Questions about the HRD 4000
20 replies to this topic
#1 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Sun Jun 3, 2018 8:38 PM
I recently got an oppurtunity to repair a busted 4000. It appears to work well now with 128K and 512K SRAM. So it looks fixed and all but I cannot for the life of me figure out how to split the card into two different CRU addresses on the TI.
The manual is pretty non specific and vague on this topic.
If anyone out there has this knowledge then please drop in.
#2 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,321 posts
Posted Sun Jun 3, 2018 10:46 PM
Never done it myself as I don't own a 4000.  I played around with one for a short while so I took a look at the attached manual.  See page 13.
The last few sentences of the last paragraph are important for setting the two CRU addresses and how they are tied to each of the two memory segments.   You must have a 32K chip installed in place of the 8k chip, the jumper must be set to 32k.  Use the TI configuration, not Geneve.  Check the position of J2.  Theoretically, by selecting two CRU addresses (watch for the overlap) you'll get two visible for formatting.
#3 Swim OFFLINE
Swim
    Chopper Commander
  • 153 posts
Posted Mon Jun 4, 2018 7:23 AM
This is also done with two 4000's in the same P-Box for a total of 10meg storage. One card populated with 128k chips and a second card populated with 512k chips. My grey matter isn't what it used to be but I think it requires U1 and U2 to be populated with 74HC154 also SW1 must be set for this but I'm working and have nothing in front of me to go by but I think I remember SW1 settings in the 4000 manual.
10 megs of RAM disk is a beautiful thing. :)
#4 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Mon Jun 4, 2018 8:01 AM
Thanks.
TIM...
The card as it sets is pop'd with 128k SRAM and is fully loaded and works.
When I switch in 512k's it still works and I can see 5 meg (I only have 10.)
I can set the jumpers by the paperwork for dual disk operation ( using both flavors of RAM ) but stall out right there. I'm not sure if it is a lingering HW, SW or user issue.
RICH...
When the card arrived the 154's were HCT flavor. I changed those to HC during trouble shooting, fixed the problem on the card ( unrealated to the 154's) and then switched them back. The card worked as before So I figured the extra "T" was OK.
ROS version is 8.14-F
#5 Ksarul OFFLINE
Ksarul
  • 5,030 posts
Posted Mon Jun 4, 2018 9:29 AM
I have a huge supply of the .300 74HCT154s (skinny-DIP). . .they are generally unobtainium lately, but I found a source that would produce and sell them (these are newly manufactured chips from an authorized OEM) for a reasonable price, so I bought some (I think it was something in the vicinity of 1,500 chips as a minimum order, but the price was right, so it was worth it).
#6 atrax27407 OFFLINE
atrax27407
  • 1,182 posts
Posted Mon Jun 4, 2018 10:53 AM
I've got to see your "magic toy shop". There are bound to be chips stacked from floor to ceiling!
#7 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,321 posts
Posted Mon Jun 4, 2018 4:15 PM
Thanks.
TIM...
What happens does it lock up or only show one CRU?  Maybe you have to turn the switch OFF until you run CFG.  You got the 32K jumper set for 32K not 8k, and two CRU selections based on manual.  I was gonna suggest swapping the memory addressing chips to see if one of them has a bad input/output.  If you swap and don't get the 5meg then you have trouble.
#8 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Mon Jun 4, 2018 7:39 PM
With the split memory jumper set I get half the memory displayed. Loads just fine and I can partion disks. This is what makes me think I am missing something. Is there a special CFG program for this card or more likely some dance moves I'm missing ?
#9 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,321 posts
Posted Mon Jun 4, 2018 7:45 PM
Can ya snap a picture or two of the card itself as configured?   (wait two minutes -grin-)
#10 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Mon Jun 4, 2018 8:50 PM
Nope. Can't figure out how to on my phone. Look for an email or text.
#11 Swim OFFLINE
Swim
    Chopper Commander
  • 153 posts
Posted Tue Jun 5, 2018 5:13 AM
You are hitting the "Next" key while in the config program so you set up more than one address right? Each address gets formatted not just one address, right?
#12 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Tue Jun 5, 2018 7:15 AM
That may be the move Richard, thanks.
Do you happen to know if the dip switch needs to have more than one selection ?
#13 Swim OFFLINE
Swim
    Chopper Commander
  • 153 posts
Posted Tue Jun 5, 2018 9:33 AM
Yes, SW1 will have two selected "ON" but unfortunately I'm working and have nothing in front of me to rattle the old grey matter. You will know when SW1 is set right when you are in CONFIG and press the "N" next key because repeated pressing will show what both addresses are.
#14 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,321 posts
Posted Tue Jun 5, 2018 12:41 PM
Sent you a reply to your picture PM with a potential solution.
#15 Swim OFFLINE
Swim
    Chopper Commander
  • 153 posts
Posted Tue Jun 5, 2018 1:20 PM
What's the potential solution?
#16 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Tue Jun 5, 2018 5:46 PM
So thank you Tim and Rich. The card is split and partioned and doing what it is supposed to do ( in TI mode anyway.) I'll spend a couple weeks comparing it to the schematic and send it back to Chris.
For posterity here was the solution.
The DIP switch must be set with two addresses (regardless of the warning in the manual to only set one.)
One of those settings MUST be either SW 2 or SW 4. The other may be one of SW's 1, 3, 6 or 8 but not 2 or 5.
Thank you Tim and Rich for this info and confirmation.
And Rich, Then next function in CFG totally escaped me. I guess I figured the ROS would automagically take care of things. I imagine had I opened the ROS manual the answer would have been right there. Well live and learn and thanks for the kick in the butt 😊.
I understand this card will go in a Geneve as a boot device. I think I know that this limits the boot drive in size. Does this preclude maxing the card to 8 MB ?
#17 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,321 posts
Posted Tue Jun 5, 2018 5:59 PM
MDOS 7.00 contains the routines needed to access the ramdisk as a hard drive and a boot drive.  I haven't finished my work on it though so the best you can do for now is split the RAMdisk into two segments and use CRUs available to MDOS.  There is a problem with disk formats above 800k so using the old FORM v1.23 to prep the ramdisks is preferred.
#18 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Tue Jun 5, 2018 6:12 PM
OK. Does that mean that the boot ramdisk could be 4MEG and have a specifed boot drive @ 800k or does the entire CRU address have to be 800k or less ?
#19 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,321 posts
Posted Tue Jun 5, 2018 6:21 PM
The physical memory can be up to 4mb for each CRU address.  FORM v1.23 will only format up to 800k of the 4MB.   FORM3MEG will format each side up to 3.2MB with the risk of file corruption. Yea, Geneve is a little different in how the disks were implemented back when a small 192K RAMdisk was very expensive.
MDOS 7 resolves this by allowing you to format all 8MB as one large hard drive, minus 400K (or 800K) for a floppy partition used to boot the OS.,
#20 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Tue Jun 5, 2018 7:13 PM
So... For future ref one could pop one CRU with 1meg (512's) and the other with 4meg and it will work as both a boot drive and normal RAM disk.
When 7.0 is completed he could fill in the first side and have his boot drive plus 3meg of tree'd storage.
What would the other side be? Traditional RD or another tree ?
#21 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,321 posts
Posted Tue Jun 5, 2018 10:01 PM
Theoretically the same.  Depends whether or not I can support two CRU addresses in the final release new configuration.  Right now I have two ramdisks in the same system, each with a floppy disk partition and hard drive partition.  The same can be emulated with a 4000 in the dual ramdisk configuration by all accounts.
Edited by InsaneMultitasker, Tue Jun 5, 2018 10:02 PM.
