_The Doctor__ Posted July 22, 2018 Share Posted July 22, 2018 For whatever the reason, it seems to work. That's good enough for most folks.... I wonder if a disk that's failing format like that gets kryofluxed.scp'd and them formatted under 3, kryo etc. and then finally formatted again with 2.xx, kryo etc. and then a compare is done if it would show why in the stream.... it should, but the lack of index hole use make it tough tough tough to do... 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 22, 2018 Share Posted July 22, 2018 (edited) The only difference once the drive manages to successfully lay down the tracks is in which sectors get written out to form a blank filesystem, and there won't be many. In the case of DOS 3: boot sectors (also written by DOS 2.5), empty FAT and empty directory. Edited July 22, 2018 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
