ianoid Posted June 3, 2018 Share Posted June 3, 2018 Any suggestions how to proceed ? Power supplies are known good. It's a light sixer from 1980. Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted June 3, 2018 Share Posted June 3, 2018 Re-flowing the power connector usually fixes that problem. Quote Link to comment Share on other sites More sharing options...
covertagenda Posted June 3, 2018 Share Posted June 3, 2018 Make sure you have power to the board, then check the voltage regulator. If I remember rightly it has to be over 7 volts in to give you 5 volts out. If you have this then it must be components on the board eg caps etc. Quote Link to comment Share on other sites More sharing options...
ianoid Posted June 4, 2018 Author Share Posted June 4, 2018 Reflow ingredients the power connector didn't help. After I recapped the power/switch board the unit worked! Thanks again people of Atari Age! The cap kit I got from Console 5 came with two square green caps(?) that I couldn't figure out the polarity for(if they have polarity), and the CPU board has four of those so I skipped replacing those. 1 Quote Link to comment Share on other sites More sharing options...
