jrhodes Posted July 26, 2018 Share Posted July 26, 2018 (edited) I am looking for any and all cartridges on disk usable with EA option 5, in particular T.E. II, Personal record keeping, and Speech editor. Seems that all the "module to disk" collections i have access to are games and edutainment titles. Edited July 26, 2018 by jrhodes 2 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted July 30, 2018 Author Share Posted July 30, 2018 No one knows where to get any of the non-game modules on disk? Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted July 30, 2018 Share Posted July 30, 2018 For the 3 that you mention: Terminal Emulator II uses GROM and 8K of ROM Personal Record Keeping uses GROM only Speech Editor uses GROM only With the GROM it would be difficult to make these work with EA option 5. You would have to rewrite the GROM in assembly. That's probably why you don't see these on disk. Quote Link to comment Share on other sites More sharing options...
jrhodes Posted July 30, 2018 Author Share Posted July 30, 2018 Ah ok. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted July 30, 2018 Share Posted July 30, 2018 For the 3 that you mention: Terminal Emulator II uses GROM and 8K of ROM Personal Record Keeping uses GROM only Speech Editor uses GROM only With the GROM it would be difficult to make these work with EA option 5. You would have to rewrite the GROM in assembly. That's probably why you don't see these on disk. The attached tool should allow you to turn GPL object code into runnable E/A#5 files. I don't know how difficult it is to disassemble the Speech Editor GROM, for instance, and reassemble it to produce an object file? linker-doc.txt GPLHOW2B.zip 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted August 1, 2018 Share Posted August 1, 2018 I know there are GPL disassemblers, so the approach above might work. Any idea if there is a speed difference if you run a GPL program this way? Quote Link to comment Share on other sites More sharing options...
RXB Posted August 1, 2018 Share Posted August 1, 2018 (edited) The speech editor is only slightly larger but works the same way as XB: *********************************************************** [2985] * CALL SAY(....................) [2986] * Decode given parameter(s). Store all data first, then go [2987] * speak it all at once. [2988] *********************************************************** [2989] B1D0 D6,42,B7 SAY CEQ LPARZ,@CHAT Must start with "(" [2990] B1D3 4D,BA BR ERRSYN [2991] B1D5 BD,4C,6E DST @VSPTR,@FAC2 Save current top of stack on [2992] B1D8 0F,77 XML VPUSH the stack [2993] B1DA BF,0C,00 DST 255,@BYTES 255 bytes = 85 3 byte entires B1DD FF [2994] B1DE 0F,71 XML GETSTR Get temp speech list string [2995] B1E0 BF,4A,00 DST >001C,@FAC Indicate it is temp string (S B1E3 1C [2996] B1E4 BF,4C,65 DST >6500,@FAC2 Indicate it is string entry B1E7 00 [2997] B1E8 BD,4E,1C DST @SREF,@FAC4 Save pointer to temp string [2998] B1EB BD,50,0C DST @BYTES,@FAC6 Length is 255 [2999] B1EE 0F,77 XML VPUSH Make it semi-permenant [3000] * Set up pointers into the speak list [3001] B1F0 BD,00,4E DST @FAC4,@PTFBSL Front points to begining [3002] B1F3 BD,02,4E DST @FAC4,@PTLBSL Last now points to beginning [3003] B1F6 BD,04,00 DST @PTFBSL,@PTEBSL [3004] B1F9 A1,04,50 DADD @FAC6,@PTEBSL End points to the end+1 [3005] B1FC 06,B6,1A CALL SETRW Set PHROM read/write address [3006] B1FF 06,B6,0F CALL WAIT Wait till no one is speaking [3007] B202 06,B3,E7 DIRSPK CALL GETPRM Get next parameter [3008] B205 72,79 BS NEXT1 If non-null ASCII string [3009] B207 BD,06,4E DST @FAC4,@PTFCIS Set up pointer to first char [3010] B20A BD,0A,50 DST @FAC6,@PTLCIS Set ptr-to-last-char-in-strin [3011] B20D A1,0A,06 DADD @PTFCIS,@PTLCIS by adding length-of-string [3012] B210 93,0A DDEC @PTLCIS and subtracting 1 [3013] * Make a speech list [3014] B212 06,B6,1A CALL SETRW Set speech read/write addrs [3015] B215 BD,08,06 DST @PTFCIS,@PTCCIS Start at beginning of string [3016] B218 86,4C CLR @TOTTIM Clear total time delay [3017] B21A 06,B4,64 CALL GETTIM Get first timing mark [3018] B21D 06,B4,54 CALL TIMING Get any subsequent marks [3019] * The total first time delay is in TOTTIM now [3020] B220 C5,08,0A GB158 DCH @PTLCIS,@PTCCIS While more string [3021] B223 72,6F BS GB1A7 [3022] B225 06,B3,FD CALL PHRASE Get next phrase [3023] * If spell flag is 0, try to look the phrase up. If it [3024] * can not be found, then set the spell flag, and it will be [3025] * spelled out. If found, save on speak list. [3026] B228 8E,4B CZ @SPLFLG There is a phrase [3027] B22A 52,3B BR GB173 [3028] B22C 06,B4,F9 CALL LOOKUP Try to look it up in the PHRO [3029] B22F 8F,4D DCZ @DATAAD If not found then [3030] B231 52,38 BR GB170 [3031] B233 BE,4B,01 ST 1,@SPLFLG Set the spell flag [3032] B236 52,3B BR GB173 [3033] B238 06,B5,FF GB170 CALL STDATA Store data in list [3034] * If spell flag is 1, set time delay to >3C, and take the [3035] * phrase one character at a time (spell it). Look up each [3036] * character: if not found, use 'UHOH' data instead. [3037] * Regardless, store data on speak list. [3038] B23B D6,4B,01 GB173 CEQ 1,@SPLFLG Need to spell it out? [3039] B23E 52,68 BR GB1A0 [3040] B240 BD,4F,10 DST @PTLCIP,@PTLCIL Est last char to spell out [3041] B243 BE,4C,3C ST >3C,@TOTTIM >3C used because sounds good [3042] * Take each single character 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0053 EQUATES EXEC-359 [3043] * Skip over any embedded spaces encountered in a phrase [3044] B246 D6,B0,0C GB17E CEQ SPACE,V*PTFCIP B249 20 [3045] B24A 52,50 BR GB188 [3046] B24C 91,0C DINC @PTFCIP [3047] B24E 52,46 BR GB17E [3048] * Set first and last pointers to same one character [3049] B250 BD,10,0C GB188 DST @PTFCIP,@PTLCIP [3050] B253 06,B4,F9 CALL LOOKUP Try to look it up [3051] * If not found, use data to 'UHOH' [3052] B256 8F,4D DCZ @DATAAD [3053] B258 52,5E BR GB196 [3054] B25A BF,4D,71 DST >71F4,@DATAAD Put addr of 'UHOH' in B25D F4 [3055] B25E 06,B5,FF GB196 CALL STDATA Store data on speak list [3056] B261 91,0C DINC @PTFCIP Go on to next character [3057] B263 C5,0C,4F DCH @PTLCIL,@PTFCIP Until done all [3058] B266 52,46 BR GB17E [3059] * At this point, get next timing group. The first timing [3060] * character has already been found, and it's value is still [3061] * in TIMLEN. Therefore, initiatory call to GETTIM not [3062] * needed. Simply clear TOTTIM and call TIMING. [3063] B268 86,4C GB1A0 CLR @TOTTIM [3064] B26A 06,B4,54 CALL TIMING [3065] B26D 52,20 BR GB158 [3066] * At this point, finished all the phrases in this string. [3067] * TOTTIM should equal >FE, it indicate end of sting If it [3068] * doesn't equal >FE, it indicates that a timing group was [3069] * put on the end of the string. Therefore, save the timing [3070] * group with a null data address to show it is only timing. [3071] B26F D6,4C,FE GB1A7 CEQ >FE,@TOTTIM [3072] B272 72,79 BS NEXT1 [3073] B274 87,4D DCLR @DATAAD [3074] B276 06,B5,FF CALL STDATA [3075] * Next item could be direct string. [3076] B279 D6,42,B3 NEXT1 CEQ COMMAZ,@CHAT If direct string present [3077] B27C 52,93 BR SPEAK [3078] B27E 06,B3,E7 CALL GETPRM Get the next parameter [3079] B281 72,8E BS NEXT2 If non-null direct string [3080] B283 BE,4C,FF ST >FF,@TOTTIM Mark TOTTIM as direct string [3081] B286 0F,77 XML VPUSH Save direct string on stack [3082] B288 BD,4D,6E DST @VSPTR,@DATAAD Store stack addr on string [3083] B28B 06,B5,FF CALL STDATA And add to the speak list [3084] * If the next character is a comma, loop thru it again [3085] B28E D6,42,B3 NEXT2 CEQ COMMAZ,@CHAT [3086] B291 72,02 BS DIRSPK [3087] * If end fall into SPEAK [3088] *********************************************************** [3089] * SPEAK will actually speak the speech list. It tests the [3090] * timing byte to see if it is an >FF. If it is, then the [3091] * data following it points to a direct speech data string [3092] * in VDP. If it is not, then the data following it points [3093] * to a PHROM speech data list. In the first case, this [3094] * routine will issue a speak external command to the PHROM [3095] * and then feed bytes out to the PHROM as it requests them. [3096] * In the second case, the address will be loaded out to the [3097] * PHROM, and then a speak command will be issued. [3098] *********************************************************** [3099] B293 06,B6,1A SPEAK CALL SETRW Set read/write address [3100] B296 C9,00,02 GB1CE DCHE @PTLBSL,@PTFBSL More speech list to go [3101] B299 73,20 BS GB258 [3102] B29B 06,B6,0F CALL WAIT Yes, wait until previous [3103] * speech is though [3104] B29E D6,B0,00 CEQ >FF,V*PTFBSL External speech data 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0054 EQUATES EXEC-359 B2A1 FF [3105] B2A2 72,C6 BS GB1FE [3106] B2A4 BC,79,B0 ST V*PTFBSL,@TIMER No, load timer B2A7 00 [3107] B2A8 82,79 NEG @TIMER and neg it to correct [3108] B2AA BD,12,E0 DST V@1(@PTFBSL),@PTFBPH Put addr into PTFBPH B2AD 01,00 [3109] B2AF A3,00,00 DADD 3,@PTFBSL and skip to next node B2B2 03 [3110] B2B3 D2,79,00 LOOP1 CGE 0,@TIMER Wait for time delay [3111] B2B6 52,B3 BR LOOP1 [3112] B2B8 8E,12 CZ @PTFBPH If there is data [3113] B2BA 72,C4 BS GB1FC [3114] B2BC 06,B5,B5 CALL LOADAD Load the addr to PHROM [3115] B2BF BE,C0,00 ST >50,@VAR0(@WRITE) and issue speak command B2C2 5A,50 [3116] B2C4 53,1D GB1FC BR CONTIN [3117] B2C6 91,00 GB1FE DINC @PTFBSL Speak external, skip over >FF [3118] B2C8 BD,5E,B0 DST V*PTFBSL,@PTCBED Set up pointer to 1st byte B2CB 00 [3119] B2CC BD,5E,E0 DST V@4(@PTCBED),@PTCBED in external speech data B2CF 04,5E [3120] B2D1 95,00 DINCT @PTFBSL Skip addr bytes [3121] B2D3 BC,62,EF ST V@-1(@PTCBED),@LENWST Get Len of whole string B2D6 FF,FF,5E [3122] B2D9 A6,62,03 DIRSPH SUB 3,@LENWST Minus 3 bytes overhead [3123] * All external speech strings start with a >60 [3124] B2DC D6,B0,5E CEQ >60,V*PTCBED Bad speech string B2DF 60 [3125] B2E0 4D,EE BR ERRBV [3126] B2E2 06,B6,0F CALL WAIT Wait for go ahead [3127] B2E5 95,5E DINCT @PTCBED Skip spk ext & 1st byte len [3128] B2E7 BC,60,B0 ST V*PTCBED,@LENCST Get len of current string B2EA 5E [3129] B2EB 91,5E DINC @PTCBED Skip len byte to 1st real byt [3130] B2ED BE,56,10 ST 16,@TEMP2 Do 1st 16 bytes (fill buff) [3131] B2F0 BE,C0,00 ST >60,@VAR0(@WRITE) Start Speak External B2F3 5A,60 [3132] B2F5 BC,C0,00 LOOPR ST V*PTCBED,@VAR0(@WRITE) Write byte to PHROM B2F8 5A,B0,5E [3133] B2FB 91,5E DINC @PTCBED Go to next byte [3134] B2FD 92,62 DEC @LENWST 1 less char in whole string [3135] B2FF 73,1D BS CONTIN Finished whole string? [3136] B301 92,60 DEC @LENCST 1 less char in curr string [3137] B303 72,D9 BS DIRSPH Finished current string? [3138] B305 92,56 DEC @TEMP2 1 less char in this loop [3139] B307 52,F5 BR LOOPR Not finished curr loop yet? [3140] B309 BC,69,C0 GB241 ST @VAR0(@READ),@SPKSTS Read status from PHROM B30C 00,58 [3141] [3142] * If the next statement is true, it means that speak was [3143] * probably interupted and that it is shot at this point. [3144] * Therefore, we are going to quit now. [3145] B30E DA,69,80 CLOG >80,@SPKSTS [3146] B311 73,1D BS CONTIN [3147] B313 DA,69,40 CLOG >40,@SPKSTS Loop till buff below half [3148] B316 73,09 BS GB241 [3149] B318 BE,56,08 ST 8,@TEMP2 Put 8 more bytes to PHROM [3150] B31B 52,F5 BR LOOPR and go do these [3151] B31D 05,B2,96 CONTIN B GB1CE We've said it all!! [3152] * Now pop all entries off stack that we put on! [3153] B320 0F,78 GB258 XML VPOP Free up a temporary string [3154] B322 D5,6E,4C DCEQ @FAC2,@VSPTR [3155] B325 53,20 BR GB258 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0055 EQUATES EXEC-359 [3156] B327 51,BA BR GB0F2 And return to the caller [3157] *********************************************************** [3158] * SPGET subprogram. Load speech data from external device. [3159] * Use standard file I/O [3160] *********************************************************** [3161] B329 D6,42,B7 SPGET CEQ LPARZ,@CHAT Must have left parenthesis [3162] B32C 4D,BA BR ERRSYN [3163] B32E 06,B6,1A CALL SETRW Set PHROM read/write address [3164] B331 06,B6,0F CALL WAIT Wait till no one is speaking [3165] B334 06,B3,E7 NXTPAR CALL GETPRM Get the next parameter [3166] B337 8F,50 DCZ @FAC6 If non-null ASCII string [3167] B339 73,E0 BS GB318 [3168] B33B BD,06,4E DST @FAC4,@PTFCIS Pointer to 1st char in string [3169] B33E BD,0A,50 DST @FAC6,@PTLCIS Pointer to last-char-in-strin [3170] B341 A1,0A,06 DADD @PTFCIS,@PTLCIS by adding length-of-string [3171] B344 93,0A DDEC @PTLCIS and subtracting 1 [3172] B346 06,B6,1A CALL SETRW Set the speech read/write add [3173] B349 BD,08,06 DST @PTFCIS,@PTCCIS Set curr char to first char [3174] B34C 86,4C CLR @TOTTIM Clear total time delay [3175] B34E 06,B4,64 CALL GETTIM Get first timing mark [3176] B351 06,B4,54 CALL TIMING Get any subsquent marks [3177] * Get one phrase, and look it up. If the phrase is not foun [3178] * substitute in 'UHOH'. [3179] B354 C5,08,0A DCH @PTLCIS,@PTCCIS Possible phrase [3180] B357 73,E0 BS GB318 [3181] B359 06,B3,FD CALL PHRASE Yes, go get it [3182] B35C D6,4B,01 CEQ 1,@SPLFLG Spell flag set then set [3183] B35F 53,64 BR GB29C [3184] B361 BD,10,0C DST @PTFCIP,@PTLCIP last ptr to first (1 char) [3185] B364 06,B4,F9 GB29C CALL LOOKUP Look up the phrase [3186] B367 8F,4D DCZ @DATAAD If not there, [3187] B369 53,72 BR GB2AA [3188] B36B BF,4D,71 DST >71F4,@DATAAD use 'UHOH' data addr B36E F4 [3189] B36F BE,64,51 ST >51,@STRLEN 'UHOH' data length [3190] * Data must be in PHRADD and PHLEN, so move it [3191] B372 BD,01,4D GB2AA DST @DATAAD,@PHRADD [3192] B375 BC,00,64 ST @STRLEN,@PHLEN [3193] B378 A2,00,03 ADD 3,@PHLEN For overhead info [3194] * There must be a variable to put this data in. If not, err [3195] B37B 0F,7E XML SPEED [3196] B37D 00 BYTE SYNCHK [3197] B37E B3 BYTE COMMAZ [3198] B37F 0F,7A XML SYM Find symbol in table [3199] B381 0F,7B XML SMB Evaluate andy subscripts [3200] B383 0F,77 XML VPUSH Save for assignment [3201] B385 86,0C CLR @BYTES Two byte value [3202] B387 BC,0D,00 ST @PHLEN,@BYTES+1 Length of string needed [3203] B38A 0F,71 XML GETSTR Get a string for the data [3204] B38C 06,B6,1A CALL SETRW Set up speech read/write addr [3205] B38F BF,4A,00 DST >001C,@FAC Now build string FAC entry B392 1C [3206] B393 BF,4C,65 DST >6500,@FAC2 String ID B396 00 [3207] B397 BD,4E,1C DST @SREF,@FAC4 Pointer to string [3208] B39A BD,50,0C DST @BYTES,@FAC6 Length of string [3209] B39D BF,B0,1C DST >6000,V*SREF Mark string as speech data B3A0 60,00 [3210] B3A2 BC,E0,02 ST @PHLEN,V@2(@SREF) Put in string length B3A5 1C,00 [3211] B3A7 A7,E0,01 DSUB 3,V@1(@SREF) minus thei info B3AA 1C,00,03 [3212] * LOADAD expects addr to be in PTFBPH, so move it. [3213] B3AD BD,12,01 DST @PHRADD,@PTFBPH 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0056 EQUATES EXEC-359 [3214] B3B0 06,B5,B5 CALL LOADAD [3215] * Going to copy string from PHROM to VDP. The actual data [3216] * from PHROM is in bit-reversed order, so must reverse the [3217] * order after reading in the order. Remember that 3 bytes [3218] * PHLEN are our own overhead, so don't copy all [3219] B3B3 C6,00,03 GB2EB CH 3,@PHLEN [3220] B3B6 53,DE BR GB316 [3221] B3B8 BE,C0,00 ST >10,@VAR0(@WRITE) Issue read byte command B3BB 5A,10 [3222] B3BD BC,68,C0 ST @VAR0(@READ),@BYTE3 Read the byte B3C0 00,58 [3223] * the following code is somewhat tricky. It will bit [3224] * reverse the contents of BYTE3 into BYTE1 through [3225] * BYTE2 by means of word shifts. Note the definition of [3226] * BYTE1 , BYTE2, and BYTE3 in EQU's. You might try an [3227] * example if it isn't clear what is going on. [3228] B3C2 86,67 CLR @BYTE2 [3229] B3C4 BE,54,08 ST >08,@TEMP1 [3230] B3C7 EB,67,00 RNDAG DSRC 1,@BYTE2 B3CA 01 [3231] B3CB E3,66,00 DSLL 1,@BYTE1 B3CE 01 [3232] B3CF 92,54 DEC @TEMP1 [3233] B3D1 53,C7 BR RNDAG [3234] * Store the bit-corrected byte into the string & inc str pt [3235] B3D3 BC,E0,03 ST @BYTE1,V@3(@SREF) B3D6 1C,66 [3236] B3D8 91,1C DINC @SREF [3237] B3DA 92,00 DEC @PHLEN Dec the string length [3238] B3DC 53,B3 BR GB2EB Go do next char if there is o [3239] B3DE 0F,7C GB316 XML ASSGNV Assign the string to variable [3240] B3E0 D6,42,B3 GB318 CEQ COMMAZ,@CHAT If more go do [3241] B3E3 73,34 BS NXTPAR [3242] B3E5 51,BA BR GB0F2 [3243] *********************************************************** [3244] * GETPAM gets the next string paameter passed to the [3245] * routine. If that parameter is non-exist or null, then [3246] * condition bit is set. If the parameter is there then [3247] * condition bit is reset and the FAC entry describes the [3248] * string. In either case, return with condition is done. [3249] *********************************************************** [3250] B3E7 0F,79 GETPRM XML PGMCHR Get next token [3251] B3E9 D6,42,B3 CEQ COMMAZ,@CHAT Go set condition no parm [3252] B3EC 73,F9 BS SETCB [3253] B3EE 0F,74 XML PARSE [3254] B3F0 B6 BYTE RPARZ [3255] B3F1 D6,4C,65 CEQ >65,@FAC2 If not string, error [3256] B3F4 4D,BE BR ERRSNM [3257] B3F6 8F,50 DCZ @FAC6 Set cond if null string [3258] B3F8 01 RTNC Else return [3259] B3F9 D4,00,00 SETCB CEQ @VAR0,@VAR0 Set condition bit [3260] B3FC 01 RTNC [3261] *********************************************************** [3262] * Get the next phrase out of the current string. The phrase [3263] * may begin with a #, which means it will continue to the [3264] * next #, or it many begin with an ordinary character, in [3265] * which case it will end with the character just before the [3266] * first timing character encountered. In either case, the [3267] * end of the string will indicate a legal end of phrase if [3268] * it occurs before the usual indicator! [3269] *********************************************************** [3270] B3FD D6,4A,23 PHRASE CEQ NUMBER,@CCHAR Phrase start with #? [3271] B400 54,38 BR GB370 [3272] B402 91,08 DINC @PTCCIS Yes, inc CC ptr past # 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0057 EQUATES EXEC-359 [3273] B404 D6,B0,08 GB33C CEQ SPACE,V*PTCCIS Skip spaces B407 20 [3274] B408 54,0E BR GB346 [3275] B40A 91,08 DINC @PTCCIS [3276] B40C 54,04 BR GB33C [3277] B40E D6,B0,08 GB346 CEQ NUMBER,V*PTCCIS All spaces? B411 23 [3278] B412 54,17 BR GB34F [3279] B414 91,08 DINC @PTCCIS Yes, skip this # too [3280] B416 00 RTN And ignore this phrase [3281] B417 BD,0C,08 GB34F DST @PTCCIS,@PTFCIP Save 1st char in phrase [3282] B41A 91,08 GB352 DINC @PTCCIS Go on to next char [3283] * Got to watch for end of string. If encountered before a [3284] * #, act like char after string is #. Then last char will [3285] * be char before, or the last char in the string!! [3286] B41C C5,08,0A DCH @PTLCIS,@PTCCIS [3287] B41F 74,2A BS FNDNUM [3288] B421 BC,4A,B0 ST V*PTCCIS,@CCHAR No, get char in CCHAR B424 08 [3289] B425 D6,4A,23 CEQ NUMBER,@CCHAR If not # continue looking [3290] B428 54,1A BR GB352 [3291] B42A BD,10,08 FNDNUM DST @PTCCIS,@PTLCIP Last char in phrase is one [3292] B42D 93,10 DDEC @PTLCIP before the # [3293] B42F 91,08 DINC @PTCCIS Point to char after # [3294] B431 06,B4,64 CALL GETTIM Get 1st timing char after phr [3295] B434 86,4B CLR @SPLFLG Indicate don't spell [3296] B436 54,53 BR GB38B No # as 1st char in phrase [3297] B438 BD,0C,08 GB370 DST @PTCCIS,@PTFCIP Curr char is 1st char phrase [3298] B43B 86,4B CLR @SPLFLG Assume don't spell [3299] B43D CA,4A,41 CHE >41,@CCHAR If not alphabetic (>41="A") [3300] B440 74,44 BS GB37C [3301] B442 90,4B INC @SPLFLG set spell flag [3302] * Need to find end of phrase, which is char before next [3303] * timing char we find. Therefore, look for a timing char! [3304] B444 91,08 GB37C DINC @PTCCIS [3305] B446 06,B4,64 CALL GETTIM [3306] B449 D6,51,FF CEQ >FF,@TIMLEN If not timing, loop [3307] B44C 74,44 BS GB37C [3308] B44E BD,10,08 DST @PTCCIS,@PTLCIP Char before curr char is [3309] B451 93,10 DDEC @PTLCIP the last char in phrase [3310] B453 00 GB38B RTN [3311] *********************************************************** [3312] * TIMING will loop through chars in string until it finds [3313] * non-timing char. Non-timing chars have TIMLEN values of [3314] * >FE or >FF. GETTIM must be called before this routine to [3315] * establish a correct value of TIMLEN. Also, most likely [3316] * TOTTIM should have been cleared. [3317] *********************************************************** [3318] B454 CA,51,FE TIMING CHE >FE,@TIMLEN [3319] B457 74,63 BS GB39B [3320] B459 A1,4C,51 DADD @TIMLEN,@TOTTIM [3321] B45C 91,08 DINC @PTCCIS [3322] B45E 06,B4,64 CALL GETTIM [3323] B461 54,54 BR TIMING [3324] B463 00 GB39B RTN [3325] *********************************************************** [3326] * GETTIM will examine the current char in the string and [3327] * set TIMLEN to the appropriate time delay value. TIMLEN [3328] * can take on the following values: [3329] * >00 if char is timing '+' [3330] * >06 if char is timing ' ' [3331] * >0C if char is timing '-' [3332] * >12 if char is timing ',' [3333] * >1E if char is timing ';' 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0058 EQUATES EXEC-359 [3334] * >30 if char is timing ':' [3335] * >3C if char is timing '.' [3336] * >FE if char is out of stirng bounds [3337] * >FF if char is not timing [3338] * Note that to test timing, some manipulation of PTCCIS [3339] * would be neccesary, so it is stored and used in TEMP1 [3340] *********************************************************** [3341] B464 BC,4A,B0 GETTIM ST V*PTCCIS,@CCHAR Get the char B467 08 [3342] B468 BD,54,08 DST @PTCCIS,@TEMP1 store curr ptr in TEMP1 [3343] B46B C5,54,0A DCH @PTLCIS,@TEMP1 out of string bounds? [3344] B46E 54,74 BR GB3AC [3345] B470 BE,51,FE ST >FE,@TIMLEN Yes, load value and return [3346] B473 00 RTN [3347] B474 C6,4A,3B GB3AC CH SEMICO,@CCHAR Can not be timing [3348] B477 74,DE BS NOTIME [3349] B479 D6,4A,20 CEQ SPACE,@CCHAR [3350] B47C 54,8D BR GB3C5 [3351] B47E BE,51,06 ST 6,@TIMLEN [3352] B481 D6,E0,01 GB3B9 CEQ SPACE,V@1(@PTCCIS) While spaces B484 08,20 [3353] B486 54,8C BR GB3C4 [3354] B488 91,08 DINC @PTCCIS Skip them [3355] B48A 54,81 BR GB3B9 [3356] B48C 00 GB3C4 RTN [3357] B48D D6,4A,2B GB3C5 CEQ PLUS,@CCHAR [3358] B490 54,9C BR GB3D4 [3359] B492 91,54 DINC @TEMP1 Need to test the next char [3360] B494 06,B4,E2 CALL NUMERC Is it numeric [3361] B497 74,DE BS NOTIME Was numeric => not timing cha [3362] B499 86,51 CLR @TIMLEN Not numeric => set as no timi [3363] B49B 00 RTN [3364] B49C D6,4A,2C GB3D4 CEQ COMMAT,@CCHAR [3365] B49F 54,A5 BR GB3DD [3366] B4A1 BE,51,12 ST >12,@TIMLEN [3367] B4A4 00 RTN [3368] B4A5 D6,4A,2E GB3DD CEQ PERIOD,@CCHAR [3369] B4A8 54,BC BR GB3F4 [3370] B4AA 93,54 DDEC @TEMP1 Go back to preceding char [3371] B4AC 06,B4,E2 CALL NUMERC Is it numeric? [3372] B4AF 54,B8 BR PTIME No, so it is timing [3373] B4B1 95,54 DINCT @TEMP1 Yes, on to following char [3374] B4B3 06,B4,E2 CALL NUMERC Is it numeric too? [3375] B4B6 74,DE BS NOTIME Yes, both numeric => not timi [3376] B4B8 BE,51,3C PTIME ST >3C,@TIMLEN Both not numeric => timing [3377] B4BB 00 RTN [3378] B4BC D6,4A,2D GB3F4 CEQ HYPEN,@CCHAR [3379] B4BF 54,CC BR GB404 [3380] B4C1 91,54 DINC @TEMP1 Check next char [3381] B4C3 06,B4,E2 CALL NUMERC Is it numeric? [3382] B4C6 74,DE BS NOTIME Was numeric => not a timing c [3383] B4C8 BE,51,0C ST >0C,@TIMLEN Was not numeric => set as tim [3384] B4CB 00 RTN [3385] B4CC D6,4A,3A GB404 CEQ COLON,@CCHAR [3386] B4CF 54,D5 BR GB40D [3387] B4D1 BE,51,30 ST >30,@TIMLEN [3388] B4D4 00 RTN [3389] B4D5 D6,4A,3B GB40D CEQ SEMICO,@CCHAR [3390] B4D8 54,DE BR NOTIME [3391] B4DA BE,51,1E ST >1E,@TIMLEN [3392] B4DD 00 RTN [3393] B4DE BE,51,FF NOTIME ST >FF,@TIMLEN Set as no timing char present [3394] B4E1 00 RTN [3395] *********************************************************** 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0059 EQUATES EXEC-359 [3396] * NUMERC tests the char pointed to by PTCCIS and verifies [3397] * the following: [3398] * 1 - it is within the current string boundaries [3399] * 2 - it is numeric (i.e. between '0' and '9') [3400] * If both of the above conditions are true, COND is set [3401] * upon return, otherwise COND is reset [3402] *********************************************************** [3403] B4E2 C5,54,0A NUMERC DCH @PTLCIS,@TEMP1 [3404] B4E5 74,F8 BS GB430 [3405] B4E7 C5,06,54 DCH @TEMP1,@PTFCIS [3406] B4EA 74,F8 BS GB430 [3407] B4EC CA,B0,54 CHE >30,V*TEMP1 B4EF 30 [3408] B4F0 54,F8 BR GB430 [3409] B4F2 C6,B0,54 CH >39,V*TEMP1 B4F5 39 [3410] B4F6 53,F9 BR SETCB [3411] B4F8 01 GB430 RTNC [3412] *********************************************************** [3413] * LOOKUP is a prolong routine to SEARCH. In each PHROM, [3414] * there may be 2 trees, one starting at >0000 and the other [3415] * at >8000. Either may or may not be present. Presences is [3416] * determined if a >AA byte is at the starting location. [3417] * LOOKUP determines if the tree at >0000 is in, and if so, [3418] * calls SEARCH with that addr. If that tree is not present [3419] * or the phrase couldn't be found in it, LOOKUP then checks [3420] * if the tree at >8000 is present, and again, if so, calls [3421] * SEARCH with that tree address. If the word was found in [3422] * the first tree, or after searching the second tree, the [3423] * routine will return. [3424] *********************************************************** [3425] B4F9 87,66 LOOKUP DCLR @BYTE1 BYTE1 contains addr of curr t [3426] B4FB BD,12,66 TRYAGN DST @BYTE1,@PTFBPH Look for >AA tree header [3427] B4FE 06,B5,B5 CALL LOADAD LOADAD expects addr in PTFBPH [3428] B501 BE,C0,00 ST >10,@VAR0(@WRITE) Put out read byte command B504 5A,10 [3429] B506 D6,C0,00 CEQ >AA,@VAR0(@READ) Tree out there? B509 58,AA [3430] B50B 55,16 BR GB44E [3431] B50D 91,12 DINC @PTFBPH Skip the tree header [3432] B50F 06,B5,21 CALL SEARCH Go search this PHROM tree [3433] B512 8F,4D DCZ @DATAAD Phrase found => exit [3434] B514 55,20 BR FOUND [3435] B516 A3,66,80 GB44E DADD >8000,@BYTE1 Go to start of next PHROM tre B519 00 [3436] * Note >8000 + >8000 = >0000 => tried both trees [3437] B51A 8F,66 DCZ @BYTE1 [3438] B51C 54,FB BR TRYAGN [3439] B51E 87,4D DCLR @DATAAD Didnt find phrase in either t [3440] B520 00 FOUND RTN [3441] *********************************************************** [3442] * SEARCH actually searches the PHROM tree for the phrase. [3443] * The PHROM tree organization is as follows: [3444] * (i.e. this is one phrase node) [3445] * phrase ASCII length 1 byte [3446] * actual ASCII characters n bytes [3447] * less then pointer 2 bytes [3448] * greater then pointer 2 bytes [3449] * speech data pointer 3 bytes [3450] * speech data length 1 byte [3451] * The comparison of two words proceeds on a char by char [3452] * basis, where length is secondary to char values, i.e. [3453] * move > answer; number < we; eight < eighty; etc... [3454] *********************************************************** 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0060 EQUATES EXEC-359 [3455] B521 06,B5,B5 SEARCH CALL LOADAD Set PHROM to start phrase nod [3456] B524 BE,C0,00 ST >10,@VAR0(@WRITE) Issue read byte command B527 5A,10 [3457] B529 86,16 CLR @PTLCPH Length of phrase => PTLCPH [3458] B52B BC,17,C0 ST @VAR0(@READ),@PTLCPH+1 (stored as 2 byte value B52E 00,58 [3459] B530 A1,16,12 DADD @PTFBPH,@PTLCPH Add front ptr giving end ptr [3460] B533 BD,14,12 DST @PTFBPH,@PTCCPH Set up curr char as 1 beyond [3461] B536 91,14 DINC @PTCCPH length byte [3462] B538 BD,0E,0C DST @PTFCIP,@PTCCIP Reset current ptr into phrase [3463] * Compare two characters [3464] B53B BE,C0,00 NEXT ST >10,@VAR0(@WRITE) Issue read byte command B53E 5A,10 [3465] B540 BC,5D,C0 ST @VAR0(@READ),@PHDATA Get char in from PHROM B543 00,58 [3466] B545 D4,5D,B0 CEQ V*PTCCIP,@PHDATA Compare the char B548 0E [3467] B549 55,99 BR GB4D1 [3468] B54B 91,14 DINC @PTCCPH Equal, advance both pointers [3469] B54D 91,0E DINC @PTCCIP [3470] B54F D6,B0,0E CEQ SPACE,V*PTCCIP Skip extra spaces B552 20 [3471] B553 55,69 BR GB4A1 [3472] B555 D6,E0,01 GB48D CEQ SPACE,V@1(@PTCCIP) While spaces B558 0E,20 [3473] B55A 55,60 BR GB498 [3474] B55C 91,0E DINC @PTCCIP Skip them [3475] B55E 55,55 BR GB48D [3476] * By skipping extra spaces, might have reached end of phras [3477] * If this is true, next char in phrase = #. If so, advance [3478] * the pointer to be beyond end of phrase. [3479] B560 D6,E0,01 GB498 CEQ NUMBER,V@1(@PTCCIP) B563 0E,23 [3480] B565 55,69 BR GB4A1 [3481] B567 91,0E DINC @PTCCIP [3482] B569 C5,14,16 GB4A1 DCH @PTLCPH,@PTCCPH End of PHROM word? [3483] B56C 55,8E BR GB4C6 [3484] B56E C5,0E,10 DCH @PTLCIP,@PTCCIP Yes, end of phrase [3485] B571 55,88 BR GB4C0 [3486] B573 BD,12,16 DST @PTLCPH,@PTFBPH Yes, word found [3487] * Skip 5 bytes down from last char to data pointer [3488] B576 A3,12,00 DADD 6,@PTFBPH B579 06 [3489] B57A 06,B5,E7 CALL READAD Set data addr => DATAAD [3490] B57D BE,C0,00 ST >10,@VAR0(@WRITE) Issue read byte command B580 5A,10 [3491] B582 BC,64,C0 ST @VAR0(@READ),@STRLEN Get length of speech data B585 00,58 [3492] B587 00 RTN [3493] B588 BF,12,00 GB4C0 DST 3,@PTFBPH Move 3 bytes past PTLCPH B58B 03 [3494] B58C 55,A5 BR NXTPHR [3495] B58E C5,0E,10 GB4C6 DCH @PTLCIP,@PTCCIP 2 characters [3496] B591 55,3B BR NEXT [3497] B593 BF,12,00 DST 1,@PTFBPH Phrase linger: use LT ptr B596 01 [3498] B597 55,A5 BR NXTPHR [3499] * Two characters compared were not equal [3500] B599 BF,12,00 GB4D1 DST 3,@PTFBPH 3 bytes past last to GT B59C 03 [3501] B59D C4,5D,B0 CH V*PTCCIP,@PHDATA After phrase B5A0 0E [3502] B5A1 55,A5 BR NXTPHR [3503] B5A3 97,12 DDECT @PTFBPH Back up 2 bytes to LT link 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0061 EQUATES EXEC-359 [3504] * Go get next phrase out of the PHROM to compare [3505] B5A5 A1,12,16 NXTPHR DADD @PTLCPH,@PTFBPH Add displacement to last char [3506] B5A8 06,B5,E7 CALL READAD and get the new address [3507] B5AB 8F,4D DCZ @DATAAD More leaves on this tree [3508] B5AD 55,B0 BR GB4E8 [3509] B5AF 00 RTN No, return empty handed [3510] B5B0 BD,12,4D GB4E8 DST @DATAAD,@PTFBPH Store new addr in PTFBPH [3511] B5B3 55,21 BR SEARCH Go compare this new word! [3512] * The program should never reach this point!! It should [3513] * return somewhere up above. [3514] *********************************************************** [3515] * LOADAD will set the addr out in the PHROM to the addr [3516] * found in PTFBPH. Note that the PHROM is expecting five [3517] * nybbles to be written out as the address. [3518] *********************************************************** [3519] B5B5 BD,54,12 LOADAD DST @PTFBPH,@TEMP1 This is destructive, so copy [3520] B5B8 BD,56,12 DST @PTFBPH,@TEMP2 address into temporary areas [3521] B5BB E6,54,04 SRL 4,@TEMP1 Isolate the MSN of the MSB [3522] B5BE E6,55,04 SRL 4,@TEMP1+1 Isolate the MSN of the LSB [3523] B5C1 B3,56,0F DAND >0F0F,@TEMP2 Isolate the LSN of the MSB, L B5C4 0F [3524] B5C5 B7,54,40 DOR >4040,@TEMP1 Include a 4 as MSN of all 4 n B5C8 40 [3525] B5C9 B7,56,40 DOR >4040,@TEMP2 to indicate a Load Address C B5CC 40 [3526] B5CD BC,C0,00 ST @TEMP2+1,@VAR0(@WRITE) Write out the LSN of th B5D0 5A,57 [3527] B5D2 BC,C0,00 ST @TEMP1+1,@VAR0(@WRITE) Write out the LSN of th B5D5 5A,55 [3528] B5D7 BC,C0,00 ST @TEMP2,@VAR0(@WRITE) Write out the MSN of th B5DA 5A,56 [3529] B5DC BC,C0,00 ST @TEMP1,@VAR0(@WRITE) Write out the MSN of th B5DF 5A,54 [3530] B5E1 BE,C0,00 ST >40,@VAR0(@WRITE) Write out 0 as fifth ny B5E4 5A,40 [3531] B5E6 00 RTN [3532] *********************************************************** [3533] * READAD will read an address from the PHROM and store it [3534] * in DATAAD. Note that PTFBPH should contain the addr of [3535] * the PHROM location to be read so LOADAD will work. [3536] *********************************************************** [3537] B5E7 06,B5,B5 READAD CALL LOADAD Set the addr of the PHROM [3538] B5EA BE,C0,00 ST >10,@VAR0(@WRITE) Get high byte of addr B5ED 5A,10 [3539] B5EF BC,4D,C0 ST @VAR0(@READ),@DATAAD Stroe it in DATAAD B5F2 00,58 [3540] B5F4 BE,C0,00 ST >10,@VAR0(@WRITE) Get low byte of addr B5F7 5A,10 [3541] B5F9 BC,4E,C0 ST @VAR0(@READ),@DATAAD+1 Store it in DATAAD+1 B5FC 00,58 [3542] B5FE 00 RTN [3543] *********************************************************** [3544] * STDATA will store the data in DATAAD and TOTTIM onto the [3545] * speech list. It will also check that there is room on the [3546] * speech list for this entry, and abort with error if not. [3547] *********************************************************** [3548] B5FF D5,02,04 STDATA DCEQ @PTEBSL,@PTLBSL Is there room? [3549] B602 76,21 BS ERRSSL [3550] B604 35,00,03 MOVE 3,@TOTTIM,V*PTLBSL Put data in list B607 B0,02,4C [3551] B60A A3,02,00 DADD 3,@PTLBSL and inc top of list B60D 03 [3552] B60E 00 RTN [3553] *********************************************************** 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0062 EQUATES EXEC-359 [3554] * WAIT loops until the speech peripheral goes idle. [3555] *********************************************************** [3556] * ( Loop until nobody is talking) [3557] B60F BC,69,C0 WAIT ST @VAR0(@READ),@SPKSTS Read status from PHROM B612 00,58 [3558] B614 DA,69,80 CLOG >80,@SPKSTS [3559] B617 56,0F BR WAIT [3560] B619 00 RTN [3561] *********************************************************** [3562] * SETRW moves addrs of speech read/write from GROM to VDP [3563] *********************************************************** [3564] B61A 31,00,04 SETRW MOVE 4,G@>0046,@READ B61D 58,00,46 [3565] B620 00 RTN [3566] *********************************************************** [3567] * ERROR MESSAGES [3568] *********************************************************** [3569] * The following calls are in EXECS file. [3570] * ERRSYN CALL ERRZZ * SYNTAX ERROR [3571] * BYTE 3 [3572] * ERRSNM CALL ERRZZ * STRING-NUMBER MISMATCH [3573] * BYTE 7 [3574] * ERRBV CALL ERRZZ * BAD VALUE [3575] * BYTE 30 [3576] * ERRIAL CALL ERRZZ * INCORRECT ARGUMENT LIST [3577] * BYTE 31 [3578] *********************************************************** [3579] B621 06,6A,84 ERRSSL CALL ERRZZ * SPEECH STRING TOO LONG [3580] B624 15 BYTE 21 [3581] *********************************************************** The only real big difference is the amount of words in the library, this is why the XB disk TEXT to Speech is the same pretty much as Text to Speech on TE2 Cart. Edited August 1, 2018 by RXB Quote Link to comment Share on other sites More sharing options...
sprot Posted August 7, 2018 Share Posted August 7, 2018 I think these disk files maybe what you are looking for, lots of module conversions in this achive. TI99 Disks (tosec 001).rar 2 Quote Link to comment Share on other sites More sharing options...
