...
#46 Ksarul OFFLINE
Ksarul
  • 5,319 posts
Posted Sun May 20, 2018 2:28 PM
Is that lack of hack space in a 6K or an 8K image? Even so, if it needs two GROMs instead of one, that would double your work space and allow you to do almost anything you like. . .
#47 Ksarul OFFLINE
Ksarul
  • 5,319 posts
Posted Sun May 20, 2018 2:31 PM
My evil thought of the day: rewrite the Z-interprter from Infocom in GPL and make a universal Infocom loader like the universal Adventure loader we have today. It was one of those somewhat unique things the TI had BITD--and other systems didn't use an external loader, they built a loader into each adventure game. . .
#48 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Sun May 20, 2018 3:43 PM
The image was dumped as 8k but I am not exceeding the 6k boundary.  If going beyond 6k doesn't really matter "any more" then it would make my life a lot easier, as I could just append my poorly contrived GPL code in that 2k segment.  I really should try to use the source Torrax provided to make a cleaner version but that will have to wait...
#49 mizapf OFFLINE
mizapf
  • 3,666 posts
Posted Sun May 20, 2018 4:04 PM
I think the 6K barrier does not bother anyone anymore. If we burnt GROMs, yes. But anything we are doing now is what I call "gromemu" in MAME, that is, a simulation of GROM. The GROM interpreter obviously does not care that we use 1800-1fff.
#50 Ksarul OFFLINE
Ksarul
  • 5,319 posts
Posted Sun May 20, 2018 5:22 PM
I would expand the rest of the way through the 8K if I were you, as all of the cartridges that would be used to burn a copy of your code can handle 8K GROMs without any issues.
Also tagged with one or more of these keywords: Adventure, GPL, F18A
