RS232 over the joystick port
15 replies to this topic
#1 jrhodes OFFLINE
jrhodes
    Chopper Commander
  • 240 posts
  • RUN "CS1"
Posted Mon Jul 16, 2018 11:15 PM
I remember hearing that the TI's joystick port can be used as a rs232 port.
The person writing the article even transmitted a small amount of data over it, if i recall correct.
Unfortunately i can not seem to find that article right now.
Any one know the article in question and where to find it?
#2 JB OFFLINE
JB
  • 9,281 posts
  • With Stereo-Of-The-Art-Sound
Posted Mon Jul 16, 2018 11:40 PM
http://www.mainbyte....lk/joytalk.html
#3 sparkdrummer ONLINE
sparkdrummer
  • 1,044 posts
  • Status? I don't need no stinkin' status!
Posted Tue Jul 17, 2018 2:50 AM
Attached File  SSSD.dsk   90KB   8 downloads
Here is the source and object code for this device.
Edited by sparkdrummer, Tue Jul 17, 2018 2:50 AM.
#4 Vorticon OFFLINE
Vorticon
  • 3,539 posts
Posted Tue Jul 17, 2018 5:53 AM
Totally forgotten about this project. Has anyone ever built it?
#5 Shift838 OFFLINE
Shift838
  • 2,505 posts
  • SHIFT838
Posted Tue Jul 17, 2018 8:01 AM
I did not build it but I came by one some years ago.  Once I identified what it was I found someone that was interested in having it so I sent it to them.  He said it worked.  But it will not work with the standard terminal programs out there since it uses the joystick port.
#6 Tursi OFFLINE
Tursi
  • 5,487 posts
  • HarmlessLion
Posted Tue Jul 17, 2018 4:33 PM
We talk about it every couple of years. I built one and used it as my printer interface for about a year back in the day. :)
  • RXB likes this
#7 TheBF OFFLINE
TheBF
    Dragonstomper
  • 911 posts
Posted Wed Jul 18, 2018 4:40 AM
What baud rate can you get out it Tursi?
B
#8 RXB OFFLINE
RXB
  • 3,506 posts
Posted Wed Jul 18, 2018 10:34 AM
Joyport was much faster then the RS232 card for top performance.
#9 TheBF OFFLINE
TheBF
    Dragonstomper
  • 911 posts
Posted Wed Jul 18, 2018 7:46 PM
It  looks like the TMS9919 can get to 19,200 BPS and maybe even 38.4Kbps.
At that speed the CPU could barely keep up with the data while receiving a continuos stream, I should think.
I you added the overhead of reading bits on the 9901 with the 9900 CPU, how does it manage to do it faster?
I am amazed.
Side question, what is the effective BPS rate of the Cassette save/load system?
#10 RXB OFFLINE
RXB
  • 3,506 posts
Posted Wed Jul 18, 2018 8:33 PM
I am amazed.
Hmm you put RAM on the 16 bit bus, so this smokes the RS232 performance.
#11 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Wed Jul 18, 2018 8:42 PM
What is this statement based on?
#12 Tursi OFFLINE
Tursi
  • 5,487 posts
  • HarmlessLion
Posted Wed Jul 18, 2018 8:53 PM
It ran through subroutine calls in MiniMemory, and basically toggled the joystick select lines. It was output-only, no hardware for data input (except it supported one or two of the printer status signals). I only ran it at 1200bps, I don't remember what it could get to (but the article is linked above ;) ).
#13 RXB OFFLINE
RXB
  • 3,506 posts
Posted Thu Jul 19, 2018 2:36 AM
Second article on PDF says (110 to 19200 baud) but I do remember someone had mods that got as high as 38400 baud and I think it was in Micropendium.
#14 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Thu Jul 19, 2018 5:43 AM
Could the joystick port be turned into a I²C? I guess the power is again the main problem here.
#15 Stuart OFFLINE
Stuart
    Dragonstomper
  • 833 posts
Posted Thu Jul 19, 2018 6:12 AM
http://www.stuartcon...m#i2c_interface
#16 RXB OFFLINE
RXB
  • 3,506 posts
Posted Thu Jul 19, 2018 12:34 PM
Quote: "Cortex BASIC should also work as that includes instructions to control the CRU interface."
RXB has CALL IO too, that has been demoed on the Weather Station interface and other devices.
