FujiConvert 0.1
182 replies to this topic
#176 MrFish OFFLINE
MrFish
  • 5,360 posts
Posted Fri Sep 28, 2018 9:34 AM
OK, the "out of memory" error strongly suggests a memory leak. Closing Firefox and restarting every so often should be sufficient. No need to clear cache as this is purely a RAM issue.
I've been having memory bloat problems with Firefox under Windows 7 for weeks now (months?).
Tired of it; I've dumped Firefox and been using Opera (which is quite nice), until Mozilla gets their act together...
#177 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,014 posts
Posted Mon Oct 1, 2018 6:30 PM
Ha, today I downloaded "SD Formatter 4.0". Okay there is a newer 5.0 version but that one did not work with my old OS (WIN XP 32Bit). The formatter still did not let me choose the cluster size, but it recognized my 16GB SD-card (that had 8k clusters) and formatted it fine with FAT32. When formatting was done, it informed me, that it had used 32k clusters...
So theoretically I should no longer have a 24MB limit for PDM files, but a 96MB limit (enough for most/all sound files)...?!? And if 24MB is enough for soundfiles of a length of up to 8-10 minutes, then 96MB should be enough for soundfiles of a length of up to 32-40 minutes...!?!
Copied the PDM files onto the SD-card again, put the SD-card into the AVG-cart, the AVG-cart. into the A8 and loaded the usual stuff (SIDE XEX loader, then PDM player) and... YES ! The 26MB, 27MB and 30MB soundfiles playback without any problems now, great!
But if anyone knows of an SD-card formatter that works under WIN XP (32 Bit) and lets me freely choose the cluster size, I am all ears...  ;-)
Edited by CharlieChaplin, Mon Oct 1, 2018 6:34 PM.
#178 Kyle22 OFFLINE
Kyle22
  • 3,823 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Mon Oct 1, 2018 9:14 PM
It does install, but refuse to run on my currently updated XP machine. It appears that they did this on purpose.
Shame on them.
I *WILL* keep my eyes open for such a tool.
Edit: MiniTool is coming to mind,  but I am having a hard time finding it without MALWARE attached.
I'll find it eventually.
Edited by Kyle22, Mon Oct 1, 2018 9:51 PM.
#179 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,044 posts
Posted Fri Oct 12, 2018 11:48 PM
So I'm trying to figure this stuff out for the first time, the fujiconvert page seems pretty straight forward, but I'm still confused about the output media types. Is Atarimax output only for the Atarimax 1Mb & 8Mb carts? Or will this work with MyIDE 2 FAT32? Or, alternatively, does the IDE output media work with MyIDE 2 on the HDD side of things? Maybe since I use FJC's SpartaDOS driver for MyIDE 2 I can use the IDE file versions that way? or is this for only SiDE 2 and IDE 2.0?
I've got ONE THE!CART, ONE Atarima 8Mb (doesn't seem like a lot of room for much here) and I have MyIDE 2 with plenty of room on an 8GB CF card. I really don't want to use my only THE!CART to flash just one song file too, and have to reflash for every file, which is apparently the only way. I just got done flashing it for a bunch of software and would rather not go through that again. So, am I just SOL unless I want to reflash my THE!CART for every song file made for it? The best option is MyIDE 2 for me, but from what I can gather, this still isn't supported? Only SIDE or IDE + 2.0?
Edited by Gunstar, Fri Oct 12, 2018 11:52 PM.
#180 flashjazzcat OFFLINE
flashjazzcat
  • 14,325 posts
Posted Sat Oct 13, 2018 1:25 AM
No idea about the cart types: pass.
The IDE files are intended to be used with my PDM Player, which doesn't use drivers of any kind since it must communicate directly with the hardware registers for reasons of speed. The downside to this is that you need a different version of the player for each IDE host adapter. I already released versions for U1MB/SIDE and XEL-CF (1088XEL), but haven't gotten around to making any others yet. Theoretically, the player could work with pretty much any IDE or even SCSI HDD available, given sufficient motivation to actually produce the builds.
There's no player for IDE Plus or MYIDE yet, so unless you have U1MB/SIDE (or a 1088XEL), you'll need to flash THE!CART.
#181 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,044 posts
Posted Sat Oct 13, 2018 3:41 AM
Thanks for the info...I guess I wait on this stuff then...for another build for MyIDE 2 or maybe down the line with SIDE/U1MB...not going to bother constantly reflashing THE!CART for one item at a time, and have to do full reflashes when finished for the normal stuff I want on it. It's just not worth the trouble to me... I MUCH appreciate the reponse JFC! At least it's cleared up for me.
Looks like I'll just have to check it out in an emulator...eventually, maybe... :woozy:
Edited by Gunstar, Sat Oct 13, 2018 3:43 AM.
#182 _The Doctor__ ONLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,234 posts
Posted Sat Oct 13, 2018 1:13 PM
Or see if you can get an AVG cart !
#183 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,014 posts
Posted Sun Oct 14, 2018 8:50 AM
Well,
the SIDE XEX loader (as a CAR file) is required to be loaded first, then the PDM player can be loaded with it. The PDM player works on UNO cart, SIDE/SIDE-2 cart and AVG cart and plays the 8Bit mono sounds (converted with FujiConvert and option set to IDE-player Flashjazzcat) directly from the SD card. The FJC PDM player supports up to 3072 clusters, if your SD-card is formatted with 8k clusters, then sounds with up to 24MB can be played back, if it is formatted with 16k clusters, then sounds with up to 48MB can be played back and if it is formatted with the maximum (?) 32k clusters, then sounds with up to 96MB can be played back with it.
Playback is currently only mono and there is no option yet to pause or cancel playback (return to the menu), but nevertheless playing Megabyte long sounds in 8Bit resolution and full length on a 64k A8 is great ! My 16GB SD-card is filled with approx. 500 converted sounds and I am currently listening to them and writing down which sounds do require a better (with resampling effort = high or ultra) or louder (with gain = 1.5 or 2) conversion with FujiConvert, since I converted them as fast as possible (with resampling effort= none) in the first go...
Edited by CharlieChaplin, Sun Oct 14, 2018 8:53 AM.
