Altirra Questions
Altirra
3 replies to this topic
#1 Ripdubski OFFLINE
Ripdubski
  • 1,303 posts
Posted Thu May 17, 2018 8:17 PM
1) Is there a way to turn off the "PAUSED" display overlay when the you manually pause the emulator?  When taking screen shots using an external application, the "PAUSED" message is in the way.  Using the save frame makes the image smaller than I want.
2) Is there a way to emulate an Epson FX printer?  I can get text and binary data to the printer window, but would like to have it go to emulated printer like Atari800MacX.  Atari800MacX emulates the epson, and allows the collected output to be saved as a PDF.  I saw another thread about this, but it was older.  If not native, how can I route printer output to a file?
Thanks
Wade
#2 phaeron OFFLINE
phaeron
  • 2,648 posts
Posted Thu May 17, 2018 10:05 PM
Direct way: no.
Cheesy way: stop the emulator using Debug > Run/Stop (F8) instead of Pause (F9).
Nope.
#3 gozar OFFLINE
gozar
    Dragonstomper
  • 952 posts
Posted Fri May 18, 2018 5:37 PM
Direct way: no.
Nope.
Along the same lines, can it be possible to map pause to a controller button?
Sent from my iPad using Tapatalk
#4 Ripdubski OFFLINE
Ripdubski
  • 1,303 posts
Posted Fri May 18, 2018 6:36 PM
I tried F8 to break/run, and that will work for my needs.  Now I just need Epson FX printer emulation.
Also tagged with one or more of these keywords: Altirra
