SDrive-MAX Connection Issue
64 replies to this topic
#51 Level42 ONLINE
Level42
  • 2,464 posts
Posted Mon Jul 16, 2018 3:35 PM
Can't you hold reset on the 800 during power up and then let go ? IIRC the RESET of the 800 is quite different in function compared to the XL/XE's
#52 DrVenkman OFFLINE
DrVenkman
  • 3,467 posts
  • Back off, man! I'm a scientist.
Posted Mon Jul 16, 2018 3:41 PM
I tried that last night; didn't work. Eh, no biggie. Ultimately (some months from now) I expect this device will get used with one my 800's, and I'll just stick with the XEL-CF Loader for my 1088XEL, plus use of the built-in SIO2PC functionality when necessary.
That said, I do intend to build one or two more of them (one spare for myself and another for a friend). You can be darn sure I'll be using a Schottky diode instead of a 1N4148 on those! :P
On the upside of this situation, I now have more 1N4148 diodes than I'm likely to need in my remaining lifespan … lol!
#53 orpheuswaking OFFLINE
orpheuswaking
  • 5,737 posts
  • Lone Raider Time!
Posted Tue Jul 17, 2018 12:55 PM
I now have the parts for two of these (and a third case for future use) - Just need to find the time to actually build them out. I'll definitely be showing this off at the VCF MW this year.
#54 mytek OFFLINE
mytek
  • 3,013 posts
Posted Tue Jul 17, 2018 2:01 PM
Those will work fine as replacements for the 1N914s as spec'ed for the 1088XEL, or on any of the TK-II boards. So keep that in mind  ;) .
#55 Level42 ONLINE
Level42
  • 2,464 posts
Posted Wed Aug 1, 2018 3:36 PM
My case is being printed by a friend as we speak :) I went for black, as his white is really ....white, which will look more off next to the ivory of my 600XL.
For some reasons explained later: I just measured the current the Sdrive-Max consumes. With the screen installed and running, incl. SD-card installed it is 110mA. However, when I removed the screen and measured again the USB tester indicated 0,00 A...... Of course it is quite logical that the screen draws most current but I didn't expect the power "hunger" of the UNO (clone) to be so low....Yeah I know it's, not a Fluke, but it's close enough for why I measured it...
Now my question is: could the screen be turned off after some time and can it pop back on when it's touched ?
The 110mA is a pretty serious amount for the A8 power supplies which usually need to provide less than 1000mA. Having a "maxed out" machine with all sorts of extra's doesn't help either of course...
....and there's another reason why I would it to go into some "sleep" mode if possible....
Edited by Level42, Wed Aug 1, 2018 3:37 PM.
#56 _The Doctor__ OFFLINE
_The Doctor__
  • 5,144 posts
Posted Wed Aug 1, 2018 4:15 PM
be great to dim the back light that's for sure... current limiting possible?
#57 tomsmart1 OFFLINE
tomsmart1
    Space Invader
  • 11 posts
Posted Sat Aug 4, 2018 9:02 AM
I finaly made it after i had to order new diodes. My SDRIVE-MAx runs with a shottky diode of the type 1N5817 in the 5V line and a BAT85 in the Data Input - TxD line. I test it with my 800XL with Ultimade1MB with a power converter from the Abbuc the SDRIVE-MAX was directly connected to the computer. I test it with ATR images like RealDOS up to POKEY divisor 0 , BIBODOS,... and with .CAS file like GREENBERRET,AIRWOLF,TRUST and THE DOMAIN OF THE UNDEAD.
#58 Level42 ONLINE
Level42
  • 2,464 posts
Posted Sun Aug 5, 2018 8:15 AM
Man I really must complain about this whole Sdrive-Max idea......
It seriously was the most boring project I ever did.
I ordered the insanely cheap parts, put them together, figured out the USB driver and programming, figured out the wiring of my SIO cable, soldered 5 wires, copied files to an SD card and bam it worked. And works and works....
This is not how it should go. Projects should be costly, but at least be troublesome, hard to execute and cause headaches  :grin:  :grin:  :grin:  :grin:  :grin:
Edited by Level42, Sun Aug 5, 2018 8:17 AM.
#59 rdea6 OFFLINE
rdea6
  • 2,739 posts
Posted Mon Aug 20, 2018 3:16 PM
Got mine soldered up today and it worked first time with a 1N914 diode I had laying around.  From what I can see of your board in the above picture it appears to be the same board.  This is running on SIO power from a 600xl.  Thsi is the board I ordered:
https://www.amazon.c...0?ie=UTF8&psc=1
Any chance of buying one of those cases?  They look great!
Hi,
What screen are you buying to go along with this UNO product.??
#60 JR> OFFLINE
JR>
    Moonsweeper
  • 293 posts
Posted Mon Aug 20, 2018 3:50 PM
I used the Elegoo.  It's relatively expensive compared to some of the clones, but it works and fits the printed cases perfectly.
https://www.amazon.c...e?ie=UTF8&psc=1
Some of the others can probably point you to cheaper alternatives.
#61 Level42 ONLINE
Level42
  • 2,464 posts
Posted Mon Aug 20, 2018 4:52 PM
http://s.aliexpress.com/fA7VNf2E
I am going to claim that this is simply the same as the Elegoo.....they just put a name on it and box around it....I just ordered and received a second one and works 100% too.
Edited by Level42, Mon Aug 20, 2018 4:59 PM.
#62 Level42 ONLINE
Level42
  • 2,464 posts
Posted Mon Aug 20, 2018 4:57 PM
Nope....not possible sadly....
Edited by Level42, Mon Aug 20, 2018 4:57 PM.
#63 orpheuswaking OFFLINE
orpheuswaking
  • 5,737 posts
  • Lone Raider Time!
Posted Tue Aug 21, 2018 7:21 AM
I'm glad you got yours ok, I ordered from the same link and received two screens in a bubbleope with smashed pins and lovely cracks on the screen.
#64 Level42 ONLINE
Level42
  • 2,464 posts
Posted Tue Aug 21, 2018 7:30 AM
Arghhh. Stupid trasnporters although to be honest....you indeed would expert a box for shipping these.
Ordered two individually and both arrived fine....guess I was lucky ....what did the seller say ? They should pack better...
#65 orpheuswaking OFFLINE
orpheuswaking
  • 5,737 posts
  • Lone Raider Time!
Posted Wed Aug 22, 2018 12:52 PM
I opened a dispute through aliexpress and they just refunded it. Luckily the uno boards came in perfect condition so I only had to buy new screens.
