raycasting with Dpc+
7 replies to this topic
#1 Trip2018 OFFLINE
Trip2018
    Star Raider
  • 83 posts
  • young nerd
Posted Wed Jun 20, 2018 10:20 AM
I would like to make a Raycaster for a game i'm working on but all the engines I found didn't work, are in assembly and hard to implement, or just don't suit my needs.
Needs:
 Interactive sprites that move around the map
 doors (windows maybe) and changing walls
 on/off toggle to switch between main game and a screen/menu
what do you think?
I know how to scale sprites and provide layering.
However I'm confused as to how I can accomplish the calculations needed.
Thx. :D
#2 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,295 posts
Posted Wed Jun 20, 2018 2:16 PM
I know in the standard batari BASIC kernels pfpixel commands are "slow".  The 2600 doesn't have a frame-buffer per se to draw those rays.  Not sure if those pfixel commands are present/working in DPC+ anyway.  You're better off waiting for SpiceC so you can offload the calculations onto the ARM.
#3 Trip2018 OFFLINE
Trip2018
    Star Raider
  • 83 posts
  • young nerd
Posted Thu Jun 21, 2018 11:42 AM
I think somewhere on RandomTerrain's bB commands page that dpc+ pfpixel has three arguments, y, x1, x2.
Also, I never heard of SpiceC.
#4 Gemintronic OFFLINE
Gemintronic
  • 9,295 posts
Posted Thu Jun 21, 2018 11:48 AM
SpiceC is an upcoming C compiler for DPC+.  Not out yet.
If pfpixel works for DPC+ then, well.. there you go!  I'd start testing out using that command to plot pixels where you hit a ray.
My hunch is that you need to resort to straight assembly.  There's a game called Merlin's Walls that just barely does it.. and, it has to do it sideways.
#5 Trip2018 OFFLINE
Trip2018
    Star Raider
  • 83 posts
  • young nerd
Posted Thu Jun 21, 2018 3:39 PM
First:
I meant x, y1, y2 :P
Second:
I'm taking some info from this and this
Both require trigonometry and square roots. Is that even achievable in bB (or the 2600 in general)?
#6 ZackAttack OFFLINE
ZackAttack
    Dragonstomper
  • 760 posts
Posted Thu Jun 21, 2018 7:21 PM
I was playing around with ray casting the other day. The algorithm I used was based on this article. The equation with sqrt is simplified so that sqrt is not actually required.
For sin() I just created a lookup table with 128 elements. This is easier than using radians or degrees because a simple bitwise and with $7F will always convert an angle to the proper range. cos() can be accomplished with the same table. You just have to offset by 1/4 rotation before anding with $7F.
vec2 rotate(int direction, vec2 vec)
	f32 s = SineLookup[direction & 0x7f];
	f32 c = SineLookup[((direction + 32) & 0x7f)];
	vec2 v =
		F32Add(F32Mul(c, vec.x), F32Mul(s, vec.y)),
		F32Add(F32Mul(F32Mul(F32(-1), s), vec.x), F32Mul(c, vec.y))
	return v;
#7 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,553 posts
  • Medieval Mayhem
Posted Fri Jun 22, 2018 7:30 AM
Close, for CDF not DPC+ :)
If you might be interested then follow my blog series on SpiceC.  There's just a few entries so far as RL intervened - we learned another definition for TIA (dad's doing much better now) and took a vacation for a road trip to Wisconsin. I'll be returning to work on SpiceC next month.
#8 chewy ONLINE
chewy
    Chopper Commander
  • 107 posts
Posted Sun Dec 16, 2018 6:53 PM
[NON PROGRAMMER TAKING HERE] you know for the amount of raycasting games on the vcs , im suprised we havent yet had a port of 'doom' or the doom-style, as opposed to simple maze style games- recently i got a rom off here that is similar to a doom style game, but with a smaller portion of the screen for viewing, while the rest of the screen is for other things, it looks pretty good though.  but i mean what about a full screen raycasting shooter---
