pause before executing more code
2 replies to this topic
#1 ... OFFLINE
    Combat Commando
  • 1 posts
Posted Sun Jul 22, 2018 9:53 PM
I'm trying to make a "munching squares" effect
I need to wait before changing the playfield to the next frame
can anyone help me with this?
#2 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,291 posts
Posted Mon Jul 23, 2018 12:28 PM
Not sure how to help without seeing the code you're struggling with.  Also, how you pause is a programming choice.  For instance:  I write two separate drawscreen related sections for paused and unpaused gameplay.  The code snippets below are basically two very similar code blocks but one decrements a time display (the paused section doesn't)
 rem //** DRAW EVENTS **//
drawevent_main
 COLUPF = pfcolor
 COLUBK = bkcolor
 COLUP0 = p0color
 COLUP0 = counter
 NUSIZ0 = p0size
 NUSIZ1 = p1size
 CTRLPF = pfctrl
 if p0ref then REFP0 = 8
 if p1ref then REFP1 = 8
 player1x = player1x - tempx
 drawscreen
 player1x = player1x + tempx
 rem //** COUNTDOWN TIMER **//
 frames=frames+1:if frames<>one_tenth then skip_tenths
 frames=0
 tenths=tenths&$0F
 minutes=minutes&$F0
 score=score-1
 if tenths=$99 then score=score-90
 if seconds=$99 then score=score-4000
skip_tenths
 tenths=tenths|$A0
 minutes=minutes|$0B
 goto main_begin
drawevent_pause
 COLUPF = pfcolor
 COLUBK = bkcolor
 COLUP0 = p0color
 COLUP0 = counter
 NUSIZ0 = p0size
 NUSIZ1 = p1size
 CTRLPF = pfctrl
 drawscreen
 goto main_begin
#3 Lolkiu64 OFFLINE
Lolkiu64
    Space Invader
  • 26 posts
Posted Mon Jul 23, 2018 1:37 PM
Are you talking about this:
Looks awesome, but keep in mind a munching squares program on Atari 2600 won't look as cool because in batari basic the playfield pixels are 32 x 11 (or 32 x 12 if you add some vertical scrolling)
Anyways have a variable play as some sort of timer, each time the current code runs have it take one away from the variable (timer = timer - 1) then once the variable reaches 0 reset the variable to whatever number (ex: 60) and have it move to the next frame.
