Would this help for audio
3 replies to this topic
#1 Trip2018 OFFLINE
Trip2018
    Star Raider
  • 92 posts
  • Fuzzy boi
Posted Mon Jun 25, 2018 2:06 PM
I found this on the adafruit website and was wondering if this could be hooked up to a 2600 cart (most likely with battery).
Might order this sometime around.
Edited by Trip2018, Mon Jun 25, 2018 7:41 PM.
#2 DarkCart OFFLINE
DarkCart
    Space Invader
  • 42 posts
Posted Tue Jun 26, 2018 10:41 PM
Well, the first problem with using that board is that it doesn't come with a built-in speaker, meaning you'd either have to connect headphones or somehow shoehorn a speaker into the cartridge as well, further increasing hypothetical costs.
Secondly, unless you just wanted to use it for background music, there is no way to get the 2600 to talk to the board. It would be essentially impossible to dynamically play sound effects using this board, as the 2600 would have no way of telling the board to play sound like it can its own audio chip.
Even if you could somehow magically put the board, a battery, and some form of speaker inside a 2600 cart and it not look awful, and somehow magically convince the 2600 to address a component some 40 years newer than itself, then the third problem arises: What would you use it for?
The only kind of music that would feel appropriate to play while playing such primitive games would be some form of chiptune music, but if that's all you're going to do you probably could've accomplished that without the expensive audio components inside. Anything newer would sound out of place.
In the end, your'e no better off than when you started, and you essentially made the cartridge cost $20+ extra for no real benefit in the end.
#3 Trip2018 OFFLINE
Trip2018
    Star Raider
  • 92 posts
  • Fuzzy boi
Posted Wed Jun 27, 2018 9:26 AM
Ok. Just thought it would be more memory saving than storing pcm audio in a rom. Might work pluged into the controller port as sorta like a flashable version of an atari vox.
#4 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Mon Jul 2, 2018 4:36 PM
Of course it's possible for the 2600 to talk to a device in a cartridge. You would just need the proper support circuitry. Still not necessarily worth the effort, though.
