MiniWriter 3 cart (with novel, integrated parallel interface)
27 replies to this topic
#1 blakespot OFFLINE
blakespot
    Chopper Commander
  • 189 posts
Posted Tue May 8, 2018 8:07 AM
This thing is pretty interesting.
http://www.hexbus.co...ictures.html#16
Does anyone have a photo of this cracked open? Id love to see how its pit together. Can the TI write (output) to the cart port? Hmmm....trying to recall if MiniMemory is a command module or a side attach cart. Maybe the whole bus is exposed on that cart connector.
Im intrigued.
#2 mizapf ONLINE
mizapf
  • 3,484 posts
Posted Tue May 8, 2018 8:33 AM
No, there is only A3-A15 of the address bus, limiting the addressable space to 8K. And the ROMG line is set when the address is between 6000 and 7fff. However, there is no restriction for writing; you can put whatever you want inside that space. Unless you are using a QI console, you even have ports via CRU.
#3 acadiel OFFLINE
acadiel
  • 1,457 posts
  • www.hexbus.com
Posted Tue May 8, 2018 9:19 AM
I know of the following versions:
Miniwriter
Miniwriter II
Miniwriter III
Miniwriter III+
I'd love to know:
1) Differences between these
2) Specs on the cable that was used to hook up to them
I'll see if I can split mine apart to give you some pictures.
#4 sparkdrummer OFFLINE
sparkdrummer
  • 1,013 posts
  • Status? I don't need no stinkin' status!
Posted Tue May 8, 2018 9:32 AM
I've got a couple of those carts as well - I'd like to know what the pin outs are for a printer as well.
#5 Schmitzi OFFLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Tue May 8, 2018 3:16 PM
IIRC, once I saw a " Miniwriter II + " (with PIO-header) on eBay, it went for $13,50
#6 Ksarul OFFLINE
Ksarul
  • 5,030 posts
Posted Tue May 8, 2018 5:03 PM
The "+" variants were supposed to be the ones with the integral printer port, but DataBioTics didn't always use the labels that way (I have seen a lot of the ones without the PIO ports labeled as Miniwriter III+ or Miniwriter II+. I have to double check, but I think I have all four types. The original Miniwriter was a tape/disk for the Mini Memory, not a cartridge. Later iterations from this code base were the Wordwriter, Wordwriter Xtra, and Beyond Wordwriter cartridges. Further development was planned and announced, but never came to pass.
#7 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,320 posts
Posted Tue May 8, 2018 5:21 PM
I am pretty sure I have the source code to one or more versions of this cartridge.  I'll poke around for the disk images and post them (if I find them) when I have time.
#8 acadiel OFFLINE
acadiel
  • 1,457 posts
  • www.hexbus.com
Posted Thu May 10, 2018 9:03 PM
Here’s my Miniwriter III. Label is falling off. :(
#9 acadiel OFFLINE
acadiel
  • 1,457 posts
  • www.hexbus.com
Posted Thu May 10, 2018 9:07 PM
Here’s my III plus
#10 acadiel OFFLINE
acadiel
  • 1,457 posts
  • www.hexbus.com
Posted Thu May 10, 2018 10:10 PM
16 pins connected out of the 20. Probably pretty close to a PBox PIO cable, but need someone to dig out a cable so we can pin out it.
#11 Opry99er OFFLINE
Opry99er
  • 10,392 posts
Posted Fri May 11, 2018 12:57 AM
Wow. I have seen pictures of these carts, but never in this much detail. Thanks for the pics!!
#12 Count9929A OFFLINE
Count9929A
    Star Raider
  • 75 posts
Posted Fri May 11, 2018 4:44 PM
Hi, I have MiniWriter I on tape (original), but I don't have the manual. I have a pdf of the MiniWriterII manual.
 Does anyone know the differences between the two versions?
#13 Ed in SoDak OFFLINE
Ed in SoDak
    Moonsweeper
  • 422 posts
Posted Sat May 12, 2018 12:21 AM
What format are the files? Standard DV/80 such that TI-Writer could load/save them? Or is it some cassette-only format? Still, oughta be a BASIC loader for that. Does the printer only accept output created by Miniwriter or can other programs access the printer through the cart?
In other words, is there any usefullness to them other than the original intended purpose of printing what you just wrote? It would just be a collector cart for most of us unless it had broader uses.
Jes' curious.
-Ed
#14 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,866 posts
  • Technology Samurai
Posted Sat May 12, 2018 8:33 AM
My guess is the printer port is memory-mapped in the cartridge space, something simple.  DBT used CRU bank switching in its cartridges but, with the exception of later models, the circuitry does not look complex enough for that.
#15 blakespot OFFLINE
blakespot
    Chopper Commander
  • 189 posts
Posted Sun May 13, 2018 10:32 AM
Do you imagine that outputting to the printer was writing to that address space and that data was the datastream for the printer? Or do you think somehow reading a certain section of data was what caused the data stream -- where a read access is handled as a signal to output data. Doesn't looks complex enough for me. I guess I'm just coming from the notion that you can't write to the cartridge port. But then, I guess there's MiniMemory, though, right?
bp
#16 Ksarul OFFLINE
Ksarul
  • 5,030 posts
Posted Sun May 13, 2018 12:42 PM
You can definitely write to the cartridge port space. Every single bank-switched cartridge from Extended BASIC on relies on it to initiate a bank switch. It is part of the original hardware specification for the TI.
#17 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,320 posts
Posted Sun May 13, 2018 2:25 PM
If this is indeed the same code, it looks like there is both a read and a write address on the cartridge.
The folder that -should- have contained WordWriter/MiniWriter source is empty but I found a nearly complete set of code from which this excerpt was copied.  I'll have a look through my disks another day, on the off-chance I still have the originals.
Edit:  Read from port:  7ffc;  write to port 7ffe.
Spoiler
Edited by InsaneMultitasker, Sun May 13, 2018 2:26 PM.
#18 Opry99er OFFLINE
Opry99er
  • 10,392 posts
Posted Sun May 13, 2018 2:40 PM
Isn't this the way to re-flash/update the XB2.7 cartridge?
#19 acadiel OFFLINE
acadiel
  • 1,457 posts
  • www.hexbus.com
Posted Tue Jun 5, 2018 8:52 PM
Item #1:  Coming back to this thread.. about making a printer cable, in some circles, I've seen pins 1-16 on the PIO port hooked to pin #1-16 of the Centronics 36 pin connector.  However, I'm not finding a guide on the TI's 16 pin PIO port of how to connect from PIO to the Centronics 36 connector, and which pins need to be omitted or changed.  Attached is a side by side pinout of the Centronics on the left and the TI PIO on the right.
Item #2: The MiniWriter port is 20 pins on the edge card.  But if you look at the last 3 (18-20), they're ground (or positive - I haven't metered it - along with one on the other side).  12 others are connected, and 8 of those are parallel data lines.  That leaves four control lines.  I'm assuming that whomever made the Centronics cable for this wanted to keep it simple, so I'm wondering if we can crowd source the pinout here as well.
Anybody have a #1 they can crack open and trace the pins?  I am aware there were different pins; I probably want an Epson compatible cable if someone has one.  If you have a different brand, it'd be kind of cool to pinout those too just to have them for reference.
Same with #2.  If someone has the cable, I have some 20 pin EDGE connectors (I just need to get some Centronics 36 male IDCs) and some ribbon cable and my crimper.
#20 acadiel OFFLINE
acadiel
  • 1,457 posts
  • www.hexbus.com
Posted Tue Jun 5, 2018 9:02 PM
Actually, XB 2.7 was a bit of a hack, so Tursi's UberGROM recovery won't work.  Best bet is to use an EEPROM programmer to reprogram the 1284P.
#21 Ksarul OFFLINE
Ksarul
  • 5,030 posts
Posted Wed Jun 6, 2018 5:23 AM
IIRC, there was only one printer cable made for these cartridges. I think I may have an original cable for it with one of mine with the printer connector. . .
#22 acadiel OFFLINE
acadiel
  • 1,457 posts
  • www.hexbus.com
Posted Wed Jun 6, 2018 9:48 AM
Cool!  I have some male IDC 36 pin Centronics connectors coming in from China, and got some 20 pin EDGE ones from UXCell on Amazon, and plenty of ribbon cable in a pack... so I can try it out once I get a pinout.
Those Centronics IDC connectors are around $5/ea and the 10 pack of EDGE connectors was $7.50.  Plus ribbon cable.  I can probably make cables for people that have these because I'll have eight of the EDGE IDC's left.  Just would have to order more Centronics ones on demand.
#23 Opry99er OFFLINE
Opry99er
  • 10,392 posts
Posted Wed Jun 6, 2018 5:21 PM
So who wants to do a board run for MiniWriter3? :D
#24 Ksarul OFFLINE
Ksarul
  • 5,030 posts
Posted Wed Jun 6, 2018 5:54 PM
You'd need a copy of the PAL coding to do a board run of these. . .
#25 Opry99er OFFLINE
Opry99er
  • 10,392 posts
Posted Wed Jun 6, 2018 8:36 PM
I was at least partially joking. I think we have little need for this cartridge these days.... but the novelty is pretty high. What a cool piece of history!
