DOS 3.3 Question
14 replies to this topic
#1 polyex OFFLINE
polyex
    Chopper Commander
  • 189 posts
Posted Fri May 11, 2018 2:23 PM
I have started playing with assembling programs in DOS 3.3 using the built in monitor program and had what I assume is a couple of newbie questions.
1) I BSAVE a program at a starting address and end it with a the length. When I BRUN a program how does the command know what address to start at? Where is that stored?
#2 thorr OFFLINE
thorr
    Chopper Commander
  • 163 posts
Posted Fri May 11, 2018 2:27 PM
I think it is an attribute of the saved file.  You can BLOAD it to a different address if I remember correctly, but the default would be wherever it was saved at originally.
#3 polyex OFFLINE
polyex
    Chopper Commander
  • 189 posts
Posted Fri May 11, 2018 2:42 PM
I figured it had to be an attribute saved somewhere, but where?
#4 The Usotsuki OFFLINE
The Usotsuki
  • 2,025 posts
  • Also called "Licca"
Posted Fri May 11, 2018 5:49 PM
First 4 bytes of the B file on disk are the address and length.
#5 polyex OFFLINE
polyex
    Chopper Commander
  • 189 posts
Posted Fri May 11, 2018 6:16 PM
Interesting. When I examine the file with a hex editor the first few bytes are my instructions , not an address/length. The whole file looks to be just instructions.
#6 The Usotsuki OFFLINE
The Usotsuki
  • 2,025 posts
Posted Fri May 11, 2018 7:07 PM
Try looking with a disk editor.
In ProDOS-8, it's filesystem metadata.
#7 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,868 posts
  • Technology Samurai
Posted Mon May 14, 2018 11:43 PM
The hex editor may only be looking at the contents of the file and ignoring the extra bytes.  According to "Beneath Apple DOS" page 4-13 figure 4.8, the four byte header is correct: Address L/H and Length L/H.  As The Usotsuki says, you probably need a disk editor to see the raw underlying DOS information in the file rather than just the data of the file.
#8 youxia OFFLINE
youxia
    Dragonstomper
  • 674 posts
Posted Thu May 17, 2018 7:38 AM
Is there any (easy) way to convert DO to .DSK file format? I'm forced to use Linapple (Retropie) and it only takes .DSK.
Pardon if this is not the right place to ask. But I know zilch about Apple II and the above formats apparently relate to DOS 3.3?
#9 The Usotsuki OFFLINE
The Usotsuki
  • 2,025 posts
Posted Thu May 17, 2018 11:12 AM
Same difference.
#10 polyex OFFLINE
polyex
    Chopper Commander
  • 189 posts
Posted Thu May 17, 2018 1:08 PM
Same difference.
.DO and .DSK are the same?
#11 david__schmidt OFFLINE
david__schmidt
    Chopper Commander
  • 163 posts
Posted Thu May 17, 2018 1:12 PM
"DO" suggests that your image is (already) using DOS sector ordering.  There no change besides renaming to whatever.DSK to make Linapple happy.  By way of background...  DOS sector ordering is the original mapping of physical to logical sectors; sectors 1, 2, 3, etc. are laid out using a skew factor so that they come flying by the read head not in numerical order, but in the order in which DOS is ready to read them. ProDOS changed this order since it always reads two sectors at once, so they're clustered together differently (and due to some code speedups in the core OS, they're skewed differently as well).  If a disk was captured in native ProDOS sector order, it would be correctly suffixed with .PO.  The naming scheme of "DSK" is ambiguous - it could be either ProDOS or DOS sector ordered.  You won't really know unless you inspect it closely and know what to look for; tools like CiderPress and AppleCommander use heuristics to determine which order an image is likely to be.  Most newer emulators automatically make the switch to whatever they need as well.
Edited by david__schmidt, Thu May 17, 2018 1:21 PM.
#12 youxia OFFLINE
youxia
    Dragonstomper
  • 674 posts
Posted Fri May 18, 2018 9:29 PM
That swap trick worked, thanks. But I also have a bunch of files with .PO and .NIB extensions, would it work with these too?
#13 david__schmidt OFFLINE
david__schmidt
    Chopper Commander
  • 163 posts
Posted Fri May 18, 2018 11:02 PM
.PO - maybe.  .NIB - no.  Nibble images are their own thing; either an emulator supports them as-is, or it doesn't.
#14 The Usotsuki OFFLINE
The Usotsuki
  • 2,025 posts
Posted Sat May 19, 2018 1:08 PM
If it doesn't Just Work®™©, 143360 byte PO can be converted fairly trivially to DO (just requires switching the sector order around, I have a tool but it's for DOS and I lost the source years ago).
#15 youxia OFFLINE
youxia
    Dragonstomper
  • 674 posts
Posted Sun May 20, 2018 8:21 PM
Tried it yesterday (po >> dsk) with mixed results: couple of games have worked, couple didn't. May come back to this if I ever find a must-play title that's only .po.
Reply to this topic
