Does the TI99/4A have a "Drivewire" type of solution?
6 replies to this topic
#1 AtariLeaf ONLINE
AtariLeaf
    Epic Godlike Canadian
  • 11,311 posts
Posted Sat Jun 9, 2018 9:44 AM
I just picked up a TI99/4A with some joysticks, the voice module and a few carts for $50 yesterday and was wondering if there's a cheap, easy way to get games onto the system similar to the Drivewire solution on the Tandy Coco in that you use a cable or cables to get games from a modern PC to the TI. I'm not interested in collecting for the system, just want to experience some games on real hardware in the most economic way possible.
#2 Lee Stewart OFFLINE
Lee Stewart
  • 3,991 posts
Posted Sat Jun 9, 2018 9:53 AM
A good place to start to assess your options is New to the group? TI-99/4A FAQ, Hardware and software resources READ FIRST!.
...lee
#3 arcadeshopper ONLINE
arcadeshopper
  • 4,405 posts
Posted Sat Jun 9, 2018 10:29 AM
It's called HDX and is detailed in the faq as Lee stated
Sent from my LG-H872 using Tapatalk
#4 chue OFFLINE
chue
    Moonsweeper
  • 373 posts
Posted Sat Jun 9, 2018 10:45 AM
For games, you probably want to take a look at the FinalGrom, which is an SD based multi-cart.  SD is not a wire, but it's not too bad to take it out of the cart and put into a PC.
The FinalGrom is in Lee's link as well.
#5 AtariLeaf ONLINE
AtariLeaf
  • 11,311 posts
Posted Sat Jun 9, 2018 10:52 AM
I'll check those links and options thanks everyone. :)
#6 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,016 posts
Posted Sat Jun 9, 2018 2:52 PM
... just want to experience some games on real hardware in the most economic way possible.
The most economical?
I'd say, if you're good with a soldering iron << THIS 32K MODIFICATION >> by Tursi, coupled with a << FlashROM 99 >>
and a cheap << 99 cent SD card >> from eBay would be the cheapest way to go.
However, the cheapest way is not always the preferred or easiest way.  If I was going to recommend a 'starter package' for a newbie or returning TI'er, I say go with the << FinalGROM 99 >> as it will give you more options, and also get one of JediMatt42's
<< 32K sidecar expansions>>.  This will allow you to keep many options open and you'll be 1/2 way to upgrading if you decide you would like to do that at a later date.
Good luck with whatever you decide!
#7 iKarith OFFLINE
iKarith
    Moonsweeper
  • 351 posts
Posted Sun Jun 10, 2018 6:53 AM
I would second Omega's assessment of the best way to get started.  (Omega!  You're green!)  It gives you most of everything.  You still need a tape recorder simulation for some things like Adventure and Tunnels of Doom, but Matt's 32k gets you well on to a permanent solution to that problem as well.
