GPL relative branches?
GPL
6 replies to this topic
#1 ralphb OFFLINE
ralphb
    Dragonstomper
  • 599 posts
Posted Mon May 14, 2018 12:18 PM
Maybe I'm still dizzy, but I'm trying to write a small GPL program and for my life cannot figure out how to do relative jumps in GPL, like so:
B  G@2(>8300)
B  G*>8300
B  *>8300
These are invalid syntax, though.  So, what else?  CASE is a bit unwieldy if the value is in the >1000s.
I'm surprised I never noticed before ...
#2 Lee Stewart OFFLINE
Lee Stewart
  • 3,871 posts
Posted Mon May 14, 2018 1:12 PM
I am pretty sure the address must be a direct value.  I do not think you can perform any indirection or indexing.
...lee
#3 ralphb OFFLINE
ralphb
    Dragonstomper
  • 599 posts
Posted Mon May 14, 2018 1:22 PM
So have people figured something out as a workaround?  If it were GRAM, you could put the word for "B" and the target in two consecutive words, and jump to the "B".  But in GROM?
#4 RXB OFFLINE
RXB
  • 3,460 posts
Posted Mon May 14, 2018 1:40 PM
Page 3-7 of the TI GPL Programmers Manual THERE IS NO INDEX ADDRESSING OF GROM/GRAM
You can index RAM or VDP but not GROM/GRAM.
GROM was never written so it could "SELF MODIFY AN ADDRESS"  like Assembly does,
hence no version was ever created to do so.
You can reference:
Ryte Data GPL Assembler
RAG GPL Assembler
Swedish GPL Assembler
TI GPL Assembler
And a couple others but none allow this.
Edited by RXB, Mon May 14, 2018 1:42 PM.
#5 kl99 OFFLINE
kl99
    Dragonstomper
  • 858 posts
Posted Tue May 15, 2018 5:53 AM
Can you calculate the absolute address inside your program and write the result into a Register and use that to branch to?
Isn't the current GROM program location stored in Scratch Pad RAM ?
You could read out that value in your beginning of your program to figure out from which memory location your Gpl is currently executed and calculate the offset from there.
#6 ralphb OFFLINE
ralphb
    Dragonstomper
  • 599 posts
Posted Tue May 15, 2018 9:50 AM
Yes, this is what I'm doing to branch from the FG99 assembly menu to the loaded GROM program.  This works quite well (see FG99 code after the XORG).
I never tried this within GPL, but it could work, even though you're messing with the running GPL interpreter.
#7 kl99 OFFLINE
kl99
    Dragonstomper
  • 858 posts
Posted Wed May 16, 2018 7:50 AM
i hope it works out. also never tried much in GPL so far.
Also tagged with one or more of these keywords: GPL
