[music] ColecoVision - Ducktales 1987
coleco music source src ducktales theme song
No replies to this topic
#1 newcoleco OFFLINE
newcoleco
  • 1,328 posts
  • Always Tired
Posted Thu May 31, 2018 5:15 PM
DUCKTALES 1987 THEME SONG (All-in-one archive) : Attached File  DUKETALES1987.zip   56.05KB   71 downloads
This archive contains the Ducktales theme song I've composed a few days ago.
This archive is also updated to contain both PAL and NTSC versions, technically making it sounds just fine regardless if you are using the NTSC or PAL ColecoVision game system. WARNING! The music may play at the wrong speed if you are using a modded ColecoVision or an emulator. For example, setting 50Hz on BlueMSX but still using the NTSC ColecoVision BIOS results into a slower theme song.
If you are curious, unzip everything in a single folder, modify one of the ASM source files, and double-click the "compile.bat" file to generate a new ROM file (if the modification is valid).
Anyway, enjoy the new ROM file with all the files to make it.
PS.: I know, I've called the project DUKETALES on my computer... why? I don't know, I just did it that way.
Edited by newcoleco, Thu May 31, 2018 5:20 PM.
Also tagged with one or more of these keywords: coleco, music, source, src, ducktales, theme, song
