Atari 800XL custom bios switch questions
256 colors
I bought a 800XL from eBay with this switch from left to right in 3 positions i get
1st position 64XL with blue ready screen which pass all the tests for ram/sound/keyboard all okay
2nd position i get ether a red or yellow blank screen
3rd position i get black screen with i can type text on too
I'm guessing the switch is for xl/os b/os a in that order am i doing something or does the switch job sound like it's been botched job?
Sounds line a common switch between 2 OS ROM's. Usually between the stock XL OS, and the other for compatibility with 800 OSb.
Sounds like yours has a 3 position switch, where the centre position is not connected. red/yellow screen is a common symptom of a missing/bad OS ROM, which the centre position would simulate.
Inside I expect you would see a 2nd chip soldered on top of the first. With the switches' wires connected to the power pins of each.
I don't immediately recall a particular OS that used a black background. Maybe you could run a utility to dump the OS to a file, and upload here...
Edited by Nezgar
Okay thank you i not able to do any more tests as it's a bare bones setup at the moment with only 800XL/Atari power supply/RF cable/joystick and no software
I've yet to add a 1010 or a 1050 with replacement power supply so I'm quite limited to what i can do
This machine could have a RamrodXL which has sockets for 3 individual OS chips, this upgrade uses a 3-position switch to select the active OS.
