Commodore 64 (black screen with line)
Commodore 64 Commodore 8-bit problem black screen
1 reply to this topic
#1 Antic OFFLINE
Antic
    Combat Commando
  • 1 posts
Posted Tue Jul 24, 2018 3:02 PM
Hi
Im trying to fix this Commodore 64 but so far no success. When I power it up I get a line on screen (look at picture), after about 3 minutes the chips are slowly getting worm except for the PLA,SID and Kernal they get hot but just enough so that they can still be touched, i probed with my scope pins 1 and 39 on cpu and the clock seems fine ,how do I proceed from here   :?
I am suspecting the PLA but dont have another Commodore to test it
I heard that I could test the chips using a arduino but probably would need a code for that.
#2 shoestring OFFLINE
shoestring
    Moonsweeper
  • 441 posts
Posted Fri Jul 27, 2018 6:00 PM
Suspect a dead PLA unless proven otherwise.
A dead SID should not prevent a c64 from booting, unless its shorted directly to gnd which may may prevent it from doing so. You'll see a blank screen or sometimes jumbled multicoloured screen.  Pull the SID chip out and see if it boots, a c64 should always boot without one if that's the only fault on the board.
What are your +5v voltages like ?
Since you have a scope.
What does RST ( pin 40 ) do on power up ? ( should toggle from low for half a second and hold high ).
Any activity on the Address and Data pins ?. If they toggle for a short time after cold reset then get stuck ( low or high ).. suspect bad DRAM or mask rom.
Any DRAM chips get hot to the touch?
Check pin 38( R/W ),
* What is it doing?. This determines what the next DRAM access will be ( Either a read or a write ). A low indicates a write, a high should indicate a read.
* Pin 39 should always be high when a r/w access occurs.
* Are any data pins from the 6510 floating during a write access ? ( r/w low ).
Also tagged with one or more of these keywords: Commodore 64, Commodore, 8-bit, problem, black screen
