Anyone have information on this Apple joystick? Which models?
5 replies to this topic
#1 eebuckeye ONLINE
eebuckeye
  • 1,264 posts
Posted Sat May 26, 2018 2:31 PM
It says IBM and Apple compatible so I would 'assume' it works for the Apple IIe, IIc, etc? Can't find anything specifically for this model online..
Thanks!
Attached File  s-l1600.jpg   367.14KB   3 downloads Attached File  s-l1600 (1).jpg   344.75KB   3 downloads
Edited by eebuckeye, Sat May 26, 2018 2:32 PM.
#2 spacecadet OFFLINE
spacecadet
  • 2,983 posts
Posted Sat May 26, 2018 6:40 PM
It's almost definitely a 9 pin connector as on the later Apple II's (IIc, IIc Plus, IIGS), as all of the combo IBM/Apple joysticks that I've personally seen are. Combo joysticks like this generally came out late in the Apple II's lifespan (and far enough into the PC's that it was a viable gaming machine on par with the Apple II), so they generally have the 9 pin plug. The fact that it advertises PC AT support on the box means it's from 1984 at the earliest.
(Edit... aaand now I see the 1993 copyright date. Well, that pretty much confirms to me that it'll be the 9 pin plug.)
Edited by spacecadet, Sat May 26, 2018 6:42 PM.
#3 H454 OFFLINE
H454
    Dragonstomper
  • 518 posts
Posted Sat May 26, 2018 7:00 PM
I seem to remember having one like this. I think It had a switch between apple/PC and a two ends with 9 and 15pin connector. The apples use potentiometers  for the x - y axis.
Having a joystick for the apple II is a huge plus. If you can find one , the CH "style" Joysticks are top notch.
Are you looking to buy this ebay listing?
https://www.ebay.com...58AAOSwvmNbAPhi
If you looking to get a cheap joystick for the apple II, that is a good start.
I had one of these:
https://www.ebay.com...gcAAOSwiMRbCULU
Worked pretty good, kinda bulky. I recommend the CH joystick because they are well built, small and pretty accurate.
#4 eebuckeye ONLINE
eebuckeye
  • 1,264 posts
Posted Sat May 26, 2018 11:36 PM
Thanks!
#5 spacecadet OFFLINE
spacecadet
  • 2,983 posts
Posted Sun May 27, 2018 2:55 PM
Yeah I forgot to mention it'll have the Y cable, but the IBM connector I believe was the same connector up until basically USB, so there's no reason to worry about that. It's only the Apple connector that changed (I think the original was 16 pin, later changed to a more standard DE-9 connector).
I do seem to recall big warnings on my joystick and in my joystick manual to make sure to have the switch set correctly. I think you can potentially do some damage if the switch is set incorrectly.
I have a Suncom combo joystick like this, although I like the design of this one better.
#6 Osgeld OFFLINE
Osgeld
  • 5,918 posts
Posted Sun May 27, 2018 3:02 PM
nah you wont cause damage they both use the same circuit internally, the difference is the resistor (its a single shot 555 timer so to achieve compatibility you just switch in some extra caps to make up the difference tween pc and apple II)
they probably overstate it to help with "but it dont werk, what a load of junk" reactions (it would work but just not right)
Reply to this topic
