FujiConvert 0.1
182 replies to this topic
#76 Stephen OFFLINE
Stephen
  • 7,457 posts
  • A8 Gear Head
Posted Fri Jun 1, 2018 8:24 PM
Hello Stephen
The noise at the end.  If I'm not mistaken CharlieChaplin mentioned it to Xuel via PM and Xuel responded in posting number 71 (last question and answer).
Sincerely
Mathy
Sorry.  I have also experienced this.  It is jarring when the volume is maxed!
#77 Kyle22 ONLINE
Kyle22
  • 3,822 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Sat Jun 2, 2018 6:36 PM
Any Pink Floyd fans here?
#78 Stephen OFFLINE
Stephen
  • 7,457 posts
  • A8 Gear Head
Posted Sun Jun 3, 2018 2:35 PM
Yes - what you want converted?
#79 Mathy OFFLINE
Mathy
  • 2,859 posts
Posted Sun Jun 3, 2018 4:17 PM
Hello Stephen
Don't you wanna wait until Xuel kills the noise?
Sincerely
Mathy
#80 flashjazzcat ONLINE
flashjazzcat
  • 14,315 posts
Posted Sun Jun 3, 2018 4:36 PM
It rather depends on how Kyle intends to play the samples. The IDE player does not suffer from noise at the end of the track.
#81 Stephen OFFLINE
Stephen
  • 7,457 posts
  • A8 Gear Head
Hello Stephen
Sincerely
Mathy
Sure thing - don't want a lot of "bad files" getting out in the wild.
#82 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,013 posts
Posted Sun Jun 3, 2018 5:38 PM
Hello Stephen
Sincerely
Mathy
I say yes, but...
Slade says no, Quiet Riot says no:
#83 Kyle22 ONLINE
Kyle22
  • 3,822 posts
Posted Sun Jun 3, 2018 7:31 PM
Anything would be great, I like mostly all Floyd.
T.I.A.
Edit: I have Incognito and Ultimate SD cart.
Edited by Kyle22, Sun Jun 3, 2018 7:32 PM.
#84 brenski OFFLINE
brenski
  • 1,810 posts
  • How should we f**k off, oh Lord ?
Posted Mon Jun 4, 2018 12:12 AM
yep
Attached File  06. Comfortably Numb pcm44 mono 44270Hz ide pal.zip   12.55MB   49 downloads
#85 brenski OFFLINE
brenski
  • 1,810 posts
Posted Mon Jun 4, 2018 9:49 AM
when trying to run the!cart files from altirra - am getting loads of hiss/distortion - actual audio is also very quiet
toggle button fixes this tho...curious
Edited by brenski, Mon Jun 4, 2018 9:50 AM.
#86 Stephen OFFLINE
Stephen
  • 7,457 posts
  • A8 Gear Head
Posted Mon Jun 4, 2018 9:50 AM
Make sure you are using the latest test version of Altirra.  I believe it was test 27 where a PoKey high-pass option was fixed.
#87 brenski OFFLINE
brenski
  • 1,810 posts
Posted Mon Jun 4, 2018 10:22 AM
Hi Stephen, am on version 3.10 of altirra
are there specific settings that'll eliminate the hiss/distortion?
if i toggle "A" before playback it improves significantly, but there's still some present
#88 flashjazzcat ONLINE
flashjazzcat
  • 14,315 posts
Posted Mon Jun 4, 2018 10:46 AM
Get yourself the latest test build from the Altirra thread Martin.
#89 Stephen OFFLINE
Stephen
  • 7,457 posts
  • A8 Gear Head
Posted Mon Jun 4, 2018 10:53 AM
Don't think so - it's not "crsytal clear" on real hardware either.  It sounds great, but there is some noise present.  I need order a few cables so I can switch between Altirra and my real Atari through my receiver.  I haven't been able to do a good side-by-side comparison yet.
#90 Xuel OFFLINE
Xuel
    Dragonstomper
  • 739 posts
Posted Mon Jun 4, 2018 12:30 PM
This one is long enough that it seems to overwrite the hi/lo tables for me. In Atlirra I can restore the hi/lo tables and truncate playback with the following debugger commands:
fbx 8000 L100 "$A0+(value&$F)"
fbx 8100 L100 "$10+(value/16)"
e 7ffc ff ff ff ff
#91 brenski OFFLINE
brenski
  • 1,810 posts
Posted Tue Jun 5, 2018 9:09 AM
ok another upload
one of my own favourite tunes...with God himself on guitar
Attached File  Rainbow - Since You Been Gone (Album Version) pcm44 mono 44270Hz ide pal.zip   7.34MB   37 downloads
#92 flashjazzcat ONLINE
flashjazzcat
  • 14,315 posts
Posted Tue Jun 5, 2018 11:30 AM
Oh... I'll have to convert "Into the Fire" by Deep Purple MKII and run it with Rapidus. :)
#93 brenski OFFLINE
brenski
  • 1,810 posts
Posted Tue Jun 5, 2018 12:06 PM
i did a the!cart version of
the Cult: She Sells Sanctuary
will do a PDM later and upload - the intro sounds really nice
#94 brenski OFFLINE
brenski
  • 1,810 posts
Posted Tue Jun 5, 2018 12:37 PM
Attached File  09 - She Sells Sanctuary pcm44 mono 44270Hz ide pal.zip   9.26MB   38 downloads
Killers: Runaways
Attached File  02. Runaways pcm44 mono 44270Hz ide pal.zip   8.97MB   37 downloads
#95 brenski OFFLINE
brenski
  • 1,810 posts
Posted Tue Jun 5, 2018 4:23 PM
okay, last three for tonight.
underneath the rock exterior ol' Brenski has an inner soul
first up, IMO the second greatest pop band of the 60s - who, in between great pop and psychedelia managed to show their true soul
Brenski's Small Faces Mix   Attached File  Brenski's Small Faces Mix pcm44 mono 44270Hz ide pal.zip   20.17MB   33 downloads
next up
Brenski's Soul Mix Attached File  Brenski's Soul Mix pcm44 mono 44270Hz ide pal.zip   25MB   33 downloads
finally, from a time when the world was a much more innocent/better place
Brenski's Four Tops vs Foundations Mix Attached File  brenski's four tops vs foundations.mix pcm44 mono 44270Hz ide pal.zip   34.82MB   31 downloads
coming soon: Brenski's Unlikely Rock Reggae Mix  ?
Edited by brenski, Tue Jun 5, 2018 4:24 PM.
#96 rdea6 ONLINE
rdea6
  • 2,777 posts
Posted Tue Jun 5, 2018 7:21 PM
T.I.A.
Kyle,
I have an Incognito also but Jon's PDM.xex will not find any content.
Have you tried to run it yet.
#97 Stephen OFFLINE
Stephen
  • 7,457 posts
  • A8 Gear Head
Posted Tue Jun 5, 2018 7:41 PM
Kyle,
I'm guessing it needs a new build, due to IDE registers being at different locations.
#98 MaPa OFFLINE
MaPa
    Dragonstomper
  • 960 posts
Posted Tue Jun 5, 2018 11:47 PM
Is it possible to run these IDE examples in Altirra? If so, what is needed?
#99 flashjazzcat ONLINE
flashjazzcat
  • 14,315 posts
Posted Tue Jun 5, 2018 11:57 PM
Correct, but PDM was a complete failure on my Incognito 800 owing - presumably - to audio circuit limitations. Did anyone else get the ROM players to work on the 800?
#100 brenski OFFLINE
brenski
  • 1,810 posts
Posted Wed Jun 6, 2018 6:25 AM
i've been trying to follow Jon's instruction...but am getting something wrong.
