Disk II Analog Card: What am I Missing?
5 replies to this topic
#1 DistantStar001 OFFLINE
DistantStar001
    Chopper Commander
  • 105 posts
Posted Fri May 18, 2018 12:03 AM
I recently acquired two Apple Disk II drives for my Apple //e.  I was able to determine that both drives work, except one (now drive 2) has a bad analog board (I swapped the boards to make that diagnosis).  When I examined the defective board, I noticed that a chip (74LS125) had a big chunk of it missing.  I've replaced the chip, but there's been no improvement.  I was told that the kind of damage the chip suffered could have been caused by a short, but I couldn't find any.  All the capacitors seem good, and I can't find any broken traces.  I'm kind of at a loss now.  I mean one drive is better than no drive, but I'd like to get both working if I can.  Maybe someone can spot something I missed.  (The first photo pre-repair.Attached File  IMG_0120.jpg   1.45MB   3 downloadsAttached File  IMG_0128.jpg   1.4MB   3 downloadsAttached File  IMG_0131.jpg   1.42MB   3 downloads
#2 trash_44fr OFFLINE
trash_44fr
    Space Invader
  • 34 posts
Posted Sun May 20, 2018 8:17 AM
Hello,
In fact, the LS125 will blow up if it takes 12 Volts instead of 5 which happens when the 20 pin connector is not correctly plugged in the Disk II controller card (ie shifted by one pin).
Since you have one working card, I suggest you tried every single IC of the defective one on it. There is good chance you'll spot more damaged ICs.
Cheers,
Edited by trash_44fr, Sun May 20, 2018 8:18 AM.
#3 Keatah ONLINE
Keatah
    Missile Commander
  • 21,798 posts
Posted Sun May 20, 2018 8:31 AM
Ensure all your connectors and contacts are clean.
#4 DistantStar001 OFFLINE
DistantStar001
    Chopper Commander
  • 105 posts
Posted Sun May 20, 2018 2:16 PM
Good to know, I've actually done that before.
#5 DistantStar001 OFFLINE
DistantStar001
    Chopper Commander
  • 105 posts
Posted Sun May 20, 2018 9:24 PM
Hello,
Cheers,
Thank You Space Invader!  I was able to narrow it down to the chip marked MC3470P Motorola 8045.  Can you believe that someone actually threw these things away for what's likely to be less than $4 in repairs.  Whoever it was kept the Apple II, but couldn't be bothered to fix the drives!?!  I don't get it :-\
#6 Osgeld OFFLINE
Osgeld
  • 5,847 posts
Posted Sun May 20, 2018 9:42 PM
I get atari consoles all the time "broken" that just requires jiggling the power switch ... if people are not going to wiggle a switch they sure are not going to sit down and trace a circuit fault
Reply to this topic
