How do I create wav files of Atari games for a Supercharger?
6 replies to this topic
#1 Spector OFFLINE
Spector
    Dragonstomper
  • 655 posts
Posted Wed May 16, 2018 1:12 PM
I know that the makewav utility used to do this, but is there a way to create wav files on a modern Windows PC of Atari .bin files so they can be used on an old Cuttle Cart/Supercharger?
#2 tdp OFFLINE
tdp
    Chopper Commander
  • 138 posts
Posted Wed May 16, 2018 1:48 PM
You might findsomething useful here:-
http://atariage.com/...er#entry3855885
http://atariage.com/...nversion-hacks/
#3 7800fan OFFLINE
7800fan
  • 5,555 posts
Posted Wed May 16, 2018 6:18 PM
May need to use DOSBox for them, generally DOS program just won't work under 64 bit Windows, and almost everything in the last 5 years are using 64 bits Windows.
#4 Flojomojo ONLINE
Flojomojo
    Use With Paddle Controllers
  • 13,106 posts
Posted Wed May 16, 2018 6:25 PM
There was a DOS program called BIN2WAV.EXE I used a zillion years ago. You'll definitely need to emulate the old environment. I personally would avoid the hassle and simply seek out the converted files instead. They're probably out there somewhere. Remember that not everything will work on the Supercharger.
#5 Flojomojo ONLINE
Flojomojo
  • 13,106 posts
Posted Wed May 16, 2018 6:27 PM
Also look here
http://atariage.com/...o-pc-via-audio/
#6 tremoloman2006 OFFLINE
tremoloman2006
  • 1,774 posts
Posted Tue May 22, 2018 9:21 AM
I ripped the "Stella Gets a New Brain" CD back in 2011 to MP3.  You can download it by clicking here.
#7 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 5,998 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Tue May 22, 2018 10:13 AM
You can also do something else...
I used to use Winamp back in the day to do this. As you could select the output to be a .wav file and then simply try to open and play the .bin files. As I recall, this used to work but now that I have the harmony I've not tried it in many years.
