List of Variables Freed by kernel Options?
2 replies to this topic
#1 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,291 posts
Posted Mon Jul 16, 2018 2:55 PM
After not having success with the search function I thought to ask:
Is there a list of confirmed safe variables freed when using certain kernel options?
For instance: when using
 set kernel_options player1colors no_blank_lines
Does that mean it frees up
missile0x, missile0y, missile1x, missile1y, missile0height, missile1height
#2 RevEng ONLINE
RevEng
    Bit Player
  • 5,081 posts
Posted Mon Jul 16, 2018 4:12 PM
No. One rule of thumb you can keep in mind is that usually the X variables stick around. Otherwise the trick of turning on ENAM0 and positioning the missile wouldn't work. The other variables are (almost?) always consumed.
If I open up 2600basic.h, I can see that "player1color = $87", and "missile1height = $87". That means when player1color is being used, it consumes that missile1height memory location.
I know from experience that player1color is actually 2 bytes, so it also consumes "$88". 2600basic.h says "missile1y = $88", so that variable is gone too.
Similar comparisons can be made to show player0color eats up missile0y and missile0height. I leave those as an exercise to the reader. ;)
#3 Gemintronic OFFLINE
Gemintronic
  • 9,291 posts
Posted Mon Jul 16, 2018 5:22 PM
Thank you for the info RevEng.  Back to reducing playfield rows and re-writing code to use boolean flags instead of whole vars. :)
