Question on DPC+ stack
1 reply to this topic
#1 pacgreg OFFLINE
pacgreg
    Chopper Commander
  • 199 posts
Posted Fri Jun 1, 2018 8:12 PM
If I were to say, pull every variable before using it and pushing it back where it came from every time, would that mean I could use the whole thing as variables?
like pulling out data for an animation to a then putting it away and using a again later in the code to pull out music position and put it away each loop will it always be stored in the same place?
I'm guessing this would look somewhat like this
 dim a = frame
 dim a = duration
mainloop
 ; Animation
 stack 100
 pull frame
 ; (CODE HERE)
 stack 99
 push frame
 ;music
 stack 101
 pull duration
 ; (CODE HERE)
 stack 100
 push duration
 drawscreen
 goto mainloop
Thanks
Greg
#2 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,546 posts
  • Medieval Mayhem
Posted Fri Jun 1, 2018 9:15 PM
You may find this topic useful.
http://atariage.com/...-into-variables
