tutachamons tomb, need help getting it to use joystick 1
7 replies to this topic
#1 jrhodes ONLINE
jrhodes
    Chopper Commander
  • 239 posts
  • RUN "CS1"
Posted Mon Jul 16, 2018 1:48 PM
I am attempting to convert a game that uses joystick 2 to use joystick 1.
I know i should change 630 CALL KEY(2,K,S) to 630 CALL KEY(1,K,S),
and change 640 CALL JOYST(2,YJ,XJ) to 640 CALL JOYST(1,YJ,XJ)
but i am confused what to use here:780 IF K=-7 THEN 810
Original:
630 CALL KEY(2,K,S) :: IF S THEN 780
640 CALL JOYST(2,YJ,XJ) :: IF XJ+YJ=0 THEN 620
What i have so far:
630 CALL KEY(1,K,S) :: IF S THEN 780
640 CALL JOYST(1,YJ,XJ) :: IF XJ+YJ=0 THEN 620
780 IF K=[b][i]??[/i][/b] THEN 810
Original game is attached to this post.
Spoiler
Attached File  TUTACHAMON.zip   5.18KB   7 downloads
#2 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,921 posts
  • Technology Samurai
Posted Mon Jul 16, 2018 2:54 PM
If that line works then I would think changing the scanned units in CALL KEY and CALL JOYST should be sufficient.
#3 jrhodes ONLINE
jrhodes
    Chopper Commander
  • 239 posts
  • RUN "CS1"
Posted Mon Jul 16, 2018 3:09 PM
Just was not sure. I was searching for new games, previewing them through TI99Dir. I hate swapping my joystick around.
I actually have not run it yet, just running through what i think i will need to do to make it work with joystick 1.
The following loop never yields a -7 with CALL KEY(2,K,S), so i'm honestly not sure what they are looking for here:
1 CALL KEY(2,K,S)
2 IF S=0 THEN 1
3 PRINT K :: GOTO 1
#4 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,921 posts
Posted Mon Jul 16, 2018 6:17 PM
Got me.  I cannot find (CTRL-F) any other place in the program which literally sets K.  Unless the programmer is exploiting some quirk of the key scan which could possibly produce a -7 return.
EDIT: I think your pasted listing is missing something.  I cannot find anywhere TEK is actually assigned, either.
#5 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,921 posts
Posted Mon Jul 16, 2018 6:28 PM
Nope.  The program lists the same way.  My brain hurts right now :)
#6 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,921 posts
Posted Mon Jul 16, 2018 6:31 PM
You need to edit lines 1060, 1260, 1660.  These have JOYST and KEY calls.
#7 sparkdrummer ONLINE
sparkdrummer
  • 1,039 posts
  • Status? I don't need no stinkin' status!
Posted Wed Jul 18, 2018 1:27 AM
I have that game as well - good game. No need to change 780, it is correct as is. As OLD CS1 states above, you do need to change those other lines. I can upload my copy if needed.
#8 jrhodes ONLINE
jrhodes
    Chopper Commander
  • 239 posts
  • RUN "CS1"
Posted Wed Jul 18, 2018 7:15 AM
Got it.
Attached version is joystick #1, thanks for the help! ;-)
Attached File  TUTACHMNJ1.zip   5.18KB   4 downloads
Edited by jrhodes, Wed Jul 18, 2018 7:18 AM.
