FujiConvert 0.1
182 replies to this topic
#126 Mathy OFFLINE
Mathy
  • 2,893 posts
Posted Thu Jun 7, 2018 5:58 PM
Hallo Andreas
As promised:
Attached File  Chi Mai pcm4+4 stereo 32760Hz atarimax pal.zip   385.74KB   35 downloads
Attached File  The Man With The Harmonica pcm4+4 stereo 32760Hz atarimax pal.zip   598.29KB   35 downloads
Sincerely
Mathy
#127 flashjazzcat ONLINE
flashjazzcat
  • 14,427 posts
Posted Thu Jun 7, 2018 6:09 PM
AVG should also handle the PDM player perfectly well, given the positive direction taken with firmware development there. ;)
#128 Mathy OFFLINE
Mathy
  • 2,893 posts
Posted Thu Jun 7, 2018 6:23 PM
Hello guys
Just tried to FujiConvert the theme from James Bond.  Don't know what happened, but the resulting sample sounds way different from the original.  I've just now FujiConverted eight songs.  Seven of them sound just like the original, "James Bond" sounds different.
If anybody is interested to check out what went wrong during FujiConversion, I can send you the original and the sample file.
Sincerely
Mathy
Edited by Mathy, Thu Jun 7, 2018 6:23 PM.
#129 Xuel OFFLINE
Xuel
    Dragonstomper
  • 740 posts
Posted Thu Jun 7, 2018 8:47 PM
Hello guys
Sincerely
Mathy
I'd be interested in taking a look.
#130 Xuel OFFLINE
Xuel
    Dragonstomper
  • 740 posts
Posted Thu Jun 7, 2018 8:53 PM
Hello Xuel
Just tried FujiConvert 0.2.1.  At first I thought I had done something wrong.  But if you press the space bar when asked to press any key, the sample won't play until you hit the space bar again.  Oops.
And could you please add the option to choose between "start over" and "stop" when the end of the sample is reached?
Sincerely
Mathy
Good point. This happened because I added space as a play/pause toggle. I'll fix the keyboard routine so it doesn't think the "any key" keypress is a keydown event for the play routine.
I'll also put a loop/stop toggle on the todo list. And Escape to return to the splash screen.
#131 Mathy OFFLINE
Mathy
  • 2,893 posts
Posted Fri Jun 8, 2018 2:25 PM
Hello Xuel
The mp3 I used is 5.5 MB, the resulting sample is (when zipped) just under 0.9 MB.  How do I get them to you?
Sincerely
Mathy
#132 Stephen ONLINE
Stephen
  • 7,525 posts
  • A8 Gear Head
Posted Fri Jun 8, 2018 3:27 PM
Hello Xuel
Sincerely
Mathy
Fairly sure you can just ZIP them both to a single file, and attach to a post here.
#133 Mathy OFFLINE
Mathy
  • 2,893 posts
Posted Fri Jun 8, 2018 3:30 PM
Hello Stephen
A yes, 6.5 MB should fit inside the 50 MB maximum.   :roll:
Sincerely
Mathy
#134 Mathy OFFLINE
Mathy
  • 2,893 posts
Posted Fri Jun 8, 2018 3:37 PM
Hello Xuel
Attached File  The James Bond Theme.zip   5.7MB   29 downloads
Sincerely
Mathy
#135 Xuel OFFLINE
Xuel
    Dragonstomper
  • 740 posts
Posted Fri Jun 8, 2018 4:04 PM
Hello Xuel
attachicon.gifThe James Bond Theme.zip
Sincerely
Mathy
The only thing I would suggest is reducing the Gain parameter to 1 for this song. This song spends most of the time using the full dynamic range, so by using FujiConvert's default gain of 1.5, you get a lot of clipping. Here it is with Gain set to 1:
Attached File  The James Bond Theme pcm4+4 stereo 32760Hz atarimax pal.zip   850.07KB   38 downloads
#136 Mathy OFFLINE
Mathy
  • 2,893 posts
Posted Fri Jun 8, 2018 4:15 PM
Hello Xuel
Thanks.  It sounds better, but still isn't anything near "perfect".  Would values like 0.9 or 0.8 work?
Sincerely
Mathy
#137 Xuel OFFLINE
Xuel
    Dragonstomper
  • 740 posts
Posted Fri Jun 8, 2018 4:52 PM
Hello Xuel
Sincerely
Mathy
Perhaps. Are you listening on real hardware? It could be that you're hitting the saturation that phaeron described here. Going below unity gain could help in that case.
This song also has a lot of low bass. So perhaps that is interacting badly somehow. The Atari's audio circuit has a high-pass filter to get rid of any DC offset. Maybe it's attenuating the bass.
#138 Mathy OFFLINE
Mathy
  • 2,893 posts
Posted Fri Jun 8, 2018 5:18 PM
Hello Xuel
Yes, real hardware.  I've tried 0.9 and 0.8.  It seems to work.  I'm not sure if it gets better.
Do you have an example of a piece of music that has a lot of bass?
Sincerely
Mathy
#139 phaeron OFFLINE
phaeron
  • 2,698 posts
Posted Fri Jun 8, 2018 11:56 PM
Source wave vs. recorded wave from 130XE. Looks like a combination of noise from hi/lo channels not quite matching up either in time/amplitude and distortion from the output circuitry.
#140 rdea6 OFFLINE
rdea6
  • 2,797 posts
Posted Tue Jun 12, 2018 8:07 AM
Talking about a todo list... I would like to see colored waveforms instead of just the white ish grey ... Either a Rust or a Kelly green.
I don't even know if a color could be added, but since I played the FairyPDM.xex by phaeron I started to wonder.
http://atariage.com/...-pcm/?p=4041309
Edited by rdea6, Tue Jun 12, 2018 8:13 AM.
#141 Stephen ONLINE
Stephen
  • 7,525 posts
  • A8 Gear Head
Posted Tue Jun 12, 2018 11:49 AM
Pretty sure that is possible.  The waveform is just a single PM register, using FF for data (with all DMA turned off).  So I believe by setting the colour register for that player, you can get any single colour you like.
#142 Stephen ONLINE
Stephen
  • 7,525 posts
  • A8 Gear Head
Posted Tue Jun 12, 2018 11:52 AM
Tried another conversion today (been listening to a ton of Jonathan Moffet via youtube).  I'm not pleased with the results.  I tried various gain settings from 0.75 up to 2.0 and there is always a "fuzziness" through the entire song, not just the quiet parts.  It's not clipping.  I am thinking it's a distortion related to the high dynamic range, and the quiet parts will always have this noise.
Attached File  06 - Billie Jean pcm4+4 mono 44270Hz ide pal gain 2.0.zip   11.13MB   27 downloads
Edited by Stephen, Tue Jun 12, 2018 11:52 AM.
#143 Mathy OFFLINE
Mathy
  • 2,893 posts
Posted Tue Jun 12, 2018 5:47 PM
Hello guys
The following sample of a Barry White song mixes high notes (the instruments) with very low notes (Barry's voice):
Attached File  Can't Get Enough Of Your Love, Babe pcm4+4 stereo 32760Hz atarimax pal.zip   625.24KB   35 downloads
Doesn't seem to create any problems.
Sincerely
Mathy
#144 Lastic OFFLINE
Lastic
    Chopper Commander
  • 115 posts
Posted Sat Jun 23, 2018 2:03 AM
Hi folks,
Since the 013 update of the AVG cart, I can now load the SIDE loader and the PDM player to playback PDM files from SD Card.
However I seem to be unable to convert an MP3 to PDM no matter which option I try in FujiConvert.
Options used :
artist:
channels: mono
dither: false
duration: -1
freq: 44270.27027027027
frequency: 44kHz
gain: 1.5
maxsize: 128M
media: ide
method: pcm4+4
offset: 0
period: 37
region: pal
title:
Attached File  07 Wanderlust.mp3   11.85MB   21 downloads
I also tried using sox ( OS X ) to create a RAW file but no luck either in the PDM player , am I using the wrong options ?
sox --no-dither --norm 07\ Wanderlust.mp3 --encoding un --channels 1 --rate 44000 --bits 8 07\ Wanderlust_44000.pdm
If I playback the raw file using play ( OS X ) the output sounds good.
play -e unsigned -t raw -r 44k -b 8 -c 1 07\ Wanderlust_44000.pdm
#145 tmp OFFLINE
tmp
    Chopper Commander
  • 106 posts
Posted Sat Jun 23, 2018 2:36 AM
not sure if that's related but fjc's IDE PDM player has currently file size limitation (due to sector table it builds) so be sure to experiment with shorter tracks first
#146 Lastic OFFLINE
Lastic
    Chopper Commander
  • 115 posts
Posted Sat Jun 23, 2018 4:33 AM
Thanks for the tip , trimmed down the MP3 to 2 minutes and now I'm able to playback the PDM.
Still trying to accomplish the same with sox but using these parameters
sox --no-dither --norm Wanderlust_trimmed.mp3 --type raw --encoding un --channels 1 --rate 44000 --bits 8 Wanderlust_44000.pdmpv
I get a very loud , way too fast (Chipmunk style) PDM.
Anybody has a clue how to convert to IDE PDM format using sox ?
#147 Xuel OFFLINE
Xuel
    Dragonstomper
  • 740 posts
Posted Sat Jun 23, 2018 5:14 PM
You need to interleave the pcm samples in a specific way.
Mono:
http://atariage.com/...-5#entry4032449
Stereo:
http://atariage.com/...-1#entry4037039
#148 _The Doctor__ ONLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,531 posts
Posted Sat Jun 23, 2018 10:32 PM
ugh pal pal pal pal, pow!!!
#149 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,447 posts
Posted Sun Jun 24, 2018 3:35 AM
Gents and ladies. lets not get too carried away after perfection, remember these old machines use hardware not really looking to produce CD quality sound :)
I am awestruck at the quality of the noise coming out of my 130XE and Altirra, its so much better than the stuff from back in the day but its also using resources that we didn't have then or it was in its very infancy (ram upgrades).
Tune away but I saw the words "its not perfect" and I just wanted to remind folk that there's 40yr old design factors in the way :)
It sounds amazing though and I love the vigour from all the folks putting time in to this and I'm proud that its the Atari doing the work, it would be so easy to add a sound producing board but then its not the Atari itself..
#150 Lastic OFFLINE
Lastic
    Chopper Commander
  • 115 posts
Posted Sun Jun 24, 2018 5:49 AM
Mono:
Stereo:
Thanks, I wasn't complety following the technical details so sox is out of the question to do batch-processing, no worries your excellent tool provided what I needed to do some testing.
