Colecovision Green Screen Problem
TheSolderMonger
Recently I had acquired a Colecovision, and hadn't gotten around to plugging it in because I had no games. Once I got some games and tried to play, the CV's RF output had a green tint, and looked as if I was playing on a GameBoy screen. There was no color, and all the graphics were just various shades of green! I tried to reflow solder on the RF board to no avail, de-soldered and checked the RF board and the components underneath (no difference), cleaned the power switch (which did not work) and even tried poking around the graphics chip and saw absolutely no difference in color whatsoever. I'm at wits end trying to figure out what is wrong with this CV.
Attached below are a couple of pictures from the system on my Trinitron TV. This also came up on a flat screen TV as well.
Any ideas?
I managed to hook up an AV mod to it, and the video only tosses out a blank screen, even with a game plugged in! So I am not sure if the graphics is failing or the my wiring is faulty.
Update: After some corrections on my soldering, I was able to get a color screen (somewhat) however the pad for the video output came off, and soldering a jumper wire and some more soldering caused the green screen to come back. So I think I found the trouble area for the green screen.
the CV is a delicate beast. I'm may not be an electrical engineer, but I would like to think I know my way around a soldering iron pretty well as I use them often at home on my projects and at work.
But the CV is one console I really have to take my time with. I make sure the station is set no hotter than about 320 - 330C else as you saw, the pads tend to left and become one with the solder you are trying to pull.
I would even go so far as to recommend only working on a CV main board if you have a hot air station as that is safer in dealing with the CV and its delicate traces and pads.
Thanks for the advice, I'll take this as a lesson learned and try a lighter tip on the soldering iron and thinner solder.
Also,next time around keep in mind that on the CV RF Modulator there are 2 adjustment screws-1 for audio/1 for screen(fine tune adjustment) this may clear the problem,
on the modulator you will see a third hole to the left it is a fastener only(it does not adjust)
the 2 adjustment screws are basically located top right and bottom left of each other
these are very small hole opening with the adjustment screws inside
See Enclosed Picture Of Colecovision RF Modulator Enclosed With Adjustment Areas
Edited by orrko8791
