6510 in A8-bit?
13 replies to this topic
#1 scotty OFFLINE
scotty
    Moonsweeper
  • 422 posts
  • I have, but have **YOU** played Atari today?
Posted Tue Jul 10, 2018 5:25 PM
Would it work?  6510 is compatible with the 6502, only difference being bank-switching.  Do not see why it wouldn't.    Years ago, I put a Motorola 68010 in a 1040 ST, and while it DID work, there were some  (not a lot but some) programs that did not work.   Thoughts?
#2 Xebec OFFLINE
Xebec
    Moonsweeper
  • 381 posts
Posted Tue Jul 10, 2018 7:00 PM
I don't think it'll work without an additional circuit due to the fact that Atari's 6502 "SALLY" has a 'halt' pin/function that the standard 6502.  The 6510 does not appear to have this HALT Pin either.
The exception might be the 'early production Atari 400/800' machines which actually used a regular 6502C and had the circuitry on the board instead of the CPU.
https://www.atarimax...g/achsally.html
Description
6502 is the heart of the computer. It's based on MOS Technologies 6502. While the 400/800 models contain a generic 6502 CPU, all of the XL/XE models contain Atari's customized 6502C chip. 6502c has an extra line called HALT. It is controlled by ANTIC which it uses whenever it needs the /jindroush.atari.org/data/address bus. The HALT line must be pulled high for the chip to work. Early 400/800 NTSC computers used a standard 6502 and 4 additional chips to stop the processor when ANTIC needed the busses.
#3 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,039 posts
Posted Tue Jul 10, 2018 11:07 PM
What would be the benefit?
We would loose 2 ZPs as IO ports and rest is binary compatible even with unsupported oppodes.
#4 Rybags OFFLINE
Rybags
  • 15,892 posts
Posted Wed Jul 11, 2018 1:58 AM
An OS rework would be needed so locations 0/1 don't get stomped on.  These are just work areas mainly used in cold/warmstart.  I think there is one XL OS (the one the spontaneously resets when you change a cart rather than doing a lockup like later ones) that can have issues if you change contents of one of those locations.
Likely the old way of halting the CPU with external circuitry would be needed like early 400/800.
The 6510 has the BA pin that I think can be used like /Halt but I think it only works once the current instruciton has finished (or similar).
Generally the C64 uses /RDY when doing DMA bursts and it needs a few cycles pre-emption since write instructions can delay it's effect.
Possibly the biggest problem - can the 6510 operate at the higher speed?  I suppose if not then the CPU from a C128 could be used as it has the "Fast" mode where it operates at 2 MHz.
But overall - why?  Without extensive further rework to use the 6 IO port bits as either bankswitching or something else (yep, the C64 only has 6 bits of IO, not 8 on the CPU), the CPU is functionally the same from a programming POV.
I guess one project might be to do an XL with 4 joystick ports that work with all games including those that read the ports directly.  But then you'd get the OS issues and software aplenty that stomps locations 0/1.
Edited by Rybags, Wed Jul 11, 2018 2:01 AM.
#5 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,039 posts
Posted Wed Jul 11, 2018 2:59 AM
6510 is C64 so its easier for us to get colors and sprites ;) (ok... joking).
SID is more interesting?
#6 Rybags OFFLINE
Rybags
  • 15,892 posts
Posted Wed Jul 11, 2018 4:05 AM
SID way more desirable though apparently getting rare thanks to people harvesting them for stereo C64 or blackbox type projects.
Didn't candle even make an interface with proper asynchronous bus interface so it could be run at it's proper speed?
#7 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,039 posts
Posted Wed Jul 11, 2018 3:06 PM
Yeah I remember some stuff but wonder why SID cards did not appear more often as project.
Or some kind of YM-chipset as sound card. We have video enhancements, cpu, ram, flash/hdd but except stereo not much more?
#8 Rybags OFFLINE
Rybags
  • 15,892 posts
Posted Wed Jul 11, 2018 6:41 PM
YM as per ST/Spec/BBC - IMO an inferior chip by a good margin.  The only advantage is that it has better frequency range and resolution in the default mode vs only 2 channels for Atari if we want to match it.
But far outweighed by Pokey's effects and exploits.
#9 Nezgar OFFLINE
Nezgar
  • 1,335 posts
Posted Thu Jul 12, 2018 12:28 AM
Looks like they've developed a drop-in SID replacement to solve having to steal chips from other machines, and add more features (stereo too) https://www.c64-wiki.com/wiki/SwinSID
#10 DrVenkman OFFLINE
DrVenkman
  • 3,600 posts
  • Back off, man! I'm a scientist.
Posted Thu Jul 12, 2018 8:02 AM
8-bit Guy reviewed that on his YouTube channel this past week. It appears relatively compatible with both versions of SID but it’s not perfect.
#11 tmp OFFLINE
tmp
    Chopper Commander
  • 104 posts
Posted Thu Jul 12, 2018 8:24 AM
this one should be way better
http://dzi.n.cz/8bit...id/index_en.php
#12 DrVenkman OFFLINE
DrVenkman
  • 3,600 posts
Posted Thu Jul 12, 2018 8:47 AM
Why isn’t someone doing this with POKEY? The 7800 community needs it badly for homebrews!
#13 David_P OFFLINE
David_P
    Dragonstomper
  • 911 posts
Posted Thu Jul 12, 2018 3:58 PM
This year, in the Abbuc HW contest (main thread at: http://atariage.com/...econtest-2018/)
PokeyMAX
Introduction
The PokeyMAX is a complete replacement for the Pokey chip.
 If pokey is socketed, zero wire installation (mono)
 Dual pokey fashion
 pins for 3 audio outputs (left channel / right channel / mixed)
 Small footprint, only a few mm larger than the original IC
 support all features: 8x paddle inputs, IRQ, serial I / O, audio output, two tone mode, high pass filter and keyboard scan
 High level of compatibility
http://www.abbuc.de/...php?f=15&t=9560
#14 _The Doctor__ OFFLINE
_The Doctor__
  • 5,840 posts
Posted Thu Jul 12, 2018 8:15 PM
hmm will it be a 50/60 issue on this one or will the pump take care of itself from the system clocks
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
