hueyjones70 Posted May 27, 2018 Share Posted May 27, 2018 I just tried to make a back-up copy of my MyDos disk. Everything seemed to work fine until I booted with the back up and it erased itself. I tried three more times with the same results. I also tried to make a backup by just copying the files from one disk to another. When I tried to boot with the backup, nothing happened. Am I missing something or is this the standard for MyDos copy protection. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 27, 2018 Share Posted May 27, 2018 Doesn't sound right to me. But to copy a Dos properly you either need to duplicate the entire disk or use whatever option it has that's equivalent to "Write Dos files". Just copying the system files to a blank disk isn't a guarantee for it to work. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted May 27, 2018 Share Posted May 27, 2018 MyDos is shareware and has no copy protection. Even the source code is included in the original releases. Quote Link to comment Share on other sites More sharing options...
Marius Posted May 27, 2018 Share Posted May 27, 2018 What Rybags said... and: It even goes a little further... When you copy a DOS file to a MyDOS partition (even when it is to a sub directory) the disk will not boot again. I consider this a major flaw (since you'll copy entire disks to a directory sometimes, and BAM ... you end up having a corrupted partition... who wants that? indeed nobody...) I would recommend: format a disk, pick WRITE DOS FILES, and see what happens. Quote Link to comment Share on other sites More sharing options...
