ECS Troubleshooting help, please...
21 replies to this topic
#1 lokidchser OFFLINE
lokidchser
    Chopper Commander
  • 156 posts
Posted Mon May 7, 2018 6:08 AM
OK Inty experts, need your help with my "new" ECS that arrived this weekend.  Hooked things up to test, and while the Inty II fired up and worked flawlessly, when I hooked up the ECS, the transformer brick emits a low buzzing sound, and the TV displays only a black screen.  Is this a bad power supply problem ,or couls it be something more advanced?
#2 Porte048 OFFLINE
Porte048
    Chopper Commander
  • 179 posts
Posted Mon May 7, 2018 7:10 AM
I believe an original NES power supply works fine, but I like to have dedicated power supplies.
Here’s an ECS replacement:
https://www.amazon.c...ef_=ya_aw_od_pi
#3 lokidchser OFFLINE
lokidchser
    Chopper Commander
  • 156 posts
Posted Mon May 7, 2018 7:20 AM
Thanks.  I'll try the NES  power supply, just to see if that fixes the problem.  Beyond that, I'll keep my eye out on EBay for an original.
#4 mr_me OFFLINE
mr_me
  • 3,941 posts
Posted Thu May 10, 2018 5:56 AM
Do you have a cartridge plugged in?
#5 jaybird3rd ONLINE
jaybird3rd
  • 9,192 posts
  • "Excuse me, sir? I have a question ..."
Posted Thu May 10, 2018 9:14 AM
I was about to say ... the ECS Computer Adaptor requires a cartridge, even if you only intend to use ECS BASIC.
#6 lokidchser OFFLINE
lokidchser
    Chopper Commander
  • 156 posts
Posted Thu May 10, 2018 11:36 AM
ok, sorry for the delay in responding...checked the ECS with a known working cart, and a nintendo PS, still black screen.  Stupid question, is the supposed to be a 1/4 inch gap between the ECS base unit and the Inty II?  They wont join any closer, and I dont want to force them if the gap is normal.
When i press the reset, i get what looks like digital gibberish, but when i let go, black screen
Edited by lokidchser, Thu May 10, 2018 11:39 AM.
#7 mthompson ONLINE
mthompson
    Dragonstomper
  • 881 posts
Posted Thu May 10, 2018 11:48 AM
Make sure the cartridge port contacts are clean, just like you have to do with the master component. My ECS had a black screen until I worked a cartridge in and out several times to get the oxidation off. I really should clean it properly some day.
#8 lokidchser OFFLINE
lokidchser
    Chopper Commander
  • 156 posts
Posted Thu May 10, 2018 12:29 PM
already cleaned the ports, isopropyl and deyoxit.  gave it one more shot, no dice
Edited by lokidchser, Thu May 10, 2018 12:31 PM.
#9 m-crew OFFLINE
m-crew
  • 5,316 posts
Posted Thu May 10, 2018 12:34 PM
Try connecting a Intellivoice into the ECS and game into that.
#10 Intymike OFFLINE
Intymike
  • 3,354 posts
Posted Thu May 10, 2018 1:13 PM
The Super Nintendo power supply works with the ECS (tested by me). Don't know if it has the same parameters than the NES one.
And a photo how much the Inty II and the ECS are apart.
#11 m-crew OFFLINE
m-crew
  • 5,316 posts
Posted Thu May 10, 2018 1:42 PM
This is the one I use for mine , specs are very close to the original,,,
#12 mthompson ONLINE
mthompson
    Dragonstomper
  • 881 posts
Posted Thu May 10, 2018 1:58 PM
Intymike: Wow, did you squeeze three jacks into that space on your Intv II for your composite mod?
#13 Intymike OFFLINE
Intymike
  • 3,354 posts
Posted Thu May 10, 2018 2:40 PM
I just took a closer look on the power supplies of NES and SNES. And they both have the same characteristics: 9V 1.3A.
#14 Intymike OFFLINE
Intymike
  • 3,354 posts
The guy who did this made a fine work. :)
#15 m-crew OFFLINE
m-crew
  • 5,316 posts
Posted Thu May 10, 2018 3:05 PM
Thanks Mike, that's good to know that both are the same..
#16 lokidchser OFFLINE
lokidchser
    Chopper Commander
  • 156 posts
Posted Thu May 10, 2018 4:45 PM
That did the trick.  Any idea why that would be the solution?
#17 m-crew OFFLINE
m-crew
  • 5,316 posts
Posted Thu May 10, 2018 5:07 PM
That means one of the connections on the ECS need more cleaning..
#18 m-crew OFFLINE
m-crew
  • 5,316 posts
Posted Thu May 10, 2018 5:09 PM
I do that a lot when I take my ECS out because you got to love the train... lol ;)
Im glad it worked and you know your ECS is good...
Cheers
#19 lokidchser OFFLINE
lokidchser
    Chopper Commander
  • 156 posts
Posted Fri May 11, 2018 2:21 PM
OK, got it cleaned enough to work without the Intellivoice module, so all is good there.  However, I HAVE determined that the power supply is faulty.  (works with the NES power supply, not with the ECS one).
Now, here is the latest dilemma...I tend to be a bit anal about completion-ism for these sort of things, so is there anyone here with the knowledge to rebuild/repair the ECS power supply, or has a replacement factory power supply for sale?
#20 nurmix ONLINE
nurmix
  • 1,744 posts
Posted Sat May 12, 2018 9:31 AM
I haven't tried to repair an ECS power supply specifically, but have repaired other types. But most times (including this one), you have to pry/crack open the plastic shell to get at the components, and you'll have a fairly messy looking power supply after that. Here's my one and only US ECS power supply:
Sent from my Keyboard Component using Jack's Conversational Intelli-talk cassette
#21 Intymike OFFLINE
Intymike
  • 3,354 posts
Posted Sat May 12, 2018 9:55 AM
I own two US power supplies. I keep them in good shape.  ;)
#22 lokidchser OFFLINE
lokidchser
    Chopper Commander
  • 156 posts
Posted Sun May 13, 2018 3:40 AM
If you ever want to part with one, let me know
