Disassembly of Astrocade Bally Pin Pinball
Astrocade Bally Arcade Z80 Programming Game Hacking
1 reply to this topic
#1 ballyalley OFFLINE
ballyalley
  • 1,752 posts
Posted Wed Jun 20, 2018 4:06 PM
Last week I began to disassemble the 4KB, 1979 pinball game for the Astrocade called Bally Pin.  The game looks like this:
Today I've reached a point where it's worth sharing.  You can download it here:
http://www.ballyalle...yPinDisassembly
Most of the ROM can be seen in Z80 mnemonics now.  Sure, it's hard to follow, but it beats reading hexadecimal!
This code can be assembled using the Zmac assembler and the Home Video Game Library (HVGLIB.H), which are both available here:
http://www.ballyalle...s/ml_tools.html
I became interested in disassembling this game in May of 2016 when we played Bally Pin in the Astrocade High Score Club, here:
http://atariage.com/...ly-pin-pinball/
The game's manual looks like this:
The game cartridge looks like this:
I'm learning to use the MAME debugger a little better, which makes disassembling the game go a bit faster.  Most of the ROM has been disassembled, but I have not started to follow the game's logic yet.  Although, to a certain extent that isn't true, for it's impossible to disassemble a game without following the logic a little bit.
Today I disassembled the music "scores" used by the on-board ROM's music routines.  By "score" and music, we're actually talking about sound effects.  I hope that tomorrow I can start looking into the graphics of the game.  I'd also like to see if I can follow how the game gets laid out.
If possible, I'd like to add a few well-placed pixels so that the ball doesn't drain.  It would be cheating, sure, but it would make disassembling the game go faster, as I have been playing the game without mixed results.  If I can't prevent the ball from draining, then maybe I can at least add more default balls when the game begins.
As progress continues, I'll post the disassembled source code to BallyAlley.com and mention it here.
Adam
#2 ballyalley OFFLINE
ballyalley
  • 1,752 posts
Posted Sat Jun 23, 2018 2:06 PM
Bally Pin - Changing Initial Number of Balls
I have found where in the cartridge the initial number of balls is set in RAM for Bally Pin.  Normally, you start off with 5 balls.  As far as I can tell, you can't earn any extra balls.  For those who understand Z80 machine language, here is the disassembled and commented code for where the number of "lives" (balls) is set:
$2236  3E05                LD      A,$05            ; Set Initial # of balls
$2238  32CC4F              LD      ($4FCC),A        ; Holds Initial # of balls
If you change the $05 to $09, then you'll get 9 balls to start with at the beginning of the game.  Swell, right?  Not quite.  It turns out that if you only change the starting number of balls then your score is scrambled.  Hey, Bob Ogdon (who programmed the game), that's a nice nod to the cheaters among us!  The score is scrambled because elsewhere in the program, Bob checks if the initial number of balls is 5.  If not, then he screws-up the score; it becomes scrambled (I haven't looked into how he does this yet).  So, you also have to change the check for the initial number of balls:
$2BCD  3ACC4F              LD      A,($4FCC)
$2BD0  FE05                CP      $05      ; Must match initial # of balls
$2BD2  2002                JR      NZ,$2BD6 ;   else the score is messed up!
Here is an example of changing this to nine balls to start with:
$2236  3E09                LD      A,$09            ; Set Initial # of balls
$2BD0  FE09                CP      $09      ; Must match initial # of balls
This works okay.  If you set the initial number of balls to higher than nine, then the displayed number of balls left on the screen is scrambled for two reasons:
  1. The screen space is only meant to hold one digit.
  2. I think that the number of lives is held as a BCD number.  If you put a number in above 99, then the display looks weird on the screen.  I've tried $FF, and it DOES work, but then the number of balls displays looks REALLY weird.
So, what this boils down to is this: in order to change the number of lives, use a hex editor to change memory locations in the ROM file to:
Astrocade ROM Cart ROM Space ($2237) is $0237 = Number of Balls
Astrocade ROM Cart ROM Space ($2BD1) is $0BD1 = Number of Balls
To change it to 99 balls, use this:
Astrocade ROM Cart ROM Space ($2237) is $0237 = $99
Astrocade ROM Cart ROM Space ($2BD1) is $0BD1 = $99
Does this make sense?
Go ahead and try it and then try running your game in the MAME Astrocade emulator.  Let me know if this works for you.
I'm glad that I found this area of RAM so easily, as I am terrible at this game.  I want to get further into the game to check certain parts of the code.
Adam
Also tagged with one or more of these keywords: Astrocade, Bally Arcade, Z80 Programming, Game Hacking
