Won't Load Game After Sega Logo (Even After New Cart Slot and Re-Cap)
capacitors cartridge slot genesis
3 replies to this topic
#1 baceman007 OFFLINE
baceman007
    Combat Commando
  • 2 posts
Posted Tue Jun 19, 2018 3:25 AM
Hello everyone. I have a Sega Genesis Model 2 (more specifically an mk-1631). It was having problems loading known good games past the Sega Logo. These games load on two other Genesis systems that I have. So:
1. I tried to re-tension the slot. That didn't work, and the carts were still loose, so.
2. I soldered in a new cartridge slot, did a continuity test on all of the pins (it passed) so I tried again. Still, wouldn't pass the Sega screen.
3. I soldered in a new reset button at this point for good measure. The old one had a worn out rubber cap. That works correctly now.
4. So, I tested the capacitors, some were bad, so I re-capped the board. All new capacitors passed a capacitance test and the new connections passed a continuity test. So I tried again. Same issue. Won't pass the Sega screen on known good cartridges.
My question is, what do I do now since, in theory, there isn't a problem with the cartridges, cartridge slot, or capacitors?
#2 Taijigamer OFFLINE
Taijigamer
    Chopper Commander
  • 106 posts
Posted Tue Jun 19, 2018 3:57 AM
Do you have access to an O-scope? Maybe it's a problem with the 7805 regulator or a bad RAM chip.
#3 Jeremy Popp OFFLINE
Jeremy Popp
    Moonsweeper
  • 365 posts
Posted Tue Jun 19, 2018 12:25 PM
Man, that's a lot of effort for a Genesis - for your sake, I hope you get it working.  I've actually repaired 2 model 2 genesis consoles with this issue, and both times it was a bad trace on the motherboard that went to the cartridge slot.  Sounds like you may have already looked that area over, but on both of mine I could see visual proof of some sort of corrosion on the board, and lo and behold one of the traces was bad.  Good luck.
#4 baceman007 OFFLINE
baceman007
    Combat Commando
  • 2 posts
Posted Wed Jun 20, 2018 8:02 PM
Thanks for your reply guys. Very helpful.
Taijigamer, I can get my hands on an O-Scope if need be. It's also on my Christmas list for my new electronics workbench! Yeah!
Jeremy Popp, I took a much closer look at the board and although everything around the slot checks out ok, I found some goop and some black stuff around the SRAM (KM6264BL-10). Alcohol did not work, so I might try Brasso next unless you have any other suggestions. I am hoping the black parts are not breaks in the traces and can be cleaned up. Otherwise, I guess I'm soldering in some SRAM and trying to redo the traces in that area. Here is a pic. The damage I'm talking about is closest to the rest button.
Attached File  20180620_183125.jpg   1.04MB   2 downloads
Also tagged with one or more of these keywords: capacitors, cartridge slot, genesis
