SOUND distorted on Atari 400 RF.
6 replies to this topic
#1 seastalker OFFLINE
seastalker
    Chopper Commander
  • 145 posts
Posted Fri Jul 6, 2018 1:17 PM
I have ebay converters that make a 1999 CRT tv accept the RF adapter output of older systems like the Atari 400. My recent 400 purchase showed me RF video fine with internal speaker working and all keyboard buttons working beautifully.  The audio however is very buzzy and thought someone here may know some tests or grounding.  Down the road I may look into the mods to bring this up to 2018 standards but first wish to test and troubleshoot it in its natural state.
#2 DrVenkman ONLINE
DrVenkman
  • 3,239 posts
  • Back off, man! I'm a scientist.
Posted Sat Jul 7, 2018 6:42 AM
A video would really help to diagnose problems, but audio buzzing is often a ground loop. Try to use either the same household circuit to plug everything in, or different ones, in order to see if that might be part of the issue.
If that doesn't make a difference, unplug the Atari, spray some electrical contact cleaner into the channel select slide switch on the 400 and then cycle it vigorously about a half dozen times, then wait a few minutes for the cleaner to dry. Sometimes those switches get corrosion or dirt inside them and cause glitches in the signal.
If it's not either of these things, you're probably gonna have to open things up to take a look. Of course, this presumes your RF converter isn't the cause of the issue. Not sure if you're referring to a physical demodulator box or just an RCA-to-COAX adapter that lets you attach the RF signal to the CABLE/ANT input on your TV. Some more details on the equipment might help figure out what's going on as well.
Anyway, if you take it apart, I strongly suggest you hit up AtariMania or Archive.org and download the Atari 400-800 Service Manual or the SAM'S COMPUTERFACTS. Both of them have troubleshooting steps, schematics and diagrams, etc.
Good luck!
#3 mytek OFFLINE
mytek
  • 2,769 posts
Posted Mon Jul 9, 2018 2:40 PM
Unlike the pre-digital tuner days of CRT televisions, modern sets would expect the RF output to be on frequency, and generally don't provide a means to fine tune like the older sets could. And if my memory serves me right, if you are slightly off freq you might still see a picture, but the sound will be not so great. After 30+ years it wouldn't surprise me if the 400's modulator tuning has drifted, and may require readjustment. as to how best to do that... never done it myself, so not sure what the procedure would be.
#4 _The Doctor__ OFFLINE
_The Doctor__
  • 4,303 posts
Posted Mon Jul 9, 2018 3:17 PM
you can tune them but you need the old nylon alignment tools and a scope.....
#5 Nezgar ONLINE
Nezgar
    Dragonstomper
  • 860 posts
Posted Mon Jul 9, 2018 9:20 PM
Is there adjustment pots on the 400 RF modulator? I've seen those on the XL modulator recently, but I've never adjusted them myself to say what they do...
#6 _The Doctor__ OFFLINE
_The Doctor__
  • 4,303 posts
Posted Tue Jul 10, 2018 1:04 AM
trimmers and coils, twists and spreads....
#7 seastalker OFFLINE
seastalker
    Chopper Commander
  • 145 posts
Posted Thu Jul 12, 2018 9:56 AM
Tried swapping PSUs and power outlets but the loud buzz remains.  Sprayed the channel select with cleaner and jostled about 10 times so when dry I'll try again. I suspect it is something internally.  I will open it after I get through the 600XL I'm working on, but it may be a great candidate for the new S-video mod and RAM upgrade and get off of RF completely.
