Black screen but not TIA problem
6 replies to this topic
#1 Blackgear ONLINE
Blackgear
    Combat Commando
  • 8 posts
Posted Thu May 17, 2018 3:12 PM
Hi all.
My 2nd light sixer, a Sunnyvale this time, arrived at home. It is affected by black screen problem. So I used the psu of the first 2600 I own, which works perfectly.
Nothing changed.
I've put the sunnyvale's TIA on the working 2600.. Black screen on it.
Placed the working 2600 Tia on the Sunnyvale.. Black screen. Sometimes shows colored vertical lines. I've try to Reinsert the CPU and the other chip.. Nothing. The voltage regulator put its 5v on the board, and 5v arrive on the connector of the shielded board too.
Suggestions? May I swap all chips from the working 2600 to the Sunnyvale?
#2 Osgeld OFFLINE
Osgeld
  • 5,080 posts
Posted Thu May 17, 2018 4:26 PM
Yes you can swap my money is on the cup along with the tia
#3 Blackgear ONLINE
Blackgear
    Combat Commando
  • 8 posts
Posted Fri May 18, 2018 12:00 PM
Yes! It works! Only with all chips from the working one
#4 masschamber OFFLINE
masschamber
  • 1,186 posts
Posted Fri May 18, 2018 10:38 PM
I agree with osgeld the cpu is probably bad. I've had quite a few bad cpus in 2600s but no bad tias
#5 Blackgear ONLINE
Blackgear
    Combat Commando
  • 8 posts
Posted Yesterday, 3:21 AM
Can I use chipset from other versions like long/short rainbow?
#6 Osgeld OFFLINE
Osgeld
  • 5,080 posts
Posted Yesterday, 7:52 AM
yes they are all the same for the most part (as long as your not mixing regions on the TIA)
#7 Blackgear ONLINE
Blackgear
    Combat Commando
  • 8 posts
Posted Yesterday, 11:19 PM
Damn, I've see that both junior version have chips soldered directly to the board. These are the cheaper versions of 2600 I can find on ebay
1 user(s) are browsing this forum
1 members, 0 guests, 0 anonymous users
