Miller Graphics Memory Editor
35 replies to this topic
#26 acadiel OFFLINE
acadiel
  • 1,499 posts
  • www.hexbus.com
Posted Fri Jun 8, 2018 9:51 PM
Opry99er, Acadiel posted the production test routines that MG used to run on all new GKs.  I would use that to check out your unit.  It runs through all of the RAM and does an extensive test.  Also, there was a modification that MG put out because some units were prone to losing "bits" of memory when the GK was pulled out of and reinserted into a console with the power on.  It involves a diode, resistor, cap change on the lower board.  That is also posted.
Yep, find the GK archives that I scanned in... the sheet with the 'repair' (just a few components you have to swap out) is in them.  We probably want to get someone like Mainbyte to put it on his page since so many people hit his page.
Also, double check the battery holder.  I was getting intermittent contact; fixed it by bending back the top + metal piece on the holder by pushing it in without a battery.  Between that and replacing the three components, mine seems to retain stuff well now.
If I'm not mistaken, it was the three parts that I circled that I replaced (enlarge the pic to see them - circled in red).
  • RXB likes this
#27 Opry99er OFFLINE
Opry99er
  • 10,679 posts
Posted Sat Jun 9, 2018 12:00 AM
Excellent! Thank you guys very much!
#28 Opry99er OFFLINE
Opry99er
  • 10,679 posts
Posted Sat Jun 9, 2018 12:53 AM
Okay, I was able to get it up and going again, edited the title screen, etc.. It works fine on reset. When the TI power is physically turned off, however, it loses all stored data. I'm going to try to bend the positive terminal down as Jon suggested, and then go from there.
#29 FALCOR4 OFFLINE
FALCOR4
    Star Raider
  • 58 posts
Posted Sat Jun 9, 2018 12:10 PM
When you're done, run the GKTEST (it will pull in GKTESU, GKTESV) file from the GK load module selection.  It will run the GK production software that checks a number of things including all of the volatile memory.  Selection one is the main program. Selection two will check battery function; you must run selection one first then you can remove your GK, reinsert it, reload the program and go to selection two.  Note a couple of things; it will wipe the GK so save your work first.  Selection two will hang on "busy...." after the first switch change unless you have a printer hooked up to your PIO port.  Just do a GK reset if that happens.
It is a bare bones program that doesn't give you much feedback on what it's doing, unless it finds something wrong then it will let you know.  So, no news is good news.  The source files are there if you want to dig into it.
Attached File  DSKA0035.hfe   981KB   4 downloads
#30 Opry99er OFFLINE
Opry99er
  • 10,679 posts
Posted Sat Jun 9, 2018 3:33 PM
Can standard cartridge binary files be loaded directly into the GK, or does one need to add a header of some sort for the GK to recognize it? I had this information at one point, but I can't seem to find it.
#31 FALCOR4 OFFLINE
FALCOR4
    Star Raider
  • 58 posts
Posted Sat Jun 9, 2018 5:33 PM
Well, this is going back a few years.  If memory serves, the GK adds six bytes as a header to the file when you use the "Save Module" function.  1st byte: tag >FF or >00, 2nd byte GROM/ROM number, 3-4 bytes number of bytes to load, 5-6 bytes GROM/ROM address.  Don't hold me to this until I check but I think that's probably it.  Attached are the source files for the GK loader.  Its in GPL and I used the Weiand GPL assembler that Heiner Martin sent me (in German no less!!).  Hope this helps.
Attached File  DSKA0073.hfe   981KB   8 downloads
#32 Opry99er OFFLINE
Opry99er
  • 10,679 posts
Posted Wed Jun 13, 2018 10:44 PM
Bending the positive terminal down seems to have corrected the problem, at least temporarily. It is a very robust and sturdy terminal (and seemed to be making a good connection) so I didn't think it could possibly be the issue, but it seems to have had an effect.
I was able to save GROM0, load GROM0, edit GROM0, INIT module space, load a module, edit a module, etc., and it all seems to have been retained in RAM after power-down.
I tried to re-save the module to disk but it told me I didn't have enough disk space. I attempted to save it as the same name as the module that was re-loaded to avoid any redundancy, but it said I didn't have enough disk space. I'm guessing that the GK is attempting to save the entire 56k of initialized module space and that is why it won't let me save... I don't think I have 56k left on that disk. This would make sense, but I don't understand why it is trying to save 56k of module space when the module itself is only 8k. Perhaps I need to do some more investigating.
In the meantime, here are some pix of my GK.
#33 RickyDean OFFLINE
RickyDean
  • 1,082 posts
Posted Thu Jun 14, 2018 5:47 AM
Maybe the pressure affected a cold solder joint on the positive terminal or something underneath.
#34 acadiel OFFLINE
acadiel
  • 1,499 posts
  • www.hexbus.com
Posted Thu Jun 14, 2018 11:09 AM
If you continue to have retention issues, there's the three components that you can replace to help with it.  :)
#35 Opry99er OFFLINE
Opry99er
  • 10,679 posts
Posted Thu Jun 14, 2018 12:00 PM
Thanks!!! I will do so if this occurs again. This morning, I still had my data in battery backed RAM, so better than the last time already. :)
#36 Opry99er OFFLINE
Opry99er
  • 10,679 posts
Posted Fri Jun 15, 2018 12:45 AM
So far so good!!! Multiple tests tonight included removing the GK from the cart slot, booting into OpSys and then swapping into my custom GROM0.
All worked beautifully!
